HD MPEG-2 Test Patterns - Page 7 - AVS Forum | Home Theater Discussions And Reviews
Old 07-31-2007, 02:27 PM - Thread Starter
dr1394's Avatar
Quoted: 107 Post(s)
Liked: 56
Originally Posted by JohnnyG View Post
Since it's been 4 months since the last time I asked , is there a specific pattern for setting black level? Something with below black or bars just above black?
Try the "needle pulse" pattern.
http://www.w6rz.net/needlepulse.zip
1 and 2 pixel wide pulses ("needle" pulse) with flashing -4, 4, 8, 92, 96 and 104 IRE bars on 0 and 100 IRE background 1920x1080
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
dr1394 is offline
Old 08-01-2007, 01:49 AM
fazzk's Avatar
Thanks for all the files! I have been looking around and could not find any until yours.
I have a request though. I just bought a 32" 720p HDTV and I am hooking up my PS3 via HDMI and Xbox 360 with component. I will have a digital cable box hooked up with normal RF connection. Can you PLEASE tell me which files I need to download and how to get these files on my TV. And then, how to use these files? I would really appreciate it. Thank you.
fazzk is offline
Old 08-02-2007, 02:39 PM
JohnnyG's Avatar
Perfect! Thanks Ron!!
JohnnyG is offline
Old 08-02-2007, 04:56 PM
WTS
WTS's Avatar
Quoted: 37 Post(s)
Hi Johnny,
DO you have the means to turn these ts files into an HD iso? If so do you think you could do up an iso for the allpatterns file?
Walter
WTS is offline
Old 08-03-2007, 08:09 AM
JohnnyG's Avatar
I've converted all the ones I have into plain vanilla MPEG2 files (just via transport stream conversion), so I suppose I can. I can download the .iso from Ron's page and just make the same disc but with plain MPEG2 files. Is this what you're after?
JohnnyG is offline
Old 08-03-2007, 02:29 PM
WTS
WTS's Avatar
Quoted: 37 Post(s)
Hi Johnny,
YEs I have the iso file which is on his site now but it doesn't have the patterns I'm looking for. The patterns I want are in the allpatterns.zip file but these are all .TS files and they need to be put through videredo and moviefactory( I believe) to get them into a HD type iso with menus (just like the iso which someone made with the other files) so I can burn it to a dvd. I can't recall who did the iso on his site, his AVS ID is something like RADA----.
Yes I'd really appreciate if you could turn those into an iso, as I'm sure lots of others would like it too. I'm sure dr1394 would let you put it on his site for all to use.
I don't need it at the moment because I'm going on holidays for 2 weeks.
Walter
WTS is offline
Old 08-09-2007, 11:43 AM
PencilGeek's Avatar
Originally Posted by WTS View Post
Hi Johnny,
If you search the forum (or maybe even this thread), I already did this for BluRay and posted it to my site. I'm pretty sure somebody else did it for HDDVD also. Anyways, hope this helps.
http://www.rcollins.org/ftp/Calibration/
PencilGeek AKQJTs
2006 WSOP Omaha Hi/Lo Tournament: 6th Place
Brillian Discrete IR Codes
PencilGeek is offline
Old 08-14-2007, 04:34 PM
WTS
WTS's Avatar
Quoted: 37 Post(s)
Hi Pencilgeek,
Thanks, I did a search for any thing with allpatterns in the search but didn't come up with anything new. i did download your bluray zip, maybe someday I might have a bluray machine too.
If you wouldn't mind pointing me to where i might fine this iso I would be greatful, thanks.
How hard is it to convert the bluray files over?
Walter
WTS is offline
Old 10-04-2007, 10:06 AM
alluringreality's Avatar
Quoted: 57 Post(s)
Liked: 64
Thanks for the patterns, they've been useful. Is there any chance that you could add a few more for a full grayscale and color calibration? Alternately, could someone maybe give me some idea how I could go about creating correct YCbCr patterns on my own?
As an amateur using HCFR, one major issue is getting a good calibration disk. GetGray is nice for SD, but for HD there's not many choices that I'm aware of besides DVE HD and the few patterns on Sony Blu-rays. Neither of those interfaces well with single spot measurements so I'd like to create a disk that would be easier to use. Your patterns easily seem the best start.
#1 - 75% gray window - In order to make color decoder changes, it would be nice to have a 75% gray to go with the 75% color patterns already on the site.
#2 - 100% color windows (709) - To measure primaries and secondaries, I think 100% color patterns are intended to be used. I can't adjust my primaries so this actually isn't anything I necessarily need myself, but for a full grayscale and color calibration it would be useful.
