Service Menu Access Codes : Official Request Thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #61 of 1574 Old 02-15-2006, 06:36 PM
RedMed427's Avatar
Anyone have the service menu code for an Insignia Model: IS-TVHD30?
I've been looking for a while and still had no luck
thanks in advance
RedMed427 is offline
post #62 of 1574 Old 02-18-2006, 11:48 PM
zinum1's Avatar
I would appreciate it if someone could pm me with the service menu access info for the Pioneer PDP 4214HD and any help on how to access it.
Thanks in advance.
zinum1 is offline
post #63 of 1574 Old 02-19-2006, 07:06 PM
iwaldrum's Avatar
Thanks in advance.
me too please!!!!
iwaldrum is offline
post #64 of 1574 Old 02-19-2006, 08:26 PM - Thread Starter
BruZZi's Avatar
Quoted: 62 Post(s)
Liked: 125
SM Codes for the Pioneer PDP 4214HD
This info is now available.
ATTENTION: The New Domain for BruZZi's Plasma FAQ is www.bruzzi.ws
If you have a direct link to the site please uptade to the new Domain Name.
All the links in the Panasonic FAQ Thread are already updated.
BruZZi is online now
post #65 of 1574 Old 03-04-2006, 06:48 PM
Hexplosive's Avatar
Does anyone have the service menu code for the Sanyo PLV-70, I can get it to pop up but I can't get it to stay so I can change values?
Hexplosive is offline
post #66 of 1574 Old 03-06-2006, 12:23 PM
caeguy's Avatar
I'm looking for a glossary of terms for my Panasonic Plasma Service menu. Anyone know where this could be found? Does a Service Manual exists for a 42PD25U?
Samsung PN60F8500, Panasonic TH-42PD25U/P, Pioneer VSX-1018TXH-K, Oppo BDP-93, Aperion Audio 5T&5C, HSU STF-2, PS3, Wii, HTPC, SD Homerun Prime, Ceton Echo
caeguy is offline
post #67 of 1574 Old 03-06-2006, 08:19 PM
rcs476's Avatar
I am looking for service menu codes for Toshiba 42hp95.
Thank you in advance.
rcs476 is offline
post #68 of 1574 Old 03-07-2006, 02:18 PM
agrsiv95's Avatar
Can someone tell me the service menu code for the 8720? I received it yesterday and want to know what to look for.
Jeremy
agrsiv95 is offline
post #69 of 1574 Old 03-08-2006, 06:54 PM - Thread Starter
BruZZi's Avatar
Quoted: 62 Post(s)
Liked: 125
nfa1934 posted some description of the service menu settings long time ago:
MTS:
MTSIN (input level)
SEPAL (low frequency separation)
SEPAH (high frequency separation)
VIDEO:
COLOR (color adjust)
TINT (tint adjust)
BRIGH (sub-brightness)
CONT (sub-contrast)
B-Y_G (color adjust, magenta)
CUT G (green cutoff)
CUT R (red cutoff)
CUT B (blue cutoff)
BRT (temp brightness)
R DR (red drive)
B DR (blue drive)
(A definition for R-Y_A was not listed)
I have the Service Manual for the TH-42PA20U which is similar to the 42PD25U. If you want a copy of it, send me a PM with a request.
BruZZi's Panasonic Plasma FAQ - bruzzi.ws
Lots of info for all Plasmas in general.
post #70 of 1574 Old 03-09-2006, 06:04 AM
sixfoot_pianist's Avatar
Hi!
Is there anyone out there who could contact me with a service menu code for a CRT set - Samsung WS32M204D?
The Samsung service codes I've found on the net don't seem to work on this model.
Thanks in advance for any help.
sixfoot_pianist is offline
post #71 of 1574 Old 03-09-2006, 07:36 PM - Thread Starter
BruZZi's Avatar
Quoted: 62 Post(s)
Liked: 125
Originally Posted by sixfoot_pianist View Post
Hi!
Did you try the other 2 codes available??? (Link at the first post of this thread)
post #72 of 1574 Old 03-11-2006, 01:46 AM
Ed Mass's Avatar
Anyone know if there are service menu codes for the Westinghouse LVM-37w1 and the LTV-27w2? And if there are, would it be possible to get these via PM?
Ed Mass is offline
post #73 of 1574 Old 03-11-2006, 03:11 AM
Ic661's Avatar
Looking for Panasonic PT-52LCX65 service menu code. Thank You!
Ic661 is offline
post #74 of 1574 Old 03-11-2006, 06:21 AM - Thread Starter
BruZZi's Avatar
Quoted: 62 Post(s)
Liked: 125
See the first post of this thread.
post #75 of 1574 Old 03-13-2006, 07:47 PM
jocanton's Avatar
Quoted: 45 Post(s)
I would like the service menu codes for Panasonic 42PHD8UK, thanks!
jocanton is offline
post #76 of 1574 Old 03-13-2006, 08:31 PM - Thread Starter
BruZZi's Avatar
Quoted: 62 Post(s)
Liked: 125
Click on my signature.
