Does anyone have an alternate white point for 2016 LG OLEDs? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 65Likes
post #61 of 168 Old 07-09-2017, 02:40 AM - Thread Starter
Quoted: 1688 Post(s)
Liked: 728
Originally Posted by D-Nice View Post
Here are offset I've created for 2016 LGs, 2017 LGs and the 2017 Sony A1E
...snip...
2016 LGs: x:0.3039 y:0.3214
That actually worked pretty well on my 65B6. Only thing I did different was use a 25% window pattern. When I used a full screen pattern, I noticed warm/pink ish whites on content that was more like a 25% APL. I'd rather have a rare cyan ish white scene than a very often warm/pink whites on normal content.
One thing I noticed is when you get the color right whether it be in photographic color print processing or display calibration, you get this extra little punch in contrast. I'm seeing that with this alternate white point.
Thanks again Dwayne.
Edit: I should mention that I target a fairly bright peak white which probably explains why 100% on a full screen pattern would need more red that shows up on more normal average picture levels. Might be a good idea to try it Dwayne's way with full screen patterns and if your whites look fine, stop there. If you go for a brighter picture, then using the 25% pattern might work best for you. When I refer to a bright picture as my personal preference, its in the 70s ftl on a 10% sized pattern.
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is offline
post #62 of 168 Old 07-09-2017, 07:48 PM
D-Nice's Avatar
Quoted: 670 Post(s)
Liked: 1467
Glad it worked for you. Yeah, I see why you did 25% with that peak output target. I aim for 30 and 40fL on all TVs here. 30 works well with 100% patterns. 40 is best with 50% patterns.
D-Nice is offline
post #63 of 168 Old 07-10-2017, 09:37 AM
BigCoolJesus's Avatar
Quoted: 1511 Post(s)
Liked: 1197
Jim,
Getting a bunch of new approaches in order when I get home in two weeks to redo my C6 calibrations and found this WP thread.
Attached is a picture of the Target WP/Color Space editor for CalMAN. Do I simply plug in the x and y values D-Nice provided and save it? I don't edit any other values, right?
And after that, I just measure and use the white balance controls on the LG like normal to hit my target gamma curve...as in the new x, y WP values will automatically be calculated into the gamma measurement targets behind the scenes?
Sent from my Pixel XL using Tapatalk
WiFi-Spy likes this.
BigCoolJesus is offline
post #64 of 168 Old 07-10-2017, 09:42 AM
Liked: 1197
D-Nice
For ISF Dark I target 40fl and for ISF Bright I target 60fl at 10% windows.
From your provided input, when I do ISF Dark measurements I should use a 50% window and for ISF Bright I should use a 25% window?
Do you still set max light output at a small window (no ABL) before using a larger window (like 50%)?
post #65 of 168 Old 07-10-2017, 09:57 AM
ConnecTEDDD's Avatar
Quoted: 1568 Post(s)
Liked: 2013
Hi, only enter the new xy of White Point and then save it. After that before starting your measurements select your saved new gamut as target gamut and then do the calibration like you do usually.
Gamma is not related with the target gamut, it's different setting for target gamma.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #66 of 168 Old 07-10-2017, 10:02 AM
Liked: 1197
Got it.
So I entered the x, y WP and noticed it changed the CCT from 6503 to 7093 automatically. And the secondary color x, y targets also changed. That's correct, right?
post #67 of 168 Old 07-10-2017, 10:04 AM
Liked: 2013
Got it.
Yes, it's OK.
post #68 of 168 Old 07-10-2017, 10:09 AM
Liked: 1197
Yes, it's OK.
Ok. Here is a screen shot of the new gamut target after WP entry. Just let me know if it looks OK. Thanks Ted
post #69 of 168 Old 07-10-2017, 10:11 AM
Liked: 2013
All looks fine.
post #70 of 168 Old 07-10-2017, 10:15 AM
Liked: 1197
All looks fine.
One last thing. Should I also edit the WP with the same x, y values for HDR Rec. 2020 gamut target?
post #71 of 168 Old 07-10-2017, 10:35 AM
Liked: 2013
This require some additional check from D-Nice, to see if a perceptual match for D65 REC2020 have agreement with these custom white point coordinates he tested for D65 REC.709.
D65 White Point for REC.709 (BD Movies) Color Space is using: Red 21.27%, Green 71.52%, Blue 7.22% which gives 6504K while...
D65 White Point for REC.2020 (UltraHD Movies) Color Space is using: Red 26.27%, Green 67.80%, Blue 5.93% which gives 6504K also.
post #72 of 168 Old 07-10-2017, 10:37 AM
Liked: 1197
Learning something new everyday. Thanks
post #73 of 168 Old 07-10-2017, 10:43 AM
Liked: 1197
So I'm learning the how, but what causes the why?
