Meter Not Working in Calman - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By randal_r
post #1 of 8 Old Yesterday, 08:17 PM - Thread Starter
bee144's Avatar
Liked: 1
Solved: Meter Not Working in Calman
This issue is now resolved.
Hi All,
I can’t seem to connect to my meter now. My meter seems to show up in the menu as X-Rite i1Display Retail but the meter shows up as red. (I attached two pictures)
I thought I read in the below link that my meter is supported in RGB as it worked in Calman Enthusiast.
http://calman.spectracal.com/tech-specs-calman-rgb.html
Is there are reason why I can't fully connect to my meter?
Bryan
ID:	2081985   Click image for larger version
bee144 is online now
post #2 of 8 Old Today, 12:16 AM
Quoted: 1466 Post(s)
Liked: 606
Originally Posted by bee144 View Post
Hi All,
Bryan
Looks like your software isn't authorized for that computer. Do you have it installed on more than one computer? Is it paid software?
A few months ago, Spectracal changed from allowing you to put it on as many computers as you want to only allowing it to be authorized on one computer. By exception, you can request a second computer . What they're trying to do is stop the abuse of people sharing their license keys.
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is online now
post #3 of 8 Old Today, 12:34 AM - Thread Starter
bee144's Avatar
Liked: 1
Hi Jim,
Thank you for the reply. I believe the license was successfully applied. I attached a screenshot as proof but I'm still running into the same issue.
bee144
post #4 of 8 Old Today, 04:29 AM
Liked: 606
Seems that I read about that happening to some others over on the Calman thread.
Check out the last couple of pages. CalMan 5 Release Notes and Discussion
JimP is online now
post #5 of 8 Old Today, 05:20 AM
randal_r's Avatar
Quoted: 171 Post(s)
Liked: 117
Not sure if this is of any help but would it hurt to load on the driver pack from SpectraCal? LINK
randal_r is offline
post #6 of 8 Old Today, 05:39 AM
ConnecTEDDD's Avatar
Quoted: 1233 Post(s)
Liked: 1757
Hi All,
Bryan
Hi Brian,
If you are not using the X-Rite's i1Profiler Software, remove the X-Rite Device Manager (If it's installed) using Windows Control Panel.
If you cannot find X-Rite device services in control panel follow instructions below:
Open in the Administrative Tools / Computer Management /
Look for X-Rite Device Services Manager
Double click on that name and a new window will appear
Click the "Quit" button to close the process.
or:
Run "services.msc". At the bottom of the services list, if you see an X-Rite Device Service listed, turn it off.
These X-Rite devices services are not letting third party software to access the meter to some setups.
Hi Randal,
i1Display PRO Retail or OEM use the Human Interface Device (HID) drivers contained in Windows, there no other drivers needed to be installed from X-Rite or SpectraCAL etc.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #7 of 8 Old Today, 12:22 PM
randal_r's Avatar
Quoted: 171 Post(s)
Liked: 117
Thanks Ted,
Just grasping at a possibility. Here is a second thought, could there be an issue with the HID drivers? He could check the device manager in the systems section of the control panel. If there is an issue it should show up there.
Thanks again for your knowledge.
ConnecTEDDD likes this.
randal_r is offline
post #8 of 8 Old Today, 03:23 PM - Thread Starter
bee144's Avatar
Liked: 1
Thanks Ted,
This was just resolved. It turns out my initial license didn't fully apply so I was stuck in a "half trial/half licensed" product.
They gave me a new product key and the issue was resolved.
Thank you to everyone on here for your help!
Reply Display Calibration
