Service Menu Access Codes : Official Request Thread - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #631 of 1505 Old 02-01-2008, 09:14 AM
chartwel's Avatar
Originally Posted by chartwel View Post
does anyone know how to get into a sony 1080p KDL-46v2500 service menu? i read on this forum that the code is the following:
with set off, press display, then 5, then +volume, then power quickly. no matter how fast or slow, or many times i do this, it doesnt do anything................im wondering if it was the wrong code or if there is a trick to it?
posting again to see if someone can help.
chartwel is offline
post #632 of 1505 Old 02-02-2008, 08:59 AM
BeltFedWeapon's Avatar
Does anyone know the service menu for Hitachi P50V701? I have been using menu-menu-8-select and it does get me into a different menu, but I dont know if I'm doing something wrong or not because alls I can find in this menu is basically the drives for high med std or b/w but no cuts, or any other option that has to do with the picture itself (as far as I can tell). So I dont know if I'm in the right service menu and not pressing a specific button or if I'm in the wrong menu all together!!! Any feedback or help would be greatly appreciated. Thank you.
BeltFedWeapon is offline
post #633 of 1505 Old 02-09-2008, 02:35 PM
nicholc2's Avatar
I'm looking for service menu code for Protron LCD HDTV's. Does anyone have any info on those?
nicholc2 is offline
post #634 of 1505 Old 02-09-2008, 11:29 PM
natettu35's Avatar
dude this is a great thread idea!!
Nathan Muller
An eye for an eye makes the world go blind
natettu35 is offline
post #635 of 1505 Old 02-10-2008, 09:01 AM
Gslide's Avatar
I wonder if anyone knows how to get into the EMPREX 3202H HDTV's Service menu, I know many people here got one from FRY's and the set seems cool for what it cost but the only problem I have with it is that the Backlight seems to be too powerful, also the GAMMA or CONTRAST seems too high on HDMi(PS3 browser shows grays too bright), other then that it is fine.
Gslide is offline
post #636 of 1505 Old 02-11-2008, 01:20 PM
oobymach's Avatar
Looking for service menu for NEC 1940wcxm or possibly the generic cx series service menu. The only nec monitor codes I can find online don't work for this particular monitor so I'm trying my luck here.
EDIT: I found it on my own.
1. Mute Volume
2. Go to info pane w. serial number
3. Press reset/mode, volume + and volume - all at once and release.
oobymach is offline
post #637 of 1505 Old 02-24-2008, 12:31 PM
albani's Avatar
Hi
Asking you the access code for service menu
fo SHARP 32" LC-AD5E(Sharp's European opreration
series)
Bye+
Tosh 46SV685&Tosh 42WL863
Panasonic BluRay BDT320EG&Toshiba BluRay BDX5400
albani is offline
post #638 of 1505 Old 02-25-2008, 01:02 PM
HiHoStevo's Avatar
I noticed on the BruZZi website that it does not mention projectors?
I have searched this thread, but have not found anyone asking for these:
InFocus SP7210
Mitsubishi HD1000U
Runco VX5000D
If anyone has the codes or if BruZZi can come up with them I would appreciate it!!
There are just two theories for successfully quarreling with a woman -- neither one works!
The Barn - Use Password = AVSForum
HiHoStevo is offline
post #639 of 1505 Old 02-25-2008, 04:25 PM
gatsu_kun's Avatar
Hi, my set is a Samsung TX-P2665W
I would like to know how to access the service menu please, can someone help with that?
gatsu_kun is offline
post #640 of 1505 Old 02-26-2008, 11:51 AM
TJG55's Avatar
Display is a Tosh 50HP66 plasma. Have worked on it before in service menu. Tried yesterday and standard method of service entry (vol- on set and 9 on remote for >2sec) DOES NOT WORK! What's up with this? Have done a dozen of these and never had any prob. Need help. Please advise.
TJG55 is online now
post #641 of 1505 Old 02-26-2008, 01:11 PM
angryht's Avatar
Westinghouse LTV-40w1 HDC.........please.
I tried the three methods on the Bruzzi Forum and they did not work.
-Greg
angryht is online now
post #642 of 1505 Old 03-05-2008, 06:59 AM
marcelo_cr's Avatar
Anyone know where can I get the Service Manual for Sanyo PLV-Z2000?
marcelo_cr is offline
post #643 of 1505 Old 03-10-2008, 07:04 PM
SirPwn4g3's Avatar
I'd love to know how to get to the service menu for an Olevia 232T. Thanks very much!
SirPwn4g3 is offline
post #644 of 1505 Old 03-12-2008, 07:25 AM
mstrorr's Avatar
Anyone know how to change the "clamp" or "sync/timing" settings in the service menu of a Mits WS- series HDTV? I am trying to resolve the color banding issues related to the HDMI to component converter. Thanks.
K.Noel Orr
mstrorr is offline
post #645 of 1505 Old 03-23-2008, 08:48 PM
fastsilicon's Avatar
I've been searching around for some time for the service menu code for this 32" LCD HDTV, the Emerson LC320EM8
The Funai/Emerson/Symphonic codes on Bruzzi's don't seem to work. At least if I'm getting the correct button sequences. My remote (as do most Funai and Symphonic remotes I've seen recently) doesnt have buttons explicitly called RECALL or DISPLAY. I've went under the assumption that these would be CH RETURN (which recalls the last channel) and either SCREEN MODE or INFO...
