Service Menu Access Codes : Official Request Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #271 of 1574 Old 09-27-2006, 07:12 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 3400 Post(s)
Liked: 2654
Originally Posted by Chandu1 View Post
I haven't gotten to this yet. I plan to do basic calibration with SpyderTV later next week. When I find time for advanced grayscale calibration, I'll be looking into this. I hope to make an update by end of next week.
Have you had any luck with the Westinghouse LVM-37w3? The service menu code for the 42 does not work on my 37, and I'd also like to find a service manual.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #272 of 1574 Old 09-29-2006, 05:47 PM
YeuEmMaiMai's Avatar
I would like a service menu code for a Viewsonic 32" LCD with HDTV tuner 3152 is the set model
EDIT: Found it
For the ViewSonic N3251W you need to be in the service menu and then you press
100/- 9 9 1 and the "service" menu will come up. To exit menu press menu. The menu will remain active until you power down the set. (each time you press menu you will be back in the service menu)
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
post #273 of 1574 Old 09-29-2006, 07:07 PM
rodiddy's Avatar
I've looked through the posted Samsung button strokes and none of them work on this TV. Can somebody -- anybody please help, this convergence is driving me insane.
RO
rodiddy is offline
post #274 of 1574 Old 09-30-2006, 01:47 AM
Chandu1's Avatar
-Bill
I apologize to everyone, but I never found the bandwidth to look into this. I did some basic calibration with SpyderTV and the GetGray disk and that's it. I have no bandwidth anymore to look into service menu unfortunately, and I'm quite happy with the level of calibration I've achieved for now.
Once again, sorry for getting hopes high.
Chandu1 is offline
post #275 of 1574 Old 09-30-2006, 09:26 PM
xfeastonarsex's Avatar
Im looking for the service menu code for the Westinghouse LVM-42W2
xfeastonarsex is offline
post #276 of 1574 Old 10-01-2006, 06:11 AM
wmcclain's Avatar
Liked: 2654
I believe this works for the 42, but I don't have one:
http://www.bruzzi.ws/plasma-faq/showthread.php?t=192
It doesn't work for the 37w3.
-Bill
post #277 of 1574 Old 10-03-2006, 10:25 AM
ianchan1970's Avatar
Thanks Bruzzi!
I found the code for my old Toshiba 27A34, and cal'd it.
Distortion is now lower and color temperature is much better.
- Ian
ianchan1970 is offline
post #278 of 1574 Old 10-07-2006, 02:55 PM
gpdlt's Avatar
I have a viewsonic 42"LCD model n4200w, it has no built in tuner so the 99-1 for entering into the service mode did not work, any one that could help me with this?
Thanks in advance!!
gpdlt.
gpdlt is offline
post #279 of 1574 Old 10-12-2006, 04:42 PM
Pharados's Avatar
hi does anyone have more information for the service mode ?
have some information regarding the normal service mode by accesing it via mute on the remote and menu on the tv set.
i also have access to the the extended menu set
while in the service mode press and hold menu on the remote and then menu on the tv set now it's possibe to scoll through 0000h to 3FFFh adresses of register information.
i looking for the overscan and geometry settings for the display.
Pharados is offline
post #280 of 1574 Old 10-13-2006, 03:36 PM
KJkos's Avatar
Any chance someone here knows the service menu code for a Infocu SP777.
Thanx for the help
We're not satisfied until you're not satisfied. :)
KJkos is offline
post #281 of 1574 Old 10-14-2006, 11:46 PM
Lynne's Avatar
Does anyone know the code for the prima ht-3461? I've tried the one listed by Bruzzi and it doesn't seem to work for this model.
Thank you
Lynne is offline
post #282 of 1574 Old 10-15-2006, 11:33 PM
Ev01vEd's Avatar
Is there any information for a Dell W3201C ?
Ev01vEd is offline
post #283 of 1574 Old 10-25-2006, 12:15 AM
vasvir's Avatar
Halo,
Does anybody know how to access the service menu in Toshiba DLP MT400? If you happen to know the sequence for MT200/MT500 please let me know (PM) so I can try them also. MT700 sequence is known and is not applicable to MT400.
Also if you happen to know the extended set of RS232 commands please let me know since I have managed to build the control cable. I am planning to post the details of this in the DIY forum.
The local representatives were not cooperative at all.
vasvir is offline
post #284 of 1574 Old 10-25-2006, 03:37 PM
Derrickla's Avatar
Could someone PM me the SM access codes/procedure for the Sony KDS-50A2000? Could not get the ones from BruZZi's to work. Thanks!
