Hi All,
I am Kevin Miller and my company is ISFTV. My contact information is listed below:
Kevin Miller
ISFTV
Phone: 718-274-0236
Email:
kevin@ISFTV.COM
Web Site:
www.ISFTV.COM
Founding Imaging Science Foundation Member since 1994
Industry Consultant ~ ISF Instructor
Contributing Editor to CNET.COM & The Perfect Vision
I have been calibrating in the New York Tri-State area since February 1994 when the ISF was first formed. I have been a co-instructor of the ISF seminars for the last five years.
I have extensive experience with all display types and all makes and models of HDTVs. I am also a consultant to some of the major TV manufacturers including Samsung, Sharp, Runco International and others. My equipment arsenal is state-of-the-art and includes the following:
Equipment Used: We are constantly upgrading our arsenal of test equipment, which includes:
New Gear: The Minolta CS-200 is designed to measure luminance, chromaticity, gamma and contrast of light emitting products, such as large flat panel and plasma displays, compact LCD's and OLED's, outdoor screens, high pressure lamps and instrument panels. In short, it can accurately read any type of display device. The CS-200 has 40 high accuracy sensors to calculate spectral response where as most color analyzers have only 3; 3 selectable measuring angles, and measurement speed as low as 0.5 seconds. The CS200 was tested against several Photo Research PR650 Spectraradiometers by Joe Kane of JKP and found to be just as accurate, and perhaps more accurate than the PR650 below 1.5 Footlamberts.
Sencore Color Pro 5000: This laptop software based meter has been developed mainly for the new fixed pixel displays like DLP, Plasma, and new forms of LCD like LCOS, because fixed pixel displays often have much different color space and gamma than traditional CRT based displays. This means old fashioned tri-stimulous meters like our trusty old Philips won't do the job as accurately as desired.
The Sencore 5000 has been compared to the industry standard calibration device, the Photo Research PR 650 Spectraradiometer on several occassions with many different types of displays, and has been proven to be as accurate if not more so than the Photo Research.
Sencore VP403 HDTV/SDTV signal generator with DVI Output and ATSC RF Output. The VP403 is the industry standard signal generator primarily because of its ATSC RF out, which allows us to go into an off-air or Satellite HDTV receiver's antenna input, and keep the set-top box in the signal flow making for much more accurate HDTV source calibrations.
Sencore CP5000 Color Analyzer
Philips Color Analyzer
Sencore CP288 Color Analyzer
The Visual Standard Optical Comparator
Accupel HDTV (720p, 1080i) HDTV signal generator
Sencore VP403 (480i/p, 720p, 1080i, 1080p NTSC and PAL) signal generator