#3 - Above white window - I'm almost sure that my TV is red limited and always shows above-white. I figure that might be somewhat common for digital displays, so it would be nice to have an above-white pattern to go with the gray patterns for setting grayscale. The shade from the above-white bar in the bars and ramp pattern would probably work.
#4 - Flashing color decoder bar pattern (709) - For Color decoder settings, it would be nice to have a flashing pattern like the color bars pattern you added. A basic idea would be to have red, green, and blue each as a solid bar. Then on top of the bars have gray and the two related secondary colors flash on and off. There are a lot of options for how to do this, but I included a couple pictures for 1/3 of the screen.
Here is a preliminary HD DVD disk of the current grayscale and color relevant patterns. This was merely created for my own use with MovieFactory. The menu RGB images appear to be incorrect, so don't take any measurements from the menu. The only things this might currently be good for is 0% to 100% grayscale windows, and to set color and tint from the flashing bars pattern. Of course if dr1394 has any objections to the file I'll gladly remove it. http://www.sendspace.com/file/9iwytp
alluringreality is offline
Old 10-12-2007, 08:36 PM
HDholic's Avatar
dr1394,
Apparently there is a new "Motion Resolution" pattern used by HD GURU where it measures... obviously motion resolution. I this something that you can recreate?
HDholic is offline
Old 11-12-2007, 01:13 PM
JohnnyG's Avatar
Does anybody know how I could burn these patterns onto a regular DVD discs - in HD format - that would be readable by HD DVD players and Blu-ray players (specifically a PS3)?
I apologize if this info is already in this thread...I've read through it before and don't recall seeing it.
JohnnyG is offline
Old 11-12-2007, 06:05 PM - Thread Starter
dr1394's Avatar
Quoted: 107 Post(s)
Liked: 56
You can burn to HD-DVD fairly easily. See this thread:
http://www.avsforum.com/avs-vb/showthread.php?t=705146
There's a ready to burn .iso file on my site:
http://www.w6rz.net/hdtestpatterns.zip
For Blu-ray, see these threads:
http://www.avsforum.com/avs-vb/showthread.php?t=815296
http://www.avsforum.com/avs-vb/showthread.php?t=790449
Ron
dr1394 is offline
Old 11-13-2007, 07:51 AM
JohnnyG's Avatar
Perfect...thanks, Ron!
JohnnyG is offline
Old 11-13-2007, 08:57 AM
John Mason's Avatar
Quoted: 76 Post(s)
Liked: 103
The article describing the test patterns for the actual magazine-published article mentions converging-line resolution wedges being shifted left and right for the motion portion. Maybe that means rotated left/right. But the results are given for only vertical resolution, AIUI.
Seems that both horizontal (what's generally meant by measured format effective resolution, both static and motion) and vertical resolution are significant.
The video experts approving the ATSC format, table 2.3 (test results), used a rotating test pattern at 5 rpm for motion testing (see Note 3, table 2.3), and reported diagonal resolution readings as well, describing it as the vector sum of horiz. and vertical rez (see 2.1 Resolution intro). There seems to be diagonal wedges in the resolution test pattern used by HD Guru (1st article link above). Some video-processing algorithms manipulate diagonal signal information. This earlier table converts the ATSC committee's table 2.3 to simply lines/PH or PW for 16X9 HDTV, omitting diagonal readings.
AIUI, it's also important to distinguish between Nyquist-limited sampled test patterns (reduced resolution after reconstruction filtering) you'd get from a TV camera or telecine scan, apparently used for ATSC approval testing, and non-sampled computer or test-equipment patterns, which can produce full HD-format resolutions on adequate displays. -- John
John Mason is offline
Old 11-28-2007, 09:35 PM
wackii's Avatar
I've just found out about this thread. Thank you Ron for your hard work. I've downloaded all the test patterns and trying to burn it as an HD format. However, when I try to import the .ts file (video file). I got "filename" is not accessible. I'm using Ulead DVD MovieFactory version 6. Can anyone help me with this? Thanks.
Al,
"When the opponent expand, I contract,
When he contracts, I expand,
And when there is an opportunity,
I do not hit--it hits all by itself."
- Bruce Lee
wackii is offline
Old 11-28-2007, 10:17 PM
Quoted: 57 Post(s)
Liked: 64
I've seen that message with m2ts files and the Ulead software. I would suggest maybe running the files through VideoReDo and making them .mpg and seeing what happens. It's possible the message might go away, but half the time I can't correctly guess what might work and might not work with the Ulead software.