Derrickla is offline
post #285 of 1574 Old 10-25-2006, 09:40 PM
RiPPn's Avatar
RiPPn is offline
post #286 of 1574 Old 10-26-2006, 10:41 PM
epsilon72's Avatar
I am as well.
epsilon72 is offline
post #287 of 1574 Old 10-31-2006, 10:19 AM
rkthor's Avatar
Hi: Does anyone know the how to get into the service menu for an Infocus LP755? I could sure use the help.
rkthor is offline
post #288 of 1574 Old 10-31-2006, 04:17 PM
BHB
BHB's Avatar
BruZZi I need help, I have a vizio L32 and I need to fix the over crop on it...and the service code provided does not work.
BHB is offline
post #289 of 1574 Old 10-31-2006, 07:29 PM
stoneag's Avatar
Originally Posted by epsilon72 View Post
I am as well.
Check the thread in the lcd display forum and do a search in there. It's 150+ pages but a search should narrow it down to a few.
If I remember correctly... hold the input and volume - buttons at the same time with the power off and while holding them, turn the power on. You have to be feeding the monitor a signal (i.e. the DVD player has to be on, or the STB has to be on). This will start the westinghouse logo flashing and you should be able to adjust your menu settings there. Once you are done, enter the regular user menu and do a full reset.
This is from memory, so I highly suggest that you go to the thread for the full instructions
-Samsung LN-T4661FX/XAA VERSION:SX07
MODULE: T-TULPAUSC-1019, DATE:
MICOM: T-TULPAUSS-1011, ACL: T-TULPAUSG-1009
KERNEL:
-MARANTZ SR4002
-ACOUSTIC ENERGY AEGIS SYSTEM
-SONY PS3
stoneag is offline
post #290 of 1574 Old 11-01-2006, 05:38 PM
jman069's Avatar
Quoted: 29 Post(s)
Hello,
Anyone PM me for the service menu code for the SONY KDL-46XBR2/3
J
jman069 is offline
post #291 of 1574 Old 11-02-2006, 08:24 AM
RipcordAFF's Avatar
Can anyone please please please please please pm me or post the service menu code for the Niko 32" lcd (OTP-3211W) I have been looking for it for months and cant find it. Thank you so very much!
RipcordAFF is offline
post #292 of 1574 Old 11-02-2006, 11:46 AM
thecodeman's Avatar
Can someone help me out with codes to further calibrate my Sony KD34XBR960?
thecodeman is online now
post #293 of 1574 Old 11-03-2006, 09:32 PM
Mr Pink57's Avatar
Can someone PM me the service code for the Westinghouse LTV-32w6.
pink
[rubbing his thumb and forefinger together]
Mr. Pink : Do you know what this is? Its the world's smallest violin playing just for the waitresses.
Mr Pink57 is offline
post #294 of 1574 Old 11-04-2006, 11:14 AM
danoo1's Avatar
can i get the service access code for the pioneer 4214
danoo1 is offline
post #295 of 1574 Old 11-04-2006, 08:54 PM
folsomparty's Avatar
service access code for lg ru-52sz51d. Thanks!!!!
folsomparty is offline
post #296 of 1574 Old 11-05-2006, 03:42 AM
noobtuber's Avatar
Service menu access code for Sharp 37d90u, please.
TIA!
noobtuber is offline
post #297 of 1574 Old 11-05-2006, 07:53 AM
ACQUA's Avatar
I'm new here from Belgium and i just bought an LG 32LC2R, Can anyone help me to acces the service menu on this LCD? Problems with green and red shadows on subtitles.
ACQUA is offline
post #298 of 1574 Old 11-05-2006, 10:46 AM
rdjam's Avatar
Hi all,
I don't know if this has been asked yet (I scanned a few pages back to check) so forgive me if it has.
This Samsung LCD has an overscan issue on HDMI input. Is there any setting in the Service Menu which can disable this overscanning so that I can have 1:1 pixel mapping?
I wanted to check here before I entered the menu.
Thanks for any help anyone can give!
rdjam is offline
post #299 of 1574 Old 11-07-2006, 11:47 PM
dckev's Avatar
Please PM me the service menu access code for a Sharp LC-32D40U. Thanks!
dckev is offline
post #300 of 1574 Old 11-08-2006, 07:09 AM
mrplows's Avatar
Im looking for the service menu code for the Westinghouse LVM-47W1
mrplows is offline
Reply Display Calibration
Sharp Aquos , Sharp Quattron Tv