As in, I saw the term metameric failure as the reason for the alternative WP but what exactly about the OLED approach is causing this? And what exactly does metameric failure mean? (tried googling but it's a little over my head)
post #74 of 168 Old 07-10-2017, 10:46 AM
D-Nice's Avatar
Quoted: 670 Post(s)
Liked: 1467
D-Nice
Try both, but I recommend 50% patterns for 40fL.
Yes
D-Nice is offline
post #75 of 168 Old 07-10-2017, 10:50 AM
Liked: 2013
D-Nice likes this.
post #76 of 168 Old 07-10-2017, 10:50 AM
Liked: 1197
Yes
Awesome, thanks!
post #77 of 168 Old 07-10-2017, 10:50 AM
D-Nice's Avatar
Quoted: 670 Post(s)
Liked: 1467
Unfortunately, I don't have a reference UHD Monitor here yet. I need to research what they are doing in post houses when it comes to this.
ConnecTEDDD likes this.
D-Nice is offline
post #78 of 168 Old 07-10-2017, 11:12 AM
Liked: 1197
Yes
Forgive my "simple" question but what does using a 50% window offer over a non-ABL initiating window size like 25%?
Im trying to make a connection in my head over the benefit of increasing window size as fL output decreases (you said for 30fL you use 100%) for calibration. The answer is probably fairly simply so don't judge me too harshly for missing it.
Thanks again. I've learned a lot of new tricks to try. Color and Tint for skin tones, Sliding Power for gamma, this new WP offset, and now window size to actually make ABL kick in. But I also like to learn the Why behind these as well.
post #79 of 168 Old 07-10-2017, 11:54 AM
D-Nice's Avatar
Quoted: 670 Post(s)
Liked: 1467
When ABL on the 2016 LGs kicks in, the red channel drops significantly. To counteract the behavior, you calibrate with the ABL active to a degree. Otherwise you will have teal looking whites when 40% or more of the screen is white.
D-Nice is offline
post #80 of 168 Old 07-10-2017, 12:04 PM
Liked: 1197
post #81 of 168 Old 07-10-2017, 12:34 PM
Liked: 1197
Lastly, I'd assume you use the same pattern size for Color and skin tone measurements as well, right? Or does ABL not really factor into those as much?
post #82 of 168 Old 07-10-2017, 02:13 PM
D-Nice's Avatar
Quoted: 670 Post(s)
Liked: 1467
Experiment
D-Nice is offline
post #83 of 168 Old 07-10-2017, 02:28 PM
Liked: 1197
Experiment
Fair enough
post #84 of 168 Old 07-10-2017, 06:54 PM
WiFi-Spy's Avatar
Quoted: 484 Post(s)
Liked: 915
For the UHD HDR related question, next time I'm at a facility that has a Sony X300 + LG I will try to do a perceptual match and post the results here.
T( )( )L likes this.
Tyler Pruitt - Technical Liaison at SpectraCal
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #85 of 168 Old 07-12-2017, 03:52 AM - Thread Starter
Liked: 728
Does this summary look right to you? Anything you'd like to change?
Name:	alternate white point summary.JPG
JimP is offline
post #86 of 168 Old 07-12-2017, 04:47 AM
Overrid3's Avatar
Quoted: 104 Post(s)
Liked: 59
I've been shooting for about 130 nits on mine and have been using the window HCFR patterns. Is that still going to give me a good result? I read that we shouldn't use full-screen patterns on OLED because of the ABL?
Overrid3 is offline
post #87 of 168 Old 07-12-2017, 08:27 AM
Liked: 1197
Tyler,
Any chance you'd have time during the shootout to do the UHD HDR perceptual match since there will be a Sony X300 on hand?
Or @D-Nice if you're there. Wasn't sure if there is downtime to play around with the displays.
post #88 of 168 Old 07-12-2017, 08:28 AM
Liked: 1197
Not that it's necessary to change, but I believe you can go up to 25% windows without any ABL interaction (according to Chad) so the gamma and color measurements don't have to be limited to 10% windows AFAIK.
post #89 of 168 Old 07-13-2017, 05:46 PM
Overrid3's Avatar
Quoted: 104 Post(s)
Liked: 59
I gave the 2016 alternate white point a try on my 2016, but it was asking for a lot more blue than my current calibration. It also needed increased red.
Overrid3 is offline
post #90 of 168 Old 07-13-2017, 06:31 PM
Liked: 1197
Sounds about right
Reply Display Calibration
