Service Menu Access Codes : Official Request Thread - Page 40 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #1171 of 1501 Old 11-11-2011, 11:32 AM
montward's Avatar
Originally Posted by m-heat View Post
Like use photoshop create a white image the same resolution as your screen ie 1366x768... Etc.
Make sure the white is full white like 235
Thanks for the speedy reply m-heat......unfortunately, I'm still not following? I don't have Photoshop...not sure how I could create a white image using my screen resolution with white like 235?
Is your thought that the menu is coming up when I try to access it, but I can't see it? SOrry, I'm just not clear how I can do this? Is there any way you could send me a "white screen image" if I PM you with my email?
montward is offline
post #1172 of 1501 Old 11-11-2011, 02:49 PM
m-heat's Avatar
Some TVs need a test pattern sent to them to exit out of some features in the service menu. Samsung is a good example of this.
Since you went into burn in I felt a full white screen might work.
When I say 235 I mean that computer monitors show black to white in steps from 0-255 and TVs are supposed to show from 16-235 buy putting a full white screen up you may trick the TV into exiting the burn in test.
Picture without sound is surveillance.
m-heat is offline
post #1173 of 1501 Old 11-11-2011, 04:05 PM
montward's Avatar
Thanks m-heat......I have the Dynex TV connected as a monitor to my desktop computer.....and oddly, now that I have accidentally set the TV to "burn in mode" in the SM, instead of the monitor shutting down after prescribed time and going to a blank black screen and eventually shutting off, it oddly goes from a full green to a red screen to a blue screen to a white screen and then finally to a black screen and repeats the color sequence all over indefinitely staying on each color for about 5 seconds. I tried to access the menu while it was on the white screen but it didn't seem to work.....
I know sometimes if you unplug the TV and press and hold a certain button as you are plugging it back in, depending on the brand, it will re-set to factory shipped settings.
I have certainly learned a valuable lesson here...never ever modify anything in the SM unless you know what you are doing !
Thanks again m-heat for your courtesy in attempting to help me out. If you can think of anything else, I'm all ears.
P.S. I am currently in communication with the Dynex support via email. They don't understand the issue...they claim there is no "burn in mode" in the menu. I did confess to Dynex support that I went into the SM and they still can't understand what I did. I am trying to get the original factory firmware for this Dynex DX-32E150A11 32" LED but they claim it will not resolve the issue. They claim that I can unplug for 10 minutes then when plugging in again, press and hold the power button for about 40 seconds then release and that should "recycle" or reset the TV......this does not work.....as soon as I plug it in again, the TV immediately comes right on without any button or remote intervention from the user!
montward is offline
post #1174 of 1501 Old 11-15-2011, 09:39 AM
ccotenj's Avatar
Liked: 101
does anyone have the service menu codes for a vivitek h5080?
tia.
- chris
ccotenj is offline
post #1175 of 1501 Old 11-16-2011, 10:41 AM
TLJester's Avatar
looking for the service menu access code for a:
Westinghouse LD-4258
TLJester is offline
post #1176 of 1501 Old 11-24-2011, 11:42 PM
gamike's Avatar
Hi,
Looking for service menu codes for a Mits WS-65413.
Thanks in advance.
gamike is offline
post #1177 of 1501 Old 11-27-2011, 09:24 PM
jlf278's Avatar
I'd love to know how to get into the LG 42LV4400 service menu. I tried using the Pronto Code that works with most LG TV's, like on my 42LH90, but to no avail!
jlf278 is offline
post #1178 of 1501 Old 11-28-2011, 07:53 AM
mazkot's Avatar
Please if anyone knows how to access the service menu for an LG 37LC5DCB.
mazkot is offline
post #1179 of 1501 Old 11-28-2011, 09:27 AM
m-heat's Avatar
Why do you need access to LG service menu? All calibration controls are nested in expert1/2 mode for display calibration.
m-heat is offline
post #1180 of 1501 Old 11-28-2011, 09:29 AM
m-heat's Avatar
So you are holding power before and during plugging in the TV then releasing it after 40 seconds?
m-heat is offline
post #1181 of 1501 Old 11-28-2011, 06:33 PM
montward's Avatar
hi M-heat....yes, I have tried your suggestion of holding power button and holding when re=plugging in....along with several other options...and still no luck, It works as a monitor but just won't respond to anything or go into sleep mode until unplugged...fortunately, the AC cord is easy to access on the back of the LED TV
montward is offline
post #1182 of 1501 Old 11-29-2011, 12:27 PM
eortli1's Avatar
mheat,
I just spoke with LG customer service who informed me that the 42 and 47 inch versions of their lv4400 series don't allow TruMotion to be turned off. I get motion sick from time to time and found it happening to me during Saving Private Ryan's beach scene. The CS rep mentioned that this TruMotion is likely able to be disabled within the service menu, but that he didn't know (nor would be allowed) to help me access it. He agreed that turning TruMotion off would be beneficial. These are the best led LG tv's for those of us not interested in internet and on a seriously tight budget. The lg 55lv4400 does have an option allowing TruMotion to be turned off.
The CS rep guided me toward the LK 520 series and mentioned it was similar...more expensive, more inputs, better contrast ratio, and TruMotion can be turned off in the 42 and 47 inch models.
I'm wanting to go with the lg 47lv4400, but want to hit the service menu to turn off TruMotion. Might this be able to be done?
