Service Menu Access Codes : Official Request Thread - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #121 of 1501 Old 04-24-2006, 06:41 PM - Thread Starter
BruZZi's Avatar
Originally Posted by NefariousOne View Post
Ok ive had some time to try the codes at the link - both did not seem to work. I think my model TV is the pain of the bunch .
Any Ideas?
Usually Panasonic uses the same codes for all types of TVs. Sorry, I don't know any other code.
Originally Posted by enemywithin View Post
Anyone have the service menu codes for the Pioneer 614MX plasma?
Originally Posted by mmveit View Post
Can you please PM me with the Service Menu Code for the Pio PRO-1130.
Also, If you happen to have the service manual, I would really appreciate it.
Check out the available codes for The Pioneer Plasmas:
http://www.bruzzi.ws/plasma-faq/showthread.php?t=77
__________________________________
BruZZi's Panasonic Plasma FAQ bruzzi.ws
Lots of info for all Plasmas in general.
__________________________________________________ _
Samsung 55KS800 • Pioneer Elite VSX-90TXV • Oppo BDP-103D
Paradigm Studio 10's • Paradigm Studio CC-490 • Sunfire HRS-8
BruZZi is offline
post #122 of 1501 Old 04-25-2006, 10:54 AM
enemywithin's Avatar
Yep, tried those but no luck
enemywithin is offline
post #123 of 1501 Old 04-26-2006, 05:46 AM
videobruce's Avatar
Quoted: 596 Post(s)
Liked: 246
The code for Sayno doesn't work with the new LCD sets. The set doesn't power on when you plug it in w/o pushing the Pwr. button first.
Any ideas?
Free, abundant OTA television separates this country from many others. ATSC1 has only been in force since 2009. The wireless industry has enough spectrum. Enough of 'planned obsolesce'.
videobruce is offline
post #124 of 1501 Old 04-26-2006, 11:23 AM
thekze's Avatar
I'm looking for service menu of this model: JVC AV-30W585.
My TV and 360 games edges are cut and I need to fix it, thanks a lot!
thekze is offline
post #125 of 1501 Old 04-26-2006, 01:54 PM
PencilGeek's Avatar
Looking for service codes for Pioneer Elite PRO-720HD, and Mitsubishi WS65813. I think I already have the Mitsubishi codes, just want to double check.
PencilGeek AKQJTs
2006 WSOP Omaha Hi/Lo Tournament: 6th Place
Brillian Discrete IR Codes
PencilGeek is offline
post #126 of 1501 Old 04-26-2006, 02:17 PM
Dimitrios's Avatar
Is there a service menu option for this tv, and Viewsonic LCDs in general? If you know of them, please reply and PM me the codes. Maybe we can arrange to add them to the list at the top of this thread.
Dimitrios is offline
post #127 of 1501 Old 04-27-2006, 10:08 AM
mmveit's Avatar
BruZZi,
I have checked out the codes to get into the SM, but unable to find where panel hours (not MR) and several other things mentioned on this board.
Can see INFORMATION, FUNCTION CHECK, COMMON ADJ, OPTION, INITIALIZE, but can not move to other pages by press the "DOWN" key (only INFORMATION level allows me to page DOWN, others just info on main page).
Other than how to open the SM, can someone PM with Service Guide (pdf?) and what is available on each of the INFORMATION, FUNCTION CHECK, COMMON ADJ, OPTION, INITIALIZE menus. I only see a few selections for each menu & like mentioned above can't move off main menu page using DOWN key
mmveit is offline
post #128 of 1501 Old 04-28-2006, 02:18 PM
dawgfather369's Avatar
Can someone please PM me the service menu code for a Vizio P50HDM? Any assistance is much appreciated!
dawgfather369 is offline
post #129 of 1501 Old 04-28-2006, 05:38 PM
bitemymac's Avatar
Please send me a SM code for Westinghouse 37" or 42" LCD models. Any assistance to preferred RGB settings to start off would be much appreciated. thanks!
bitemymac is offline
post #130 of 1501 Old 04-29-2006, 04:18 AM
Campster's Avatar
PM me a service code/manual for the Benq DV3750 please
Campster is offline
post #131 of 1501 Old 04-29-2006, 02:14 PM
CMale05's Avatar
I saw that you had the instructions for LG TV's to get into the service menu:
-Press AND HOLD the Menu button ON THE REMOTE
(The menu on the screen will disappear)
-Now Press AND HOLD the Menu button ON THE PANEL
-Keep both buttons pressed for 5-10 seconds
-When service menu appears stop pressing the 2 buttons
-Change page on SM using the yellow (swap) button on the remote.
Well I have the LG 17LX1R and there is no button on the remote that is yellow or says "swap". Just wondering how to switch pages once I am in the service menu. I can get into the service menu, I just cant figure out how to switch pages because there is no "swap" button on the remote.
CMale05 is offline
post #132 of 1501 Old 04-29-2006, 03:55 PM
roachxp's Avatar
Same here mine is the 42" 1080p.
roachxp is offline
post #133 of 1501 Old 04-30-2006, 04:13 PM
jkinghome's Avatar
Really be grateful for service menu codes for the Westinghouse 42". Please PM me.
THANKS!
