***Official B/C/E/G6P OLED Calibration Thread - Page 63 - AVS Forum | Home Theater Discussions And Reviews
 561Likes
post #1861 of 1884 Old 08-09-2017, 10:54 AM
bpmurr's Avatar
Quoted: 156 Post(s)
Liked: 112
I'd like to calibrate my 65B6P beyond what I can do today by eye with a calibration Blu-ray and a color filter. What do you recommend for an amateur calibrator just starting out?
i1Display Pro and CalMAN Home Enthusiast or is that overkill?
75X850C l 65B6P l P55-C1 l SB4551-D5 l XB1 S l PS4 Pro l LIVE:BPMURR l PSN:BPMURR
bpmurr is offline
post #1862 of 1884 Old 08-09-2017, 11:00 AM
Jrocker23's Avatar
Quoted: 64 Post(s)
Liked: 43
Color filters such as the blue filter don't work properly with OLED. You can do other calibrations with color but the blue filter method wouldn't be accurate
Sent from my HTC6545LVW using Tapatalk
Living Room: LG 55C6P, AVR Yamaha RX-V381, Xbox One S, Playstation 4 Pro, Nintendo Switch
Bedroom: LG 55UH8500, LG Soundbar NB3530A, Halo 5 Xbox One
Link to LG UH8500 & C6 Firmware (Click the reference tab on the right side to see firmware details)
http://www.lg.com/us/support-product...D55C6P#manuals
Jrocker23 is offline
post #1863 of 1884 Old 08-09-2017, 11:05 AM
jayraysaiz's Avatar
Quoted: 112 Post(s)
Liked: 25
I use ChromaPure and the i1Display pro. ChromaPure is relatively inexpensive and their customer service is very quick to respond to any inquires but HFCR is free and has a lot of traffic in its calibration thread so someone will be able to answer your questions.
OLED's seem to need to be coddled, you have to take them out, warm them up, and get them comfortable before they let you inside to calibrate them.
I suggest you move your OLED into a padded room the first couple of runs until you get the hang of it. You may want to break something.
Jrocker23 likes this.
LGOLED65B6P
Onkyo Tx NR3030;HDBaseT
Klipsch 7.1.4
R-3800-W II Fronts ; R-5502-W II Center
RS-42 II Surrounds ; CDT-3800-C II Heights
R-112SW Sub
jayraysaiz is offline
post #1864 of 1884 Old 08-09-2017, 11:06 AM
bpmurr's Avatar
Quoted: 156 Post(s)
Liked: 112
Which gets back to my original question. What does one need?
Thanks, I'll give them a look. Would you say ChromaPure is any easier or harder to work with for an amateur than CalMAN? I could always start with my P Series or X850C.
bpmurr is offline
post #1865 of 1884 Old 08-09-2017, 11:07 AM
Jrocker23's Avatar
Quoted: 64 Post(s)
Liked: 43
I will leave that up to the pros here. I wouldn't know where to start. I am looking to pay for a calibration
post #1866 of 1884 Old 08-09-2017, 11:10 AM
jayraysaiz's Avatar
Quoted: 112 Post(s)
Liked: 25
Thanks! I'll give them a look. Would you say ChromaPure is any easier or harder to work with for an amateur than CalMAN?
I haven't used CalMAN but I did consider it. I like pretty pictures.....so being able to generate a report for pre-calibration and post calibration I opted for ChromaPure.
I am in about ~$430 and a tad more once I get the UHD calibration disc. I am not experienced by any means but the test runs I have been able to make have greatly improved issues I had with less than adequate satellite and streaming feeds.
I have the HDR10 USB files but I can't test out the UHD player to TV link since the files will not play through my UHD player's usb.
LGOLED65B6P
Klipsch 7.1.4
R-112SW Sub
post #1867 of 1884 Old 08-09-2017, 11:17 AM
dschlic1's Avatar
Quoted: 125 Post(s)
Liked: 39
I use HCFR and an i1Pro Display on my OLED.