Old 11-28-2007, 11:17 PM
wackii's Avatar
I downloaded VideoReDo the trial version. It also giving me an error when I try to open the .ts file saying "can't open filename, no PIDs specified when trying to open a transport stream". Am I missing something during the installation??? Both softwares said successfully installed. Thanks.
Al,
- Bruce Lee
wackii is offline
Old 11-29-2007, 12:10 AM
Quoted: 57 Post(s)
Liked: 64
Google returns 'If you get this, try enabling the "Ignore Program Stream Map" on the Tools>Options>Stream page.'
You might also be able to re-encode the patterns to something Ulead will accept, but I'm somewhat intentionally out of the loop on going from YUV to video http://www.avsforum.com/avs-vb/showthread.php?t=918654
Old 11-29-2007, 12:18 AM
wackii's Avatar
Thanks. After setting "ignore program stream", it loaded the .ts files using VideoRedo. I'm wondering if Ulead has something like that in the setup. Thanks again.
Al,
- Bruce Lee
wackii is offline
Old 01-23-2008, 10:08 AM
d3z0rian's Avatar
I need the 100IRE Field Pattern in 720p and 1080i res
thank you.
d3z0rian is offline
Old 01-24-2008, 02:36 PM - Thread Starter
dr1394's Avatar
Quoted: 107 Post(s)
Liked: 56
thank you.
There's already a 1080i 100 IRE field pattern.
http://www.w6rz.net/irefield100.zip
I can easily make a 720p pattern. Is the usual 30 seconds okay, or do you want something longer?
I don't have the capability for 480p@60 patterns.
Ron
dr1394 is offline
Old 01-28-2008, 05:37 PM
plughplover's Avatar
I need to present a specific 1080i test pattern ("hoz30bar") to the component inputs of my TV in order for it to do an auto-calibration. The Service manual shows the attached information about the calibration image.
I have a mod'd xbox (with xbmc) and also a PC with an MDP-130 card that I can use to present the image. With xbox+xbmc I could use a still image or mpeg2 file, with the MDP-130 I think it would have to be a transport stream (?)
Any suggestions or pointer to appropriate software?
plughplover is offline
Old 01-30-2008, 12:21 AM - Thread Starter
dr1394's Avatar
Quoted: 107 Post(s)
Liked: 56
Here you go. It's about 4 minutes, 37 seconds long.
http://www.w6rz.net/mitstest.zip
Ron
dr1394 is offline
Old 01-30-2008, 12:23 AM - Thread Starter
dr1394's Avatar
Quoted: 107 Post(s)
Liked: 56
dr1394,
Better late than never. Here's my version of the moving SMPTE 133 pattern (like on the HD HQV disc).
http://www.w6rz.net/filmrez.zip
Ron
dr1394 is offline
Old 01-30-2008, 05:48 AM
Ron
Thanks! I'll give it a whirl...
Old 01-31-2008, 12:29 AM
SpHeRe31459's Avatar
Quoted: 16 Post(s)
Ron
Good stuff :-)
Could you also do one with 3:2 pulldown? the HD HQV disc has the SMPTE pattern at 1080i/30 and 1080i/30 with 3:2, so it would be awesome to have this as an alternative test.
SpHeRe31459 is offline
Old 01-31-2008, 02:00 AM - Thread Starter
dr1394's Avatar
Quoted: 107 Post(s)
Liked: 56
Originally Posted by SpHeRe31459 View Post
Good stuff :-)
This pattern does have 3:2 pulldown. Here's a progressive frame:
and an interlaced frame:
If you see any of the interlaced artifacts on your panel, it's having trouble with 3:2 detection. Some panels will do well on most of the image, but fail on the edges of the some of the boxes.
Ron
dr1394 is offline
Old 01-31-2008, 03:07 AM
trbarry's Avatar
Ron -
The squares with finest vertical lines turn redish on my LCD. Do you know what that is?
- Tom
Why don't we power our electric cars from greener, cheaper Liquid Fluoride Thorium Reactors?
Tom Barry - Find my video filters at www.trbarry.com
trbarry is offline
Old 01-31-2008, 07:11 PM
WTS
WTS's Avatar
Quoted: 37 Post(s)
Hmmm, all I see on my monitor is 2 black pics.
Walter
WTS is offline
Old 02-01-2008, 02:58 AM - Thread Starter
dr1394's Avatar
Quoted: 107 Post(s)
Liked: 56
Looks like my server (www.w6rz.net) is down. The pictures are linked to that server.
Ron
dr1394 is offline