Your time is much appreciated.
eortli1 is offline
post #1183 of 1501 Old 11-29-2011, 09:40 PM
xbox365's Avatar
hey looking for the service menu codes for a PRIMA PS-42D8V3 any chance you could help me been looking everywhere and cant find anything
thanx
xbox365 is offline
post #1184 of 1501 Old 11-30-2011, 10:04 AM
lglmoris's Avatar
I need the service menu codes for an Optoma HD73. Please PM with any information. Thanks Kerry
lglmoris is offline
post #1185 of 1501 Old 12-02-2011, 01:14 PM
rc51kodiak's Avatar
Looking for service menu code for a Westinghouse vr-4625 any help would be appreciated.
rc51kodiak is offline
post #1186 of 1501 Old 12-02-2011, 02:17 PM
Otto Pylot's Avatar
Quoted: 1360 Post(s)
Liked: 852
TruMotion can be turned off, sort of. The LG will still take the 60fps and double it (showing each frame twice) to mimic 120fps. All turning TruMotion off will do is eliminate or greatly reduce the SOE. And you should never get into the service menu unless you know exactly what you are doing. It's very easy to brick your set and if you do, LG won't help you at all. That's probably why the CS was reluctant to lead you in that direction. I have the 47LD520.
Otto Pylot is online now
post #1187 of 1501 Old 12-11-2011, 11:45 AM
WaveBoy's Avatar
Quoted: 134 Post(s)
Liked: 43
Trying to find the Service menu code for the LG PT350 plasma. I'm dieing to find out if i can turn off this annoying 'Auto Brightness'
WaveBoy is offline
post #1188 of 1501 Old 12-11-2011, 07:41 PM
aznmidnite's Avatar
Hello,
I am looking for the service code for the Insignia 32" LED LCD NS-32E740A12.
I have searched, and all ready tried (without luck) these posted methods:
Pressing on remote: {2}{5}{8}{0}
Also tried:
Power on the set.
Adjust the volume to zero
With the remote - Input 9876 - then OK within 5 seconds.
Also tried:
Try:
TV POWERED OFF
MUTE
1
8
2
POWER
Any input would be much appreciated. Thanks!
aznmidnite is offline
post #1189 of 1501 Old 12-11-2011, 11:42 PM
fallengt's Avatar
looking for LG 32LK450 access code, Thanks. Tried to use search but no match.
fallengt is offline
post #1190 of 1501 Old 12-13-2011, 09:37 AM
PlasmaPZ80U's Avatar
Quoted: 1962 Post(s)
Liked: 559
Are you trying to do white balance in the SM?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #1191 of 1501 Old 12-15-2011, 11:34 AM
Liked: 559
Is it possible to enter the service menu on a 2011 LG TV with the user remote control? I have the service manual for my LK450 and want to access the EZ ADJUST mode to dial in white balance for the warm color temp preset to exactly D65. I know the user menu has every setting you could want to calibrate the TV but I want the white balance settings to stick even after a picture reset or "initial setting" reset in the user menu.
post #1192 of 1501 Old 12-15-2011, 12:37 PM
m-heat's Avatar
You can lock the expert modes. I just sent you a PM
m-heat is offline
post #1193 of 1501 Old 12-24-2011, 05:32 PM
ZandarKoad's Avatar
How about accessing the service menu for an Emerson LC320EM1F? Thanks guys!
Edit: And for the record, I did search this forum, finding only one post about taking the remote control apart and adding a jumper... Which did not apply to this model TV nor remote control... I also looked for a hidden button under the remote control casing (as mentioned elsewhere), and found none.
ZandarKoad is offline
post #1194 of 1501 Old 12-28-2011, 08:34 AM
zim2dive's Avatar
Looking for service menu codes for Westinghouse LD-4080
thanks!
zim2dive is offline
post #1195 of 1501 Old 12-28-2011, 09:11 PM
ChaosCloud's Avatar
Quoted: 152 Post(s)
Liked: 81
Hi all,
I'm looking for the service code for the NEC E461 LCD.
I suppose there is a common code for these NEC displays...
Remote control model is RL57Q-2
Would be much appreciated.
ChaosCloud is offline
post #1196 of 1501 Old 12-29-2011, 11:15 AM
KevenW's Avatar
Toshiba 65ht2u service code?
KevenW is offline
post #1197 of 1501 Old 12-31-2011, 04:30 PM
Electron Mover's Avatar
Service Menu access code for a Samsung PN43D490?
Bill
Electron Mover is offline
post #1198 of 1501 Old 01-04-2012, 06:53 AM
stephrich1's Avatar
Looking for Service menu access code for Optoma Hd33
stephrich1 is offline
post #1199 of 1501 Old 01-04-2012, 05:30 PM
ZandarKoad's Avatar
I guess I'll just post this for my own records, just to say I tried to find the service menu:
Mitsubishi DLP Projector
Manufactured M1KY
Serial 0002565
Model HC100
Anyone have this projector's service menu (or at least some access to color management or luminance controls?)
post #1200 of 1501 Old 01-09-2012, 04:24 PM
MikeRich's Avatar
Hey
I am looking for ISF Menu code for the BENQ W6000 and hopefully where/when to enter it
Please PM me.
Thanks in advance
Mike
XBL: BigMikeRich
PSN: BigMikeRich
MikeRich is offline
Reply Display Calibration
Sharp Aquos , Sharp Quattron Tv
