projector cal. help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-28-2005, 05:09 PM - Thread Starter
paulp1's Avatar
How would I go about calibrating a Runco Projector myself. I would like to find out how certain adjustments are intended to adjust the picture. Any help would be deeply appreciated.
65" Mits.RPTV
Runco Proj.
Yamaha RX-Z9
Yamaha S2500DVD
Martin Logan Aieon-i
Klipsch RC7
Polk RTi6 Side
Klipsch KSP-S6 Dipole rear
SVS PC-46
paulp1 is offline
post #2 of 3 Old 09-28-2005, 06:02 PM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
Depends on what you want to adjust. Runco digital projectors can typically adjust the grayscale in the service menu. Contact Runco for the Access codes.
Regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #3 of 3 Old 09-29-2005, 03:26 AM - Thread Starter
paulp1's Avatar
Originally Posted by Michael TLV
Greetings
Regards
I want to adjust gray scale & color. Some of the settings aren't what I am use to such as what des "White" do? What does "filter" do? What color temp are the different settings suppose to be. I think their are 4 of them and I can't find out which one is 6400K etc. These are all in the user menu.
65" Mits.RPTV
Runco Proj.
Yamaha RX-Z9
Yamaha S2500DVD
Klipsch RC7
Polk RTi6 Side
SVS PC-46
paulp1 is offline
Closed Thread Display Calibration
