Service Menu Access Codes : Official Request Thread - Page 49 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #1441 of 1502 Old 02-24-2016, 02:30 PM
Liked: 0
Lg 49ub850v
Hello I am looking to access the service menu of LG 49UB850V, I need it to try enable AC3 sound through optical or HDMI2(ARC) to my receiver.
Vladimir Sukharev is offline
post #1442 of 1502 Old 02-25-2016, 03:00 PM
Liked: 0
Thomson TV service menu
Hi, does anybody know how to access the service menu on recent Thomson LCD/LED TVs made by TCL in Poland? The one I'm interested in is THOMSON 40FW3323. I already tried pressing the VOL- and PROG- buttons on the TV (a sequence suggested on some sites) but it just turns on the TV.
If you're not familiar with Thomson, do you know any service codes for a TCL or RCA LED/LCD TV made in the past 5 years? They all have the same manufacturer, so maybe the codes are the same.
cib3k is offline
post #1443 of 1502 Old 02-25-2016, 10:21 PM
SnipeUout's Avatar
Quoted: 562 Post(s)
Liked: 440
Looking for service code/manual for a Vizio model VA26LHDTV10T.
Current gear: UN65JS8500 (Main TV), P65-C1(Testing), M40-C2(Guestroom TV), UBD-K8500, I1D3(Using HCFR)
Retired: TH-50PX80U, M55-C2 (Returned)
Duds: 2x XBR-65X930D(bent frame, 3D unwatchable and clouding), P65-C1(Yellow banding, dead pixels), UN65JS8500(blue bleed) UN60J6200 (Returned, dead pixels), M65-C1(3x Defective units, all dead pixel and yellow banding)
SnipeUout is offline
post #1444 of 1502 Old 03-01-2016, 03:53 PM
Turdhat's Avatar
Looking for service menu access codes for the Vizio e Series 55 or 60 inch. Thanks. I believe this set can be forced in to 4:4:4 chroma via the SM.
Turdhat is offline
post #1445 of 1502 Old 03-26-2016, 02:27 PM
gyrfalcon16's Avatar
Question Vizio D65u-D2 Service Menu
Does anyone know how to access a service menu on the Vizio D series of displays? In particular I'd like get information on the D65u-D2.
gyrfalcon16 is offline
post #1446 of 1502 Old 04-24-2016, 08:33 AM
Liked: 0
Originally Posted by nitant View Post
I haven't found any information on this, but from my own research came across Service Codes for my TV
Micromax - 40T2810FHD. This is re-branded TCL L40B3800
The TV has 3 types of Service Modes
1) Design Menu - Can access all other modes through this - Access to Overscan and other settings
Using the remote, enter the “Picture” submenu in the OSD; choosing the “contrast” item and press the 1, 9, 5 and 0 in series, Design Menu will appear in the left top of screen
2) Factory Menu - Access to color calibration & WB settings
Using the remote, enter the “Picture” submenu in the OSD; choosing the “contrast” item and press the 9, 7, 3 and 5 in series, Factory Menu will appear in the left top of screen
3) Service Menu - Random stuff
Using the remote, enter the “Picture” submenu in the OSD; choosing the “contrast” item and press the 9, 7, 0 and 5 in series, Service Menu will appear in the left top of screen
is it possible to let me know the service code for micromax 42 inch 4k smart tv?
anthony morris is offline
post #1447 of 1502 Old 05-13-2016, 01:09 PM
Mr Crunk's Avatar
Anyone have the Service Codes(Access) for a Sharp Aquos LC-70UH30U?
Mr Crunk is offline
post #1448 of 1502 Old 05-19-2016, 03:01 PM
Liked: 0
looking for way to access and code to 40" element eleft406.
Thank you in advance.
bbsreaper is offline
post #1449 of 1502 Old 05-24-2016, 01:16 PM
Liked: 0
Question
I have searched this forum for the thread the OP refers to, the known access code list, but I have been unable to find it.
Can you please link to it?
If it is unknown already I am looking for how to access the service menu of LG 65UF770. I basically want to copy the existing channels to USB. The advanced menu options for programmes allows me copy from USB, but not to USB.
dusf is offline
post #1450 of 1502 Old 06-01-2016, 11:59 AM
stereo55's Avatar
This maybe a repeat question (but could not find the complete answer searching the forums) .
Would like the service menu code for an LG 60PB6650 .
Thx !
I miss my old Altec 1590 monoblocks ....
stereo55 is offline
post #1451 of 1502 Old 06-04-2016, 04:19 AM
ivan2011's Avatar
Quoted: 16 Post(s)
Thx !
You can do this if you have a universal remote, have a look on the LG hack site for the codes. Otherwise get a factory remote, they are not expensive.
ivan2011 is offline
post #1452 of 1502 Old 06-04-2016, 08:46 AM
stereo55's Avatar
Thx , Ill try looking up that info .
stereo55 is offline
post #1453 of 1502 Old 06-05-2016, 01:07 PM
Liked: 0
service menu access code for RCA Canada RLED4960-UHD
If you have, would you please send to me?
