display mate- how does this differ from calibration disks and has anyone used it?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-09-2005, 08:11 AM - Thread Starter
lkosova's Avatar
HI,
has anyone used this ISF approved product for calibrating displays of all types and how does this differ from using a dvd essentials disk or the like besides price???
http://www.displaymate.com/isf/index.html
Can this program be used with the likes of Spyder or Eyeone color meters???
Larry
lkosova is offline
post #2 of 4 Old 10-09-2005, 08:48 AM
Super Moderator
markrubin's Avatar
Quoted: 1036 Post(s)
Liked: 2273
many use DisplayMate as a standard
biggest difference is this is a PC based program: not a DVD you can pop in your DVD player
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #3 of 4 Old 10-09-2005, 09:11 AM - Thread Starter
lkosova's Avatar
Thanks Marc,
Just seems to be more logical then dvd type of systems and does gray scale....
Larry
lkosova is offline
post #4 of 4 Old 10-09-2005, 09:52 AM
Vern Dias's Avatar
I use displaymate video edition extensively for things like setting grey scale, checking resolution, focus, convergence and many more. You have to be a little careful, because it outputs at PC levels of 0-255, not video levels of 16-235.
Vern
Vern Dias is offline
Closed Thread Display Calibration