LG OLED65B6P TV, Yamaha RX-V665 AV receiver, Sony BDP_S1700 Player, Klipsch F-30 speaker system
dschlic1 is offline
post #1868 of 1884 Old 08-09-2017, 03:56 PM
camacho8's Avatar
Liked: 0
Do you use the oled profile from HCFR or non refresh ? I got a Sony A1 and i'am not sure which profile would work best...Thanks
camacho8 is offline
post #1869 of 1884 Old 08-10-2017, 12:41 AM
256k's Avatar
Quoted: 167 Post(s)
Jesus christ guys, FINALLY, dont know what the hell i did but for FIRST TIME i was able to touch the 20 points of HDR CALIBRATION
Settings on service menu -> Sub Brightness 126
Settings -> Brightness 52, contrast 99
The 127 cannot be touched, because it lead to huge tint, so it will be at DE 18 aprox. , but the rest of the HDR can be touched, i finished with a D.E of 2.40... FROM 20!, So i'm so happy that finally i've been able to calibrate the HDR (it's been a real pain in the ass, because on the latest codes, you have to be careful because if not, it gets tinted on the grayscale ramp), now it's perfect ñ___ñ
Maybe it was aligned now because of the new 05.30.10 firmware?
256k is online now
post #1870 of 1884 Old 08-10-2017, 04:53 AM
Overrid3's Avatar
Quoted: 104 Post(s)
Liked: 59
People have said not to use the OLED profile in HCFR since it's not accurate for LG. I got good results using non refresh, but I got even better results (to my eyes) using this profile I found on the SpectraCal website. Some created it using an i1d3, i1 Pro 2 and the LG C6.
File Type: zip meter corrections.zip (821 Bytes, 14 views)
mttpalmer, camacho8 and mo949 like this.
Overrid3 is offline
post #1871 of 1884 Old 08-10-2017, 10:49 AM
jayraysaiz's Avatar
Quoted: 112 Post(s)
Liked: 25
Settings -> Brightness 53, contrast 86, or 87? not in home right now (to keep the pure black while having all the grayscale)
I thought the brightness setting was to be left alone for HDR due to the tone mapping algorithm. Is this something I miss read? I've been reading the Near Black thread and a lot of people are adjusting the Sub-Brightness to a lower value. Would this not have an adverse affect on HDR content?
It seems the Sub-Brightness is to help near black/noise issues in less than quality feeds for SDR.
LGOLED65B6P
Klipsch 7.1.4
R-112SW Sub
post #1872 of 1884 Old 08-10-2017, 10:57 AM
256k's Avatar
Quoted: 167 Post(s)
Sub-brightness makes the TV even darker (thats why it fix the glow), so to have the HDR back to50 i had to put it to 52, BTW i fixed the data i put there, it wasnt 53/87, it was 52/99
256k is online now
post #1873 of 1884 Old 08-11-2017, 11:46 AM
Quoted: 63 Post(s)
Liked: 55
Correct, and since tone mapping is 100% internal there is no way to confirm that something isn't screwy after changing sub brightness. Hard to say for sure watching real content, as no tv can hit all the parameters of HDR. What's it supposed to look like in the first place.
JNayAV is offline
post #1874 of 1884 Old 08-13-2017, 09:45 AM
Overrid3's Avatar
Quoted: 104 Post(s)
Liked: 59
Anyone know a reason why near-black could go nonlinear? I'm still playing around with my gamma cal a bit, and I've noticed that changing brightness just one click throws off the near-black bars. At brightness 50, things look good (each one slowly increases in brightness). If I go one click higher to 51, some bars will be brighter than the next. For example, bar 19 will be brighter than 20.
Overrid3 is offline
post #1875 of 1884 Old 08-14-2017, 05:35 AM
Overrid3's Avatar
Quoted: 104 Post(s)
Liked: 59
I think I've gotten my near-blacks about as good as I can. I figured out how to emulate Chad B's 2.35 sliding power curve using HCFR, although I'm not sure why it's called 2.35 because gamma never reaches that number. I aimed for the gamma values mentioned here:
His curve starts with 2.21 at 5 IRE and tops out around 2.33 at the high end. I was able to create a similar gamma target in HCFR, but the big disappointment is I can't seem to get gamma low enough at 5 IRE. Mine is around 2.27, which still isn't bad, IMO, just doesn't show as much shadow detail.
The problem I'm running into is near-black going non linear. I was able to create a really nice gamma curve with 5 IRE around 2.2, but near-black was wrong. Bar 19 was obviously brighter than bar 20. Near-blacks look good if I push brightness to 52, but then my screen glows. So, the best I could do is:
Brightness 51
OLED 30
gamma BT.1886 (tweaked from there)
luminance at 5 IRE +8
If 5 IRE luminance is at 0 to +6, near-blacks are not linear. At +7 to +8 it looks good, and at +9 it goes wacky again. These TVs are very finicky in the near-black region.