Any help appreciated.
fastsilicon is offline
post #646 of 1505 Old 03-30-2008, 10:21 PM
SpeedEuphoria's Avatar
Hey I have an Olevia 537H, I tried the "source" + "vol-" + "ch-", but nothing. I searched the thread and didn't find anything about the 537H so any info please?
Thanks in advance
SpeedEuphoria is offline
post #647 of 1505 Old 04-01-2008, 11:22 AM
turbe's Avatar
Liked: 95
Thanks in advance
B11 or B12? What is your firmware version?
You have to hit all three precisely at the same time, try several times. Verify the buttons you are pressing, the Channel Down is next to the Menu Button (Olevia did not keep the Vol/Channel +/- placement consistent).
It has worked on every 537h I have tried.
From another post:
How did you access the service menu? I assume via the RS232C port, but what did you connect it to?
This has been covered long ago... for the record, the 537h (both B11 and B12) respond to the SOURCE, VOLUME DOWN (vol -) and CHANNEL DOWN [Ch-) Buttons (on the TV itself) at the same time and will enter the Service Menu. MENU Button will exit. YOU NEED TO HAVE THE TV POWERED ON TO ENTER THE SERVICE MENU!
I had been working on a ControlCAL Display Profile (see link in my signature below) for the 537h's which would allow you too access several controls via RS232 during calibration, but I got side tracked with the Pioneer ISF Display Profile.
First screen cap is the B11, 2nd is the B12 (sorry for cap quality, I simply used the camera in my phone):
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #648 of 1505 Old 04-06-2008, 02:41 AM
Herold's Avatar
Anyone have the code for the service menu
for my samsung syncmaster 244t
Many Thanks.
Herold is offline
post #649 of 1505 Old 04-14-2008, 06:27 AM
Zenak's Avatar
I'm looking to correct an overscan issue with my Xbox 360, does anyone have the service menu code for the Pioneer 533HD5?
Zenak is offline
post #650 of 1505 Old 04-28-2008, 04:14 AM
bhairavp's Avatar
Philips PFL7422D/98 - I have this (Europe/Asia) specific model.. anyone with the service menu codes?
TIA!
What's a sig?
bhairavp is offline
post #651 of 1505 Old 04-28-2008, 01:00 PM
Innersense's Avatar
Hello people
I own an LG 32LE2R and i have entered in the service menu trought "press menu in remote + in menu in tv".
Today i have presed and keep menu in remote and a 4 digits pin prompt pop up to "enter password"!
I have tried "0000", "7777", "8741", "9876" (+"1111", "4286" wich i found in some forums) but none worked and i get "wrong password".
Does any know the pass for 32LE2R?
Thanks in advance
Innersense is offline
post #652 of 1505 Old 05-08-2008, 06:26 AM
schlick's Avatar
Anyone have access to, and willing to share the training manual on this chassis? It would be deeply appreciated.
schlick
schlick is offline
post #653 of 1505 Old 05-08-2008, 10:46 AM
Negative Design's Avatar
Sceptre X46BV please.
-Thanks
Vlad
Negative Design is offline
post #654 of 1505 Old 05-11-2008, 05:13 PM
vorti's Avatar
The codes out there don't seem to work for my
Would appreciate if someone has the codes for the latest models
Mine is Sony Bravia 32L4000
thanks
vorti is offline
post #655 of 1505 Old 05-11-2008, 05:23 PM
lcaillo's Avatar
Left, Right, Muting, Select, Muting, Menu
is the method to get into the service menu on these units, but it will not do you much good. You cannot change anything, only review the settings.
Yes, calibration is important...every user should be calibrated.
Need electronics repair? A great place to start looking for a shop in your area: http://www.tvrepairpros.com/
lcaillo is offline
post #656 of 1505 Old 05-11-2008, 05:36 PM
vorti's Avatar
so i guess im out of luck on getting rid of that nasty overscan ... unless i swap the tv out
thx
vorti is offline
post #657 of 1505 Old 05-17-2008, 08:00 PM
jasonfmc's Avatar
Looking for Byd:sign d:4232, please... any help would be appreciated.
J
jasonfmc is offline
post #658 of 1505 Old 05-17-2008, 11:53 PM
ChuckZ's Avatar
Bruzzi, I'd like the service menu code to my Magnavox 20MC4304/17 CRT television with built-in DVD/VCR player.
Here is the product page:
Note that the remote supplied with the television doesn't have a MENU, INFO, or STATUS button. I've done some Googling for Magnavox service menu codes and all I've found mention the use of one of those three buttons in the button sequence.
Thanks for your help. This television desperately needs adjustment. I get purple splotches in the corner whenever there is a brown color on screen.
ChuckZ is offline
post #659 of 1505 Old 05-21-2008, 11:14 PM
wizurd's Avatar
Would love a service code for this commercial Philips display
42HF7544D/27
wizurd is offline
post #660 of 1505 Old 05-26-2008, 01:02 PM
vorti's Avatar
looking for 32L4000 service codes
the ones available online don't seem to be working
vorti is offline
Reply Display Calibration
Sharp Aquos , Sharp Quattron Tv
