Question about triplet calculation - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-08-2017, 12:45 PM - Thread Starter
Jeroen1000's Avatar
Quoted: 37 Post(s)
Managed to get slightly confused as usual.
In Calman the target triplet voor 75% stim. yellow is 180,180,16. So I calculated this to 70% 70% 0% RGB percentages and had the Iscan Duo (controlled by the Iscan duo control panel - not Calman) send those.
x,y are spot on. But Y is too low according to Calman when I have it read the 70% 70% 0% RGB triplet. When I set the Target Y Calman wants in the Duo control panel, the triplet changes to 75% 75% 0%. But that is not 180,180,16 any more...
What's up with that?:-) please give me the 101 on this. I'm guessing it has something to do with the the Duo control panel is targeting a theoretical 100 cd/m²?
numbers: Duo is targeting 0,420316 Y for 70% 70% 0% and Calman is targeting 0,483234 which the duo says is 75% 75% 0%.
My gear: Panasonic TH-42PF11EK pro plasma display + TX-P55VT60E -- Iscan Duo video processor -- i1 display 3 colorimeter -- i1 pro 2 spectrometer
Jeroen1000 is offline
post #2 of 3 Old 03-09-2017, 03:24 AM
ConnecTEDDD's Avatar
Quoted: 1671 Post(s)
Liked: 2081
Hi, DVD iScan DUO as a pattern generator can display patterns only with percentage values (0-100%) as you know, so 100 steps, in16-235 video TV legal range.
The 75% Yellow you ask from CalMAN, supposed to have match with 75% 75% 0% from DUO. (Why you are comparing with 70-70-0?)
I haven't used DUO at past, but in duo control, do you see 8bit digital values there?
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #3 of 3 Old 03-09-2017, 04:57 AM - Thread Starter
Jeroen1000's Avatar
Quoted: 37 Post(s)
Basically I just made the wrong calculation. Kind of stupid I know but now I get to 74,88 which is 75%. Just remeasured and now it checks out just fine.
Reply Display Calibration
