Service Menu Access Codes : Official Request Thread - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #901 of 1532 Old 12-27-2009, 11:22 AM
fpmacko's Avatar
Originally Posted by ed_in_tx View Post
All 3 of my Sonys (but not an SXRD) have the same code - with set Off, press remote keys Display, 5, Vol Up, Power. To save and exit, power Off. Write down the settings or take pictures first before adjusting anything!!
Some have an additional self-test screen, same key sequence except press Vol Down instead of Up.
Thanks, Ed. Perhaps there's something obvious that I'm missing. I tried your suggestion, which resulted in "something" happening. But I didn't see any new setup functions when I went into the menus. Instead, upon power-up, the tv displayed the following green text overlayed on the program material....
VERSION 0 SERVICE
VER_DISP_ENBL 0 TV MICRO
This text wasn't inself "cursorable". When I went into the menus while the overlay was visible I saw no change in the available screen setup functions. Any thoughts?
fpmacko is offline
post #902 of 1532 Old 12-29-2009, 04:46 PM
ounvme's Avatar
I am looking for the service code for a Proxima dp8000hb or Ask C300hb.
I have 2 of these projectors and they both are in need of software adjustment. I can access the service menu but I do not know the code. Please PM Thank You!! Is the remote needed for this??
ounvme is offline
post #903 of 1532 Old 12-29-2009, 08:51 PM
Installerman's Avatar
Hello, I'm looking for the service menu code for an AOC L32W961 32" LCD.
Thanks...
Installerman is offline
post #904 of 1532 Old 01-01-2010, 05:51 AM
wase4711's Avatar
Quoted: 165 Post(s)
Liked: 139
I am looking for the service menu access for a panasonic 65v10
thank you and happy new year!
wase4711 is offline
post #905 of 1532 Old 01-01-2010, 01:55 PM
asaw2513's Avatar
If someone could pm me the code to the magnavox 32mf339b or 32mf339b/f7
that would be great!
asaw2513 is offline
post #906 of 1532 Old 01-01-2010, 09:00 PM
krazik's Avatar
I need service menu access for Panny TC-P50U1
krazik is offline
post #907 of 1532 Old 01-02-2010, 04:39 PM
Chizzap30's Avatar
I'm looking for access to the service menu of a Pioneer PDP-5020FD. Thanks
Chizzap30 is offline
post #908 of 1532 Old 01-07-2010, 12:03 PM
Spdr77's Avatar
Hello,
I am looking for the access code for a panasonic TC-P42G10. Thanks
Spdr77 is offline
post #909 of 1532 Old 01-07-2010, 12:04 PM
Spdr77's Avatar
Hello,
I am looking for the access code for a panasonic TC-P42G10 to gain access to the service menu. Thanks
Spdr77 is offline
post #910 of 1532 Old 01-07-2010, 09:04 PM
sailing2hawaii's Avatar
I am looking for the access code/sequence for Sharp LC42SB45UT to gain access to the service menu. Thank you in advance!
sailing2hawaii is offline
post #911 of 1532 Old 01-08-2010, 01:55 AM
ounvme's Avatar
I did buy the remote. Still looking for the service code for a Proxima dp8000hb or Ask C300hb. Please PM
ounvme is offline
post #912 of 1532 Old 01-10-2010, 11:03 AM
himynameisaaron's Avatar
Hi. If you had information for Vizio SV420M that would be awesome. Thanks.
himynameisaaron is offline
post #913 of 1532 Old 01-13-2010, 06:22 PM
leviticus814's Avatar
I need the service menu code for a westinghouse TX-42F430.