__________________________________
BruZZi's Panasonic Plasma FAQ bruzzi.ws
post #77 of 1574 Old 03-16-2006, 01:15 PM
ajh2298's Avatar
I would like the service menu code for the Philips 30pw8402/37B and what settings I would need to adjust to get rid of the screen doing this.
ajh2298 is offline
post #78 of 1574 Old 03-16-2006, 02:55 PM
pyrophite's Avatar
I'm sure these arent found yet, but i figured i'd put in a formal request for the service codes for the Vizio P42HDTV.
pyrophite is offline
post #79 of 1574 Old 03-16-2006, 05:28 PM - Thread Starter
BruZZi's Avatar
Quoted: 62 Post(s)
Liked: 125
Did you try one of the following codes ?
http://www.bruzzi.ws/plasma-faq/showthread.php?t=172
Not yet.
post #80 of 1574 Old 03-16-2006, 07:22 PM
ajh2298's Avatar
Once I get into the service menu what setting do I want to tweak and is there a list of what everything listed in the service menu does?
ajh2298 is offline
post #81 of 1574 Old 03-17-2006, 09:49 AM
tattootearz's Avatar
Excellent thread...
I am the proud owner of a Mitsu WD-52525 and I would like to access the service menu and make corrections to my Overscan issues.
Can you please PM me the procedure? I do not wish to tamper with anything else, just the overscan. I think I'm at about 5-7% on the sides and a lil less on the top.
I am a pretty tech savy guy but If you could be as "LEYMAN" as possible, that would be great.
Thanks a bunch.
tattootearz is offline
post #82 of 1574 Old 03-19-2006, 02:27 PM
AllanS52's Avatar
Still looking for the code for a PRima 42TH7
AllanS52 is offline
post #83 of 1574 Old 03-19-2006, 02:55 PM
jhuber's Avatar
Hello!
Looking for service menu access codes for the Akai PDP5006H 50" plasma. The Akai codes on BruZZi's site do not work for this model. This unit has an RS-232 port, which the manual says is for connecting to a PC, but doesn't say for what purpose, or what kind of cable is required. Maybe the service menu is accessed via PC? Any pointers on how to get a service manual would be much appreciated.
Reds are too pink, and yellows are a little too green, but I can't get rid of these issues from the user menus.
Thanks for your hard work!!
jhuber is offline
post #84 of 1574 Old 03-19-2006, 04:00 PM
Gun Shot's Avatar
Great info, thank you all!
Gun Shot is offline
post #85 of 1574 Old 03-21-2006, 12:40 AM
Mikefg830's Avatar
Just purchased this LG set, and I love it except for the ever so subtle green push. I tried the code provided on the site but it did not work. Please PM me the code if at all possible.
Mikefg830 is offline
post #86 of 1574 Old 03-21-2006, 06:09 AM
williswrath's Avatar
Can anyone help me with the service code for the following CRT set? Prima HT3461.
williswrath is offline
post #87 of 1574 Old 03-21-2006, 09:02 AM
guruerror's Avatar
Hello.
I am currently using an Insignia Model IS-TV040927 HDTV as a monitor in an arcade cabinet. I need to be able to adjust the overscan settings on this unit and the manufacturer warranty is not a concern for me.
I've found several posts on accessing the 'service mode' via hidden buttons inside the remote. The problem is that I purchased this unit from Best Buy as an open item...so no remote for me.
I've tried ordering a new remote through Best Buy's Part Search site...however the item has been on backorder for quite some time.
SO...my question for everyone is: Is there any other way to access service mode on these units, from inside the case? Or can I program one of my universal remotes to transmit the code(s) necessary to activate 'service mode?' I have both the Phillips Pronto Pro and the Microsoft/Harmon Kardon T1000 remotes available to me.
ANY assistance and/or direction provided would be GREATLY appreciated.
Thanks in advance,
Brent
guruerror is offline
post #88 of 1574 Old 03-23-2006, 12:02 PM
kjohn's Avatar
Can anyone provide the service codes for this set.
KJ
kjohn is offline
post #89 of 1574 Old 03-23-2006, 06:28 PM
phigment's Avatar
Does anybody know how to access the Viewsonic N2050W service menu? The process would be greatly appreciated. Thank you.
phigment is offline
post #90 of 1574 Old 03-23-2006, 09:03 PM - Thread Starter
BruZZi's Avatar
Quoted: 62 Post(s)
Liked: 125
Sorry, I don't have experience with Philips TVs. Try the link on the second post of that thread.
There's a way to access the service menu by open the remote control and pushing a hidden button. But I'm not sure if that applies for the Insignia Plasmas TVs. The info is now available on my site.
Reply Display Calibration
Sharp Aquos , Sharp Quattron Tv
