What's a good calibration DVD? - AVS Forum | Home Theater Discussions And Reviews
Old 10-09-2005, 10:22 AM - Thread Starter
hd_rookie's Avatar
I just bought a new TV and have been told that they need to be calibrated? If so, which disc do you recomend?
hd_rookie is offline
Old 10-09-2005, 10:31 AM
arad's Avatar
We use Digital Video Essentials (http://www.videoessentials.com)
Ara
arad is offline
Old 10-09-2005, 10:32 AM
ChrisWiggles's Avatar
DVE or Avia. I like Avia in terms of user friendliness. DVE has patterns from 1-254, which can be helpful in system testing for more advanced users.
ChrisWiggles is offline
Old 10-09-2005, 11:39 AM
Tyson Jordan's Avatar
For DIY purposes I too would recommend either DVE or Avia. I also agree that Avia is a little more user friendly. To get the most out of your display though, I would encourage you to get it professionally calibrated. It is unlikely that you would be able to achieve the same level of PQ as an ISF certified calibrator. I know from personal experience that training makes all the difference. Here's how to find one near you. Go to imagingscience.com and use the dealer/tech locator for your state. Happy viewing!
Re:Calibration
It may not always be bright, but it is never wrong!
Tyson Jordan is offline
