scrolling horizontal lines on screen....interference? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-09-2005, 05:46 PM - Thread Starter
Hypo_Luxa's Avatar
Need a bit of input on this one. I have a Benq projector being fed by both an htpc and a stand alone DVD player. Both are running through a vga switch and vga amplifier, the dvd player is connected via a component to VGA cable while the htpc is strictly VGA. With the standalone DVD player I am getting barely visible horizontal lines that move slowly up the screen every few seconds. With the PC I am getting the same thing only it is refresh rate dependant. At 60hz it's very visible, at 100hz it's barely visible but still there. Either way the lines from the htpc scroll alot faster than with the DVD player. Is this some sort of electrical interference problem? Any help is appreciated.
Hypo_Luxa is offline
post #2 of 5 Old 10-09-2005, 06:29 PM
Super Moderator
markrubin's Avatar
Quoted: 1036 Post(s)
Liked: 2273
probably a ground loop:
do a seach for this topic and you will find a lot of info
please take the high road in every post:do not respond to or quote a problematic post: report it
HDMI.org:what a mess
HDCP = Hollywood's Draconian Copy Protection system
markrubin is offline
post #3 of 5 Old 10-09-2005, 06:39 PM
Sirquack's Avatar
Is this an LCD BenQ, probably not, but if so, it might be vertical banding.
___________
"Don't worry about the future, it is already tomorrow in Australia..."
My Website
Sirquack is offline
post #4 of 5 Old 10-09-2005, 08:40 PM
ChrisWiggles's Avatar
No, Verticalbanding is a fixed vertical texturing that you can see on LCDs, not scrolling horizontal lines.
Sounds like a ground loop, because of the 60hz remark which is the freq of AC.
ChrisWiggles is offline
post #5 of 5 Old 10-09-2005, 08:56 PM - Thread Starter
Hypo_Luxa's Avatar
Well, I found the source of the problem (sort of). I have a PVR-150 card in the computer and I found as soon as I disconnected the coax, the lines went away. I'll have to see if I can localize it any further but at least I can watch movies without being distracted now. :) Thanks for the assistance!
Closed Thread Display Calibration
