Service Menu Access Codes : Official Request Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #181 of 1516 Old 06-28-2006, 04:58 PM
would appreciate the service menu codes for the Sharp LC-37D90U...
kohi is offline
post #182 of 1516 Old 06-29-2006, 12:58 PM
Booyang's Avatar
Ive searched the net, Ive called LG support, and I even looked in this thread, but cant access the service menu in my LG Flatron RU-30FZ13 Widescreen HDTV.
Holding the 2 menu buttons does nothing, and the other metiod of inputing 9876 after the menu dissappears doesnt work either(just changes the channels).
Ive tried each method multiple times with no luck... I need to get into that menu to fix the overscan problem Im having when my Xbox360 is hooked up..
PM or email me..
Booyang is offline
post #183 of 1516 Old 07-02-2006, 09:24 PM
jhuber's Avatar
Hello!
The Akai service code on Bruzzi's site calls for pressing the F WHITE, AUTO, and V CHIP buttons. My remote doesn't have an AUTO button. Can someone tell me where that button is on the remote?
jhuber is offline
post #184 of 1516 Old 07-09-2006, 02:01 PM
Vasichko's Avatar
Im looking for the service menu for the Vizio P50-HDM.
Thank you.
Panny TH-50PE700U
Vasichko is offline
post #185 of 1516 Old 07-10-2006, 01:38 PM
stephenM's Avatar
How to get into the service menu of the Sharp Aquos 37D40U? Thank you.
stephenM is offline
post #186 of 1516 Old 07-10-2006, 07:41 PM
Vasichko's Avatar
Here is how to access the service menu for the Vizio P50 HDM, I can not take credit for this since I got it from a fellow board member.
On the remote hold "Exit" for 3 seconds.
Release "Exit" and press "1, 2, 3" one after the other.
This will bring up the service menu.
To exit the menu press "Exit".
Panny TH-50PE700U
Vasichko is offline
post #187 of 1516 Old 07-13-2006, 06:11 AM
dark1x's Avatar
Quoted: 13 Post(s)
Looking for service codes for a Pioneer 4270HD. Previous codes do not function.
dark1x is offline
post #188 of 1516 Old 07-14-2006, 07:07 AM
pboelen's Avatar
Does anybody know the code for the service menu of the Dell W3202MC?
I have tried the input-6-1-9 code that works on some older Dell TVs, but unfortunately that doesn't work for the W3202.
pboelen is offline
post #189 of 1516 Old 07-14-2006, 08:36 AM
jones07's Avatar
Hitachi F59 series Service Menu Codes are here!
Here it is:
Press and hold the MENU key on the TV control panel, then press the REMOTE CONTROL'S MENU+8+SELECT buttons.
To EXIT Adjustment mode, press the INPUT key on control panel, or the EXIT key on the remote.
DCAM Mode:
On the REMOTE Control:
Hold down the TV key
Press the MENU key
Press the INFO key
Release the TV key
REMOTE CONTROL KEY FUNCTIONS WHEN IN DCAM MODE
INPUTS - Blue (13x9 adjust)
ASPECT - ROM Write
DAY/NIGHT - ROM Read
MENU - Remove Color
EXIT - Cross Hatch/Video Mode
INFO - Green
GUIDE - Calculation
2 - Cursor UP
5 - Cursor DOWN
6 - Cursor RIGHT
4 - Cursor LEFT
0 - RED (7x5 Adjust)
STOP KEY - Initialize
PLAY KEY - Raster Position
FAST FORWARD KEY - Phase
To get out of DCAM Mode:
Hold TV Key
Press 0 Key
Press 1 Key
Release TV Key
Use at your own risk. Always write down settings before making any changes!
__________________
http://www.avsforum.com/avs-vb/showthread.php?t=698942
WeÂre doomed. It will never work
jones07 is offline
post #190 of 1516 Old 07-17-2006, 09:58 AM
rocky246's Avatar
I desperately need the service code for the Hisense TA42P-HDRA 4" plasma. I screwed up some setting and I cant figure out how to fix it. Needless to say, I'm bummed. Please help. =oD
rocky246 is offline
post #191 of 1516 Old 07-19-2006, 02:49 PM
lcdjunkie's Avatar
Quoted: 31 Post(s)
Hi, I would love to get my hands on the service menu code for the Niko OTP-3211W.
The DVI input looks completely unsaturated and the sharpness is lacking. These adjustments are locked while using this input! Why would they do that to their customers? Anyway this is why I need this access. Any help is greatly appreciated.
lcdjunkie is offline
post #192 of 1516 Old 07-21-2006, 05:19 PM
sans_abri's Avatar
I have this set and don't have any issues adjusting the DVI input for my sony ns75h dvd player. I dont have the set in front of me, but there are preset modes (i.e bright mode, user mode, etc). maybe you are trying to adjust a locked preset mode? i have my user setting setup perfectly for dvd viewing (used the AVIA HT dvd)
sans_abri is offline
post #193 of 1516 Old 07-22-2006, 05:14 PM
lcdjunkie's Avatar
Quoted: 31 Post(s)
When using DVI in user mode, the options available to adjust are only brightness and contrast, but I also have have color, tint, and sharpness using any other analog connection.
post #194 of 1516 Old 07-22-2006, 08:30 PM
cossack2's Avatar
I would request JVC AV-27F802 service stuff...