Thank You.
leviticus814 is offline
post #914 of 1532 Old 01-14-2010, 10:34 PM
gameoso's Avatar
Hi everybody. Can please helpme to acces to service menu of vizio VO22L FHDTV10A. Thanks in advance!
gameoso is offline
post #915 of 1532 Old 01-20-2010, 10:50 AM
green99's Avatar
Looking for the Insignia NS-L42Q-10A. PM me if anyone has the service manual or can just tell me how to access the service menu. Thanks.
green99 is offline
post #916 of 1532 Old 01-22-2010, 11:32 PM
carbasher's Avatar
Looking for the service code for the Prima LC-3218p, thanks in advance
carbasher is offline
post #917 of 1532 Old 01-23-2010, 06:30 PM
Raymond42262's Avatar
Do you have the codes for a Panasonic 42 inch PZ 85U ?
Also, do you also have the best calibration codes for the tv?
I am a rookie and this will be my first attempt at this.
Thanks !
Raymond42262 is offline
post #918 of 1532 Old 01-24-2010, 08:44 AM
rcg03's Avatar
Do you have the service menu codes for the Toshiba 62MX196? Thanks in advance.
RCG
rcg03 is offline
post #919 of 1532 Old 01-24-2010, 09:10 AM
surgeon1919's Avatar
I would like information about the service menu on a JVC LT-46SL89. Please PM me. Thanks in advance.
surgeon1919 is offline
post #920 of 1532 Old 01-24-2010, 05:05 PM
audioholicJeffL's Avatar
Just picked up a Toshiba 40RV525R for the bedroom. Calibrated it with a DTP94 and HCFR and it looks really good but I would like to tweak it just a tad. Anyone know how to get to the service menu on this set? Thanks.
audioholicJeffL is offline
post #921 of 1532 Old 01-25-2010, 06:44 AM
Spdr77's Avatar
So can I ask everyone here a question? Has anyone actually gotten a Service Menu code? Cause so far I have to says Ive gotten nothing...
Spdr77 is offline
post #922 of 1532 Old 01-25-2010, 05:28 PM
rcg03's Avatar
I have not.
rcg03 is offline
post #923 of 1532 Old 01-26-2010, 12:18 PM
ehgz1's Avatar
Quoted: 17 Post(s)
I need to know how to enter the service menu for a Samsung LN-S3251D. Thanks in advance!
ehgz1 is offline
post #924 of 1532 Old 01-26-2010, 03:33 PM
Buckeye911's Avatar
Yes. Bruzzi used to maintain a pretty comprehensive list of service menu codes and there was a website that listed them but it is no longer available. Bruzzi has not been active on AVS for about seven months now, I'm not sure what happened to him.
The measure of a man's character is what he would do if he knew he never would be found out.
Buckeye911 is offline
post #925 of 1532 Old 01-31-2010, 11:30 PM
Thanks !
I have not received mine, but I would like to tweak it before the Super Bowl and the Olympics begin.
Do you 'know' him well enough to email him and ask him to help us ?
post #926 of 1532 Old 02-01-2010, 12:39 AM
Buckeye911's Avatar
Raymond, I don't know if this will get you into the service menu of your pz85 or not but here is how I access the service menu for my pz800.
Enter the service menu by taking the volume all the way to zero, release, then hold the VOL- button on the front of the TV set and press INFO three times on the remote. Release the VOL- button on the front of the TV set, and after a couple of seconds the service menu will be displayed in the top left corner of the screen.
To exit the service menu, either press Power on the remote or on the front panel of the TV set.
Entering the service menu can be very dangerous so make sure you write down all values or use a camera to take pictures of the screens before you make any changes. Good luck.
post #927 of 1532 Old 02-01-2010, 05:05 PM
Thank you, I will try it this week.
post #928 of 1532 Old 02-05-2010, 05:02 PM
rimonv's Avatar
I need the Service Manual for TC-P65S1 in pdf form please
rimonv is offline
post #929 of 1532 Old 02-08-2010, 09:08 AM
angryht's Avatar
How do I access an Insignia NS-P501Q-10A?
-Greg
angryht is offline
post #930 of 1532 Old 02-11-2010, 01:17 PM
madmatt2024's Avatar
I'm looking for service menu codes for an AOC Envision L22W898.
madmatt2024 is offline
Reply Display Calibration
Sharp Aquos , Sharp Quattron Tv
