Ursa's "Guide to Basic Display Calibration for New Users" - a MUST read!! - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 63 Old 01-26-2006, 08:17 AM
Ursa's Avatar
Originally Posted by lkosova View Post
Ursa,
What a great job....this should be a sticky!!! How do you make that happen??
Larry
Larry - Thanks! Actually, it sort of is a sticky, but the calibration FAQ thread does miss the discussion here.
Later,
Bill
Ursa is offline
post #32 of 63 Old 01-26-2006, 09:12 AM
SightSeeker1's Avatar
Quoted: 16 Post(s)
Hello, I just read your write up and had a couple questions. I'm just getting started with this and have been doing some of what you said on my own with the THX disk. I have been adjusting the cuts and drives dialing in a way better picture. I have a RPTV and should I be starting with the main contrast and brightness at 50% or at least should they both be matching? What about the cool, standard, warm?
About the gamma I can't really do anything with that without some sort of meter can I? When making adjustments to that I can't tell what is happening. My sets values are in hexadecimal and when increasing I see the light going up but then it jumps back down again and vise versa.
I really like the colors right now but the gamma is still eluding me on what it is set on. Does it go to a certain point then reset even though you keep increasing the value?
SightSeeker1 is offline
post #33 of 63 Old 01-26-2006, 09:51 AM
Ursa's Avatar
Grab AVIA, DVE or GetGray to find the patterns you need to properly set contrast and balance. Chris Wiggles has a write-up that gives a pretty good summary of what you need to do here. Check the calibration FAQ (sticky) for more info.
For this, you will need to find someone who has your set to give you the appropriate settings (preferrably after a full calibration), or a measurement instrument.
Each display has its own quirks when it comes to various controls, and you do need a meter (or a pro with one) to really see what some of the more advanced controls are doing. If I understand what you are saying, it definitely sounds like your set is "weird" to put it technically.
Later,
Bill
Ursa is offline
post #34 of 63 Old 01-26-2006, 09:56 AM
lkosova's Avatar
Bill,
I made the comments "before" I read the thing. Man, Bill....you have such a great way of explaining a very dry topic. You actually made if funny and interesting!!!!!
You should contact datavision and write the guides or have them pay you for this guide.
If you come out with a book or longer guide I would be more then happy to pay for it. It really cleared up somethings and yes I will most likely have some questions in the future.
You really did do a great job with this....
Just to let you know....this Calibration forum has some of the most helpful and nicest people in all the AVS forums etc. I can't tell you how many people go out of their way to help even thoughs with competing software and hardware etc......you all know who you are and I am very greatful.
Larry
lkosova is offline
post #35 of 63 Old 01-26-2006, 10:29 AM
Quoted: 16 Post(s)
Thanks man. I just bought the DVE at Overstock. Can't wait until it gets here. I love this site. I look on the web for a reason my TV has the later defined to me as "Red Push" and end up getting a better picture out of my TV than I ever could of without running into the forum......
And ended up with a brand new 5.1 system as well
post #36 of 63 Old 04-01-2006, 10:09 AM
Jeremy Duncan's Avatar
Thank you for the link.
Jeremy Duncan is offline
post #37 of 63 Old 07-23-2006, 10:49 PM
tyf
tyf's Avatar
Hi Bill, I've tried to down your "Guide to Basic Display Callibration for New Users" but seems to hit some problems with "Damaged file". Can you point me to another link for download?
tyf is offline
post #38 of 63 Old 07-24-2006, 07:59 AM
Bear5k's Avatar
Try my website, www.calman.tv. It will be in the "Is CalMAN right for me?" section.
Bill
Color accuracy evangelist and CalMAN insider
Bear5k is offline
post #39 of 63 Old 07-24-2006, 11:26 PM
tyf
tyf's Avatar
Hi Bill, thanks. Got it.
tyf is offline
post #40 of 63 Old 08-02-2006, 07:39 AM
HDMC's Avatar
This is truly an amazing document. Great work
When calibrating grayscale where should you place the spyder2 sensor?
1. Near the screen aiming the screen;
2. Near the screen aiming the projector;
3. Near the projector
Colorfacts recommends option 1 with the spyder2 colorimeter but I think it reduces the sensor accuracy at low IRE levels. On the other hand aiming at the projector, disregards the offset (if any) produced by the screen surface (but suffers from less contaminations produced by ambient light???).
So, which method is better for the spyder2 sensor?
NS
HDMC is offline
post #41 of 63 Old 08-03-2006, 01:09 AM
Bear5k's Avatar
1 & 3 are your best bets for FP use, and it depends upon what software, etc., you are using as to what makes sense. #1 is the technically accurate method, but suffers at low stimulus levels from a lack of photons to make the measurements work. #3 ignores the screen, so that can be especially irritating for folks using non-matte white screens. I hate to say it, but there really is not a "good" answer that works for all people in all cases. My guess is that most professionals use a screen offset and measure direct.
Later,
Bill
Bear5k is offline
post #42 of 63 Old 08-03-2006, 02:09 AM
HDMC's Avatar
Later,
Bill
Thanks for the answer, Bill.