Kinda old.
Dave Echelberger MCSE, A+, Net+
Computer Center of Sandusky, A Microsoft Partner
Cossack a t SpamCop d o t N et
cossack2 is offline
post #195 of 1516 Old 07-26-2006, 07:15 AM
kcook01's Avatar
Can someone please PM the service menu code and options for a Sharp LC-37HV6U?
This TV has a bug that if it shuts off and then back on quickly it flashes red and need a service manual reset. This is the second time it happened and the first time it cost me 175 but they would not tell me which service manual option is the reset.
I would appreciate the help - I am dead in the water right now.
Ken
kcook01 is offline
post #196 of 1516 Old 07-26-2006, 07:39 PM
Raymose34's Avatar
v
Raymose34 is offline
post #197 of 1516 Old 08-01-2006, 04:50 PM
muevelonyc's Avatar
Can someone send me the service code for Sharp Aquos LC-37D40U?
muevelonyc is offline
post #198 of 1516 Old 08-02-2006, 10:40 AM
jb_007clone's Avatar
i'm dying for the code for the 27" insignia IS-TV040923
jb_007clone is offline
post #199 of 1516 Old 08-02-2006, 12:07 PM
Chandu1's Avatar
I found the service code related info for Westinghouse LVM-37w3 from here:
http://www.bruzzi.ws/plasma-faq/showthread.php?t=192
But I'm also looking for the service manual for this display. I can't find it at http://www.servicemanuals.net
I also searched for it all over the internet but can't find anything. If you have any info about service manual for LVM-37w3 or Westinghouse LCD service manuals in general, please PM me. Thanks.
Chandu1 is offline
post #200 of 1516 Old 08-06-2006, 04:16 AM
InfernalEternal's Avatar
Does anyone know the European service menu code for the Viewsonic N3260w? If so please send over a PM. It seems the European sets have a different code to that of the American units...
InfernalEternal is offline
post #201 of 1516 Old 08-06-2006, 09:49 AM
arnieelkins's Avatar
I am searching for the service menu code for an RCA 32V550T, chassis ITC008. The commonly referenced codes for RCA sets, specifically, "press and hold Menu, then press and release Power, then press and release Volume+" do nothing on this set.
arnieelkins is offline
post #202 of 1516 Old 08-08-2006, 02:05 AM
nanao's Avatar
Could someone PM me the service code for a 27" Westinghouse LTV-27w2 LCD TV?
Thanks a lot!
nanao is offline
post #203 of 1516 Old 08-09-2006, 01:33 PM
beanerairways's Avatar
Dose anybody have the codes for a viewsonic N2751w
Thank Dave
beanerairways is offline
post #204 of 1516 Old 08-09-2006, 05:06 PM
ColBond's Avatar
Looking for a service code for a GE D52GW12. Things have fallen out of convergence on the edges and I'm not going to pay now that it's out of warranty. Thanks for any help you can give me!
ColBond is offline
post #205 of 1516 Old 08-13-2006, 03:54 PM
bberns22's Avatar
Quoted: 45 Post(s)
Liked: 37
I too would like the service menu codes for the Sharp Aquos LC-37D40U. I will do a full calibration with mygretagmacbeth, colorfacts and accucal, on this set. I will will share service menu settings to anyone who can PM me the code.
bberns22 is offline
post #206 of 1516 Old 08-13-2006, 04:41 PM
CesarNYC's Avatar
So did this method work to get into the service menu for the LVM-37w3? Holding down the volume - and the input button, and then pressing power did nothing for me.
CesarNYC is offline
post #207 of 1516 Old 08-13-2006, 07:07 PM
mikea28's Avatar
have you tried the code on Bruzzi's site (see the first post of this thread)?
How about sharing your settings with everyone here on the board?
Westinghouse 42w2 1.00 | TiVo HD 1TB | Sony DVP-NS70H | Panasonic SA-XR55 | Paradigm Monitor 9 & CC-350 v1 | Harmony 676 | Vista MCE HTPC
mikea28 is offline
post #208 of 1516 Old 08-13-2006, 08:46 PM
Chandu1's Avatar
I haven't gotten to this yet. I plan to do basic calibration with SpyderTV later next week. When I find time for advanced grayscale calibration, I'll be looking into this. I hope to make an update by end of next week.
Chandu1 is offline
post #209 of 1516 Old 08-14-2006, 06:25 AM
bberns22's Avatar
Quoted: 45 Post(s)
Liked: 37
That code did not work, I tried it several times.
bberns22 is offline
post #210 of 1516 Old 08-14-2006, 01:38 PM
mikea28's Avatar
just thought i'd give it a shot. if you do find a working code, please send it to Bruzzi so he can include it for others. And I'm sure everyone would appreciate your calibrated settings as well
(i don't even have this tv, just trying to help people out).
mikea28 is offline
Reply Display Calibration
Sharp Aquos , Sharp Quattron Tv