Jane
jkinghome is offline
post #134 of 1501 Old 05-03-2006, 01:01 PM
movieguy163201's Avatar
Could someone please PM me or posy the SM code for Westinghouse 27" W7 LCD model. Any assistance to preferred RGB settings to start off would be much appreciated. thanks!
Also could you explain how to get into SM, and if any special equipment would be used to cal. it, such as something to plug in the service port
Movieguy
movieguy163201 is offline
post #135 of 1501 Old 05-05-2006, 11:03 AM
GoatLocker's Avatar
Another request for the Westinghouse LVM-42w2 42" 1080p monitor!
GoatLocker is offline
post #136 of 1501 Old 05-06-2006, 06:03 AM
Assasine's Avatar
I'm looking for service menu code for ViewSonic N4060W.
Please help me I need the code very urgently.
Assasine is offline
post #137 of 1501 Old 05-09-2006, 06:15 PM
justtaint's Avatar
With the Insignia TV's, there are extra buttons hidden underneath a sticker on the remote. Peel back the shiny plastic on the bottom of the remote (where the Insignia logo is). Its approx. a 1" x 2" piece of plastic. Underneath are 12 extra buttons.
I have the 30" version that was sold at Best Buy on Black Friday.
I'll take pics if needed.
Tom
justtaint is offline
post #138 of 1501 Old 05-09-2006, 11:06 PM
wizard2's Avatar
I know how to get into it and move around What I need is to know is where to get info on what each of value controls. It is not the same service menu as the Z3
wizard2 is offline
post #139 of 1501 Old 05-10-2006, 02:16 PM
devros's Avatar
any info someone can PM about the Pioneer 520HD set would be much appreciated.\\
thanks,
devros
devros is offline
post #140 of 1501 Old 05-11-2006, 12:44 AM
BruZZi....do you check out this thread anymore? or do you just not know the models people are asking for? Still waiting on those Westy W7 SCs
Movieguy
post #141 of 1501 Old 05-12-2006, 01:53 PM
bwcook0's Avatar
I have looked all over the net for the service codes for this TV but I can't find them anywhere. Does anyone here have this code and can you PM ot to me? Thanks in advance
bwcook0 is offline
post #142 of 1501 Old 05-14-2006, 11:00 AM
alastairj's Avatar
Looking for a service code for a UK Panasonic TX-26LXD60. US equivalent is TC-26LX60. Want to get rid of HDMI overscan. Many thanks!
alastairj is offline
post #143 of 1501 Old 05-15-2006, 09:49 AM
dasenbrock's Avatar
Originally Posted by tattootearz View Post
Excellent thread...
I am the proud owner of a Mitsu WD-52525 and I would like to access the service menu and make corrections to my Overscan issues.
Can you please PM me the procedure? I do not wish to tamper with anything else, just the overscan. I think I'm at about 5-7% on the sides and a lil less on the top.
I am a pretty tech savy guy but If you could be as "LEYMAN" as possible, that would be great.
Thanks a bunch.
I, too, would appreciate any info you could provide on the above. Many thanks!
dasenbrock is offline
post #144 of 1501 Old 05-17-2006, 06:12 AM
GeezerOtaku's Avatar
Hi, all.
New to the board, but impressed so far.
I just purchased a small (24") flat CRT SDTV for video gaming only, and have run into some serious geometry and overscan issues.
It's an Insignia NS-24FTV and I got it new for a song and am otherwise very happy.
Here's the problem: I scanned the forums, and found a post re: Insignia Service menu access, but... So far, all I am able to access are the following;
Calendar, some Othello type game, Channel Browse, and a V-Chip control menu that I can't modify.
Is there something I'm missing? Please send me any info you might have via Personal Message, or a direct post to this forum. Either method will result in my getting an e-mail.
Thanx in advance,
GeezerOtaku is offline
post #145 of 1501 Old 05-17-2006, 08:06 AM
alucard_x's Avatar
Quoted: 25 Post(s)
Liked: 25
looking for service code for Westinghouse LTV-32w6
alucard_x is offline
post #146 of 1501 Old 05-21-2006, 10:56 AM
Atrus3's Avatar
Could someone give me the code for the service menu for a Philips 26PF5321D/37? I need to adjust the overscan on this set.
Atrus3 is offline
post #147 of 1501 Old 05-23-2006, 02:57 PM
deez's Avatar
i need the service menu code for a Maxent 42hpm20...please pm me ty...
XBOX Gamertag:deezusmusic
deez is offline
post #148 of 1501 Old 05-26-2006, 08:06 PM
nikko1221's Avatar
Mr BruZZi Sir! The service menu code for Vizio doesn't work on my L37, is the one posted for all models?
BTW Many thanks for providing a MOST helpful service
nikko
nikko1221 is offline
post #149 of 1501 Old 05-27-2006, 09:42 PM
standard141's Avatar
can anyone hook me up with the pioneer pdp-4360hd service manual??? thanks!
standard141 is offline
post #150 of 1501 Old 05-28-2006, 11:43 AM
PhatBoyG's Avatar
Same here, please PM or e-mail if you have them.
PhatBoyG is offline
Reply Display Calibration
Sharp Aquos , Sharp Quattron Tv