In graph below, yellow is my gamma, blue is reference.
Overrid3 is offline
post #1876 of 1884 Old 08-14-2017, 06:04 AM
BigCoolJesus's Avatar
Quoted: 1511 Post(s)
Liked: 1197
@D-Nice
I believe I read a while ago that you discovered setting the Color Gamut to Extended and Color to 43 allowed full use of the CMS controls for the 2016's with artifacts or real content issues.
Am I making this up or is that accurate?
Sent from my Pixel XL using Tapatalk
BigCoolJesus is offline
post #1877 of 1884 Old 08-14-2017, 04:37 PM - Thread Starter
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 2948
Realize I haven't visited 'my' thread in a long time (and also that I'm being lazy), but I have a question for anyone who's had a meter on a 2016 WOLED recently:
What is the approximate 100% IRE output luminance on ISF Bright and ISF Dark with default settings?
I know that getting OLED Light down in the 30-40 range (with Contrast at default of 85) get 100% IRE down into the 120-150cs/m2 range, but I forget what 100% IRE ouput results from leaving OLED Light at default in the two ISF modes (at least one of which has OLED Light at 80).
fafrd is offline
post #1878 of 1884 Old 08-14-2017, 04:41 PM - Thread Starter
fafrd's Avatar
Quoted: 14 Post(s)
Liked: 2948
Overkill.
Start with HCFR - better to learn the basics with and if you end up deciding that you need more handholding, you can always move to CalMAN or Chrompure in a next step...
fafrd is offline
post #1879 of 1884 Old 08-14-2017, 08:05 PM
Overrid3's Avatar
Quoted: 104 Post(s)
Liked: 59
I was able to get a better BT curve while still keeping near-blacks correct. If I used the wrong combination of settings (brightness, luminance at 5 IRE, etc.) the black bars can get brighter in the wrong order, so that's something to watch out for.
Overrid3 is offline
post #1880 of 1884 Old 08-18-2017, 09:45 AM
256k's Avatar
Quoted: 167 Post(s)
i've done something weird, used 1.9 as base, then lowered from 10-100 IRE luminances to match 2.20, but my IRE 5 has 2.40 gamma and still i have the entire grayscale, not to say that the image now has a "pop" that it's incredible, since black levels are perfect but at the same time, really dark
256k is online now
post #1881 of 1884 Old 08-18-2017, 09:06 PM
Overrid3's Avatar
Quoted: 104 Post(s)
Liked: 59
Wouldn't it be better of 5 IRE was at 2.2, and 10-100 were at 2.4?
Overrid3 is offline
post #1882 of 1884 Old 08-19-2017, 12:05 AM
256k's Avatar
Quoted: 167 Post(s)
Since IRE 5 is the one that controls all the shadow detail, no, for me it is better that IRE 5 is the darker one, thats why the image gets so much pop because of the depth
256k is online now
post #1883 of 1884 Old 08-19-2017, 11:32 AM
Overrid3's Avatar
Quoted: 104 Post(s)
Liked: 59
That's the opposite of the usual BT.1886 curve, but if you like it, then glad it's working. If I set my 5 IRE to 2.4 gamma, I get black crush like a mofo.
Overrid3 is offline
post #1884 of 1884 Old 08-20-2017, 03:05 AM
256k's Avatar
Quoted: 167 Post(s)
just a few notes:
Yesterday i noticed on LOGAN that there was a few scenes insanely dark on HDR, i put the Blu-ray and those scenes were really bright, it was then when i noticed that the HDR Standard was too dark for black levels, it wasnt bright, so after touching the calibration again, i've found that to make HDR look as it should (dark but VISIBLE) and bright as it was, we're forced to use Dynamic Contrast to LOW (not more), when using LOW + calibrated i got under 3.5D.E (IRE 127 cant be fixed) on HDR and that scene on logan now looks like on Blu-ray but with the HDR darkness/brightness (Because trust me, without that Dynamic contrast LOW, the scene was so dark that i cannot see some places of the room because of that)
256k is online now
Reply Display Calibration