When you say that "most professionals use the screen offset and measure direct" does this mean they take readings from the screen and then do the calibration with the sensor near the projector (#3) or near the screen (#2)?
How do you determine the offset? Is it enough one IRE window or field (eg 80IRE) and use the difference in x and y between the two measurements and apply to all readings?
NS
HDMC is offline
post #43 of 63 Old 08-03-2006, 06:30 AM
Bear5k's Avatar
This depends upon the individual calibrator and the projector in question. A Sony Ruby would require the meter be reasonably close to the projector. My Optoma H77 on a fresh bulb has a black level that is easily measured at my screen. In other words, it depends.
That is the way it is typically done.
Bill
Bear5k is offline
post #44 of 63 Old 08-03-2006, 08:13 AM
Victor's Avatar
Quoted: 21 Post(s)
NS
Spyder has very bad accuracy for measurment at low light levels. IMHO, using (1) at low IRE values you'll get almost useless data.
Try to measure more then one time and you'll se that every measurement will yield different results from previous ones.
Victor is offline
post #45 of 63 Old 08-03-2006, 11:12 AM
Bear5k's Avatar
You get a lot better stability with its measurements if you increase the read time. However, discussing the merits of the Spyder2 is off-topic for this thread.
Bear5k is offline
post #46 of 63 Old 08-04-2006, 04:50 AM
HDMC's Avatar
Thank you for your inputs. Based on your experience, which minimum requirements in fL would be necessary for acurate readings?
NS
HDMC is offline
post #47 of 63 Old 08-04-2006, 08:38 AM
Bear5k's Avatar
NS
This also is probably deserving of its own thread (or we can resurrect one from the past). I get fairly stable results using a 9 second read time down to about 0.2 cd/m^2 or about 0.07 ftL. If you go below that, you will want to increase the read time.
Bear5k is offline
post #48 of 63 Old 03-19-2007, 09:27 AM
spongebob's Avatar
Quoted: 76 Post(s)
Difference, please?
thx
bob
spongebob is offline
post #49 of 63 Old 03-19-2007, 11:29 AM
richlo's Avatar
Originally Posted by spongebob View Post
Difference, please?
thx
bob
Easy..
Think of it this way..
You can have Green tracking 6500K, then you can have Blue tracking 7500K and then have Red tracking at 5500K, the average of the 3 is 6500K..
Instead you want all three to track to it, so the coordinates will be x=.3129 and y = .329, this equals D65
ultimately, there are many ways to get to 6500K, there is only ONE way to get D65 (which will also get you to 6500K)
Rich L
Go Chicago Bears
richlo is offline
post #50 of 63 Old 03-19-2007, 01:23 PM
spongebob's Avatar
Quoted: 76 Post(s)
Originally Posted by richlo View Post
Easy..
Does the HCFR software use D65? That, and the DisplayLT(sp) sensor is what I will be attempting to calibrate my new Panny 9UK plasma with.
thx
bob
post #51 of 63 Old 03-19-2007, 02:38 PM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
thx
bob
yes, you can set HCFR to target D65 as well as other standard illuminants.
zoyd is offline
post #52 of 63 Old 03-20-2007, 07:53 AM
Bear5k's Avatar
The question is whether the HCFR folks appropriately adjust the XYZ->RGB conversion matrices when using something other than D65. If they do not, then they are introducing error.
Bear5k is offline
post #53 of 63 Old 05-18-2008, 02:40 AM
rrwhitfield's Avatar
I have spydertv and I have windows vista, I cannot access the secret /support menu with vista how do i overcome this
rrwhitfield is offline
post #54 of 63 Old 05-18-2008, 02:40 AM
post #55 of 63 Old 05-20-2008, 07:31 AM
Bear5k's Avatar
With the software available today, why would you want to do so?
Bear5k is offline
post #56 of 63 Old 06-05-2013, 05:48 AM
K1lgoreTr0ut's Avatar
Hi,
sorry if I am just too dumb to use a computer but to me it looks like the link to the PDF in the initial is no longer working. It takes me to the AVForums homepage.
K1lgoreTr0ut is offline
post #57 of 63 Old 06-05-2013, 06:21 AM
airscapes's Avatar
Quoted: 371 Post(s)
Liked: 297
Originally Posted by K1lgoreTr0ut View Post
Hi,
The link is no longer valid, this thread was started in 2005... Top left of each post has the date..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #58 of 63 Old 06-06-2013, 02:57 PM
hungro's Avatar
Quoted: 169 Post(s)
Liked: 114
Watching the brightness pattern video, I love how the voice announcer worded it "friends don't let friends crush blacks" I had a good laugh.
hungro is offline
post #59 of 63 Old 06-08-2013, 09:48 PM
spacediver's Avatar
Quoted: 172 Post(s)
Liked: 85
found a working link to Ursa's pdf here:
http://www.avsforum.com/attachments/22555
not sure if it's the same tutorial mentioned in the thread title.
spacediver is offline
post #60 of 63 Old 06-09-2013, 06:01 AM
T3b_vat's Avatar
T3b_vat is online now
Reply Display Calibration
