Calibration setting Samsung UE55KS9000 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By willieconway
post #1 of 18 Old 04-16-2017, 12:06 AM - Thread Starter
Liked: 0
Hello to all, congratulations for the forum. I am new to the forum, my name is Tony and I am writing from Italy. A few days ago I bought an amazing (for me) TV Samsung 55 "- KS9000 curved model. Can you help me to do the right settings? Thanks a lot
lapotony is offline
post #2 of 18 Old 04-16-2017, 12:03 PM
Otto Pylot's Avatar
Quoted: 1669 Post(s)
Liked: 1043
There are four ways to adjust or calibrate your panel.
1. Get a calibration disk such as the free AVS HD709 disk or purchase a commercial one and adjust the basic settings yourself. It won't be a calibration but it may be all you need.
2. Purchase a light meter and software and teach yourself how to calibrate. It can definitely be a steep learning curve but very satisfying.
3. Pay for a professional calibration.
4. Tweak to taste.
Borrowing settings from someone else can be an exercise in futility. It may be an ok way to start but you will quickly learn that what looks like "killer" on one panel, may look like crap on yours. The reason being is component tolerances that are set at time of mfr and final QC/QA. They can be very different for each panel, even within the same build. The tolerances can be well within mfr spec but it is very unlikely to find two panels with exactly the same component tolerance settings.
Otto Pylot is offline
post #3 of 18 Old 04-16-2017, 01:06 PM - Thread Starter
Liked: 0
Well, kindly can you tell me how can I get the free disk calibration HD709?
I also saw a video AVforum calibration of the Samsung KS9000AVS
lapotony is offline
post #4 of 18 Old 04-16-2017, 02:27 PM
GeorgeAB's Avatar
Location: Denver, CO metro area, www.cinemaquestinc.com
Quoted: 152 Post(s)
Liked: 260
Lightbulb
AVS HD 709 - Blu-ray & MP4 Calibration
'Sharing display menu settings?'
http://www.avsforum.com/avs-vb/showthread.php?t=1055906
'Why copying settings from the web won't get you a calibrated TV'
http://forums.hdtvtest.co.uk/index.php?topic=7202.0
GeorgeAB is offline
post #5 of 18 Old 04-17-2017, 02:32 AM - Thread Starter
Liked: 0
The procedure with the disc is difficul
lapotony is offline
post #6 of 18 Old 04-17-2017, 02:34 AM - Thread Starter
Liked: 0
Unfortunately I'm not very experienced and only now I approach the world of high-end TV. So I want to find, if possible, an easy procedure
lapotony is offline
post #7 of 18 Old 04-17-2017, 05:08 AM
Ips
Ips's Avatar
Quoted: 25 Post(s)
An easy approach would be to pay a professional calibrator to adjust the TV for you.
Here is a list of ISF-certified calibrators located in Italy from the Imaging Science Foundation website:
https://www.imagingscience.com/dealers.php?search=Italy
Ivan Samuel
Greyscale Solutions
Ips is offline
post #8 of 18 Old 04-17-2017, 05:15 AM - Thread Starter
Liked: 0
Thanks for the answer but they are very far away from my home town; It is difficult to find them
lapotony is offline
post #9 of 18 Old 04-17-2017, 05:17 AM
Ips
Ips's Avatar
Quoted: 25 Post(s)
I wouldn't let that put you off contacting some of them.
Most calibrators travel significant distances for appointments.
Ivan Samuel
Greyscale Solutions
Ips is offline
post #10 of 18 Old 04-17-2017, 05:21 AM - Thread Starter
Liked: 0
In your opinion, what is the reward for a calibration?
lapotony is offline
post #11 of 18 Old 04-17-2017, 05:26 AM
Ips
Ips's Avatar
Quoted: 25 Post(s)
Have a look at these articles for an overview of the reason behind the display calibration process and expected results:
http://www.lightillusion.com/why_calibrate.html
http://www.trustedreviews.com/opinio...is-it-worth-it
Ivan Samuel
Greyscale Solutions
Ips is offline
post #12 of 18 Old 04-17-2017, 06:37 AM
AKJohnny's Avatar
Quoted: 40 Post(s)
Liked: 25
Where is your home town? A number of the pro calibrators travel, and if we know where you are at, someone may recommend a pro that visits your location.
AKJohnny is offline
post #13 of 18 Old 04-17-2017, 07:09 AM - Thread Starter
Liked: 0
I believe it is very expensive to consult one of these professionals
lapotony is offline
post #14 of 18 Old 04-17-2017, 10:08 AM
willieconway's Avatar
Quoted: 166 Post(s)
Liked: 156
If you want easy, just select Movie mode and Warm 2. All the online reviews I can find say that that'll give the most accurate picture out of the box (as is usually the case with Samsungs). Also, it'll give you an idea whether or not you even like a calibrated picture. Not everybody does.
Adjusting settings according to personal preference is not calibration.
Epson 5030UB, 100" Carada Criterion with Classic Cinema White, Onkyo TX-NR818, NHT Classic 3s, Classic ThreeC, SuperZero 2.1s, Mirage Omni S10, Oppo 103D.
My Blu-Ray collection
willieconway is online now
post #15 of 18 Old 04-17-2017, 11:02 AM - Thread Starter
Liked: 0
Yes, this is the right way for me. Do you have any links to recommend me to set a more specific on my TV?
lapotony is offline
post #16 of 18 Old 04-17-2017, 11:17 AM
Quoted: 166 Post(s)
Liked: 156
All the info you need is already in this thread, directly or via links.
GeorgeAB likes this.
post #17 of 18 Old 04-17-2017, 11:27 AM
GeorgeAB's Avatar
Quoted: 152 Post(s)
Liked: 260
Lightbulb
'Display Calibration: Root Fundamentals'
http://www.avsforum.com/avs-vb/showthread.php?t=1021933
GeorgeAB is offline
post #18 of 18 Old 04-17-2017, 01:21 PM - Thread Starter
Liked: 0
lapotony is offline
Reply Display Calibration
