CMS Calibration With Color Checker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old Today, 08:38 AM - Thread Starter
beardontwalk123's Avatar
Quoted: 949 Post(s)
Liked: 621
I have been curious about the combination of these 2. I have calibrated CMS really well with super low deltaE only to find out something is screwed up in Color Checker. I have also have had really good Color Checker deltaE but CMS wasn't as good. Should Color Checker only be for evaluation or can you calibrated off of it? If CMS is great but Color Checker is off, what would be the best approach? Thanks everyone!
Sent from my SM-N920V using Tapatalk
beardontwalk123 is online now
post #2 of 3 Old Today, 09:05 AM
Quoted: 857 Post(s)
Liked: 560
I think that's a display issue, color tracking needs to be refined. When you check saturation points ( which is what I focus on), then color checker you hope that tracks well.
You remember one of the firmware updates had some color tracking refinements. Other than that, a 3D LUT is next best bet. We have yet to see it available for HDR.
Sent from my 5054N using Tapatalk
DisplayCalNoob is online now
post #3 of 3 Old Today, 11:48 AM
ConnecTEDDD's Avatar
Quoted: 1375 Post(s)
Liked: 1899
When you moving away from the specific points you calibrated and measure different saturation/luminance color levels, you will locate higher errors, the solution to get the less errors at every point you will measure is to move to 3D LUT.
I have posted some info about the difference of 3D LUT vs. Internal display controls calibration there: Sony A1E 4K HDR OLED TV Thread (No Price Talk)
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
Reply Display Calibration