Don Ruchkall is offline
post #1454 of 1502 Old 06-10-2016, 02:30 PM
Liked: 0
Service menu code for APEX LD4688T
I know it's considered a budget LCD TV, but I'd like to access the service menu to finally fix this awful overscan problem. Any source, 720p and 1080p alike display clipped on all sides. It really makes playing anything, be it YouTube or videogames fairly difficult (user interface etc). Please help. Thanks in advance!
PS - I've used the code 1.1.4.7 to access "a" service menu, but it has no adjustment featured for fixing overscan. I can change screen position along an X and Y axis, but that's about it. I figure it's either in another menu altogether or I need to find new firmware for this unit.
thatrandomguy is offline
post #1455 of 1502 Old 06-12-2016, 12:30 PM
Liked: 0
bush le-20gy15t
after service mneu code for bush le-20gy15t please
firerunic is offline
post #1456 of 1502 Old 06-15-2016, 05:56 AM
Liked: 0
Service menu - LG LF510
Please let me know how to turn on the "Service menu" in the TV series LG LF510 - 49lf510.
Thank you very much in advance
aniol is offline
post #1457 of 1502 Old 06-15-2016, 05:57 AM
Liked: 0
Service menu - Benq W2000
Please let me know how to turn on the "Service menu" in the Projector Benq W2000.
aniol is offline
post #1458 of 1502 Old 07-09-2016, 01:37 PM
Liked: 0
hy guys, i have got an LG 47LB731V and i have bought recently a wireless headset and a portable wireless audio receiver. i can pair the headset with everything except the tv. i have read that i need to acces the tv's service menu and activate or deactivate something to make it work. can someone help me with instructions? thansks
Toth Alpar is offline
post #1459 of 1502 Old 07-17-2016, 03:27 PM
Liked: 0
Need Service menu for a RCA sld32a30rq,please could any one help.??
Maxpro2000 is offline
post #1460 of 1502 Old 07-17-2016, 06:40 PM
Liked: 0
Samsung samrt tv UA32F6400AW
Originally Posted by gregr View Post
Anyone have the service menu access code for the Samsung HU6950 series? The TV has a "smart" remote with no number keys so the usual samsung access code can't be entered. Thanks
Hi, me too. I'm looking for codes yet I have a smart remote.
geminoid is offline
post #1461 of 1502 Old 08-04-2016, 07:56 AM
Liked: 0
Looking for service code/manual for a Sharp LC-55SFE7542E
orkiz is offline
post #1462 of 1502 Old 08-06-2016, 01:42 PM
Liked: 0
Looking for service code and or service manual for sceptre X325BV-FHD
thx in advance!
mdavi is offline
post #1463 of 1502 Old 08-08-2016, 09:59 PM
Liked: 0
what was the service code for your lg tv? i have a lg 50pb6600 i have tried different code but none seem to work . Please help thank you
christy pan is offline
post #1464 of 1502 Old 08-21-2016, 05:46 PM
Liked: 0
Helo
Looking for lg 49ub830v service nenu any help
thanks
Modar Dehni is offline
post #1465 of 1502 Old 08-25-2016, 11:03 PM
Liked: 0
I have a horrible overscan issue on my new tv, Hitachi LU43V809. If there's any word on service codes, that would be so awesome.
Justin
justinper91 is offline
post #1466 of 1502 Old 08-27-2016, 01:53 AM
Liked: 0
Really hoping someone can help out with the service menu code/access method for the Sharp LC-47SB57UT. I see someone earlier in the thread requested it as well, but unsure if it was ever responded to. This one seems to be a very difficult one to get ahold of based on the hours of scouring Google I've spent looking for anything helpful.
manthas is offline
post #1467 of 1502 Old 09-03-2016, 06:13 PM
Liked: 0
Hello,
Please help on how to access service menu for LG 55UH6150.
TIA.
vicanon is offline
post #1468 of 1502 Old 09-07-2016, 04:26 AM
zzbusch's Avatar
Originally Posted by SnakeEyes View Post
Whats the service menu code for Insignia 42E480A13?
I'm looking for this code also. My picture is upside down and I need to flip it.
Thanks in advance.
zzbusch is offline
post #1469 of 1502 Old 09-18-2016, 06:41 PM
WalrusXVIII's Avatar
Liked: 0
Menu, 1, 1, 4, 7
Beware, many of the things you can change in this menu don't stick.
WalrusXVIII is offline
post #1470 of 1502 Old 09-22-2016, 09:48 PM
Liked: 0
Could someone PM me the service code for a Sceptre U500CV-UMK. please and thanks
Dustyp34 is offline
Reply Display Calibration
Sharp Aquos , Sharp Quattron Tv
