Service Menus Sticky: AVS official thread: Cautions - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
Old 11-30-2005, 09:59 AM
mhollinger's Avatar
Good day, Could someone PM the service menu for a Magnavox 42MF230A/37 plasma?
~ Mike
mhollinger is offline
Old 11-30-2005, 10:05 AM
cbyrdjr's Avatar
Could someone PM the service menu for a Panasonic PT-44LCX65?
cbyrdjr is offline
Old 11-30-2005, 11:58 AM
pdiscool's Avatar
Hello can someone please give me the service code for a samsung 27 inch hdtv tantus TXN2798HF. My screen has some bad overscanning, where in 480p the left and right side are cut off a little. Does anyone know here if the service menu can fix this? If so can you please pm me the service code and some helpful advice if ya have any ;) Thanks in Advance
pdiscool is offline
Old 11-30-2005, 03:55 PM
HoustonPerson's Avatar
I need the current service menus on Samsung DLPs - HL R4266W and HL R5668W. Also, is pincushion adjustable on these sets?
HoustonPerson is offline
Old 11-30-2005, 04:54 PM
Darren Wadsworth's Avatar
Looking for service code for the Infocus 4805?
If so, please PM me.
Thank you
Darren
Darren Wadsworth is offline
Old 11-30-2005, 05:59 PM
williampzt's Avatar
Looking for the service menu for the Olevia LT26HVX. Any help would be appreciated. Please PM the magic codes... :)
williampzt is offline
Old 12-01-2005, 01:46 AM
bdspilot's Avatar
Need Service menu info for pioneer 5050
bdspilot is offline
Old 12-01-2005, 11:41 AM
redshirt's Avatar
Hi,
Where can I get a copy of the service manual for the Mitsubishi WD-62725?
redshirt is offline
Old 12-01-2005, 12:40 PM
DaveRochNY's Avatar
I'd like to get the Service Mode entry codes for a Akai PDP-4295, which is different from a 4294 & the Panasonic version of the 4294.
Tx,
Dave
DaveRochNY is offline
Old 12-01-2005, 06:36 PM
KindredWarr's Avatar
Hi, I'm a bit of a noob in the forum, so I hope i'm doing this right.
I'd like the service menu for the Sony KV-34HS510 and info on how to get a hold of the service manual for it, if posisble.
KindredWarr is offline
Old 12-01-2005, 07:07 PM
darkl4805's Avatar
I am looking for the Service Menu for the Syntax Olevia LT26HVX if someone could PM me on this, thanks.
darkl4805 is offline
Old 12-01-2005, 07:25 PM
Wakey's Avatar
If anyone has Service menu info for the Sony KP53HS30 RPTV I would appreciate it!
(edit) I found them, if anyone needs it PM me :D
Wakey is offline
Old 12-01-2005, 09:13 PM
gozu's Avatar
I'd like the service menu instructions for the 51HC85 . Please PM me.
gozu is offline
Old 12-01-2005, 10:23 PM
protomech's Avatar
I also would like to get my hands on (via PM or otherwise) the service menu on a panasonic CT-26WX15 .. need to correct some overscan and geometry issues.
protomech is offline
Old 12-02-2005, 09:45 AM
Mbai2's Avatar
Would someone PM the instructions to get the service menu for the Olevia LT37HVS?
Mbai2 is offline
Old 12-02-2005, 12:29 PM
RedFive99's Avatar
I would love to get any and all information regarding the service menus on my Sony KV-30HS420 HDTV. Spreadsheets, guides, lists of codes, explinations... anything that might help.
Thank you!
RedFive99 is offline
Old 12-02-2005, 01:58 PM
bnwbass's Avatar
I'm looking for the service menu codes for the Samsung HLR-4667W...please PM if you have it, thanks!
bnwbass is offline
Old 12-02-2005, 08:05 PM
natboy's Avatar
Can someone send me the service menu code for a Mitsubishi WS-A48, and while your at a Westinghouse LTV-32W1 as well.
natboy is offline
Old 12-02-2005, 10:09 PM
matheue's Avatar
can some one PM me the service code for Ph 32pf7320A
thanks in advance
matheue is offline
Old 12-03-2005, 03:45 AM
g4sho's Avatar
Quoted: 17 Post(s)
I would like the service menu code for a Maxent Mx-50x3. I am aware of the rs232 connection and have used it. Are there any undocumented commands for this? Or maybe an advanced command set? Any help would be appreciated.
LG OLED65C6P,PIONEER KURO 6010, EMOTIVA XMC-1,OPPO 93,OPPO UDP-203,XBOX ONE S,AUDIO TECHNICA TURNTABLE, RYHTHMIC FV15HP, HSU VTF-2MK
MIRAGE OMD-15,MIRAGE OMD-5, ENERGY TOWERS AND CENTER CHANNEL
2 CARVIN AND 1 CROWN POWER AMP
g4sho is offline
Old 12-03-2005, 12:07 PM
m99
m99's Avatar
Can someone PM me the service code for Samsung LE27T51B
Thx
m99 is offline
Old 12-03-2005, 12:43 PM
Sn00tch's Avatar
Looking for service codes for a Panasonic CT-26WX15. If you have them and could PM me, that'd be great :)
Sn00tch is offline
Old 12-03-2005, 02:57 PM
railcs's Avatar
philips 37 inch lcd (37pf7320a/37)
anyone know how to enter its service menu?
pm please and thanks
railcs is offline
Old 12-04-2005, 10:22 AM
cecide's Avatar
I would also like the service menu codes for the 51HC85. Thanks.
gamertag: cecide
cecide is offline
Old 12-04-2005, 01:21 PM
prthealien's Avatar
I need to know where I can get the service manual for a Samsung TX-P2670WH. I know the code to get to the menu, but I need the service manual. Any help is greatly appreciated.
prthealien is offline
Old 12-04-2005, 05:08 PM
bdspilot's Avatar
Help! Need Service menu info for pioneer 5050
bdspilot is offline
Old 12-04-2005, 09:10 PM
BruZZi's Avatar
Just curious...
Are you guys getting any answer ???
Check Out the all-new BruZZi's Panasonic Plasma FAQ
The FAQ plus links to Plasma Stands, Wallmounts, Murals, Lifts, Speakers, Frames, Bezels & More.
Also links to Audio/Video Faqs, Comparisons, News, Reviews, Shootouts, Tutorials, Tweaks & Many More.
__________________________________________________ _
Samsung 55KS800 • Pioneer Elite VSX-90TXV • Oppo BDP-103D
Paradigm Studio 10's • Paradigm Studio CC-490 • Sunfire HRS-8
BruZZi is offline
Old 12-04-2005, 10:10 PM
t_tringle's Avatar
Quoted: 60 Post(s)
Liked: 63
Hi,
I need the procedure for entering the service menu on a toshiba 51h85c CRT RP.
TimT
"This is my BOOMSTICK!!!"
Ash, AOD
t_tringle is offline
Old 12-05-2005, 10:38 AM
xm_92620's Avatar
Does anyone know how to remove the base of Samsung HLR 6167 DLP TV?
xm_92620 is offline
Old 12-05-2005, 03:38 PM
Septura's Avatar
Please PM me the service menu for the Insignia IS-TV040925 or another Insignia crt model I can try. I need to fix the overscan.
Septura is offline
Samsung Pn64f8500 64 Inch 3d Smart Plasma Hdtv
