Free calibration soft (non-excel) - Page 109 - AVS Forum | Home Theater Discussions And Reviews
post #3241 of 3254 Old 05-29-2009, 06:25 AM
angryht's Avatar
Originally Posted by KTTV Images View Post
Kai,
I have searched this thread fo an answer but Jan. 2008 is the latest post I could find. Will HCFR run on a Mac? I have an iMac with OS 10.5.6 and will use a display LT or Display 2 meter.
KT
They say it does:
A mac OS X version of the colorHCFR software is now available.
This version works on mac OS 10.4 and 10.5, on intel and PPC processors.
http://www.homecinema-fr.com/colorimetre/index_en.php
-Greg
angryht is offline
post #3242 of 3254 Old 12-14-2009, 04:10 PM
zapper's Avatar
Quoted: 53 Post(s)
Hi, as usual I am coming into this thread late but better late then never they say, anyways have a Front projector Sanyo Z2000 will this color HFCR work even if my screen is not a tube like???? Thinking of going the cheapest way possible so that would be the Spyder2??? Is it worth the calibration after all the download to my laptop etc?
Ralph
zapper is offline
post #3243 of 3254 Old 12-14-2009, 11:51 PM
karsten112's Avatar
Hello ,
i used the Spyder 2 with HCFR aswell , but get no good results.
Get an Eye One , and you will be happy , because at <40 ire you get no acurate results with the spyder.
And the Eye one ist much faster.
You can do the whole Greyscale in less than 15 min.
I catch an used Eye one for under 100 at ebay.
Best Karsten
karsten112 is offline
post #3244 of 3254 Old 12-15-2009, 11:38 AM
zapper's Avatar
Quoted: 53 Post(s)
Thanks for your reply, will look around for the eye one.
Ralph
zapper is offline
post #3245 of 3254 Old 01-17-2010, 05:03 PM
fogcity's Avatar
I've got a geometry problem with my 960 and I could use some help.
The picture is skewed as follows: the top left corner is lower than top right corner, and lower left corner is lower than the lower right corner.
BUT the left and right sides are parallel to each other, and straight up and down.
So if I correct the skew by tilting the image clockwise, the left and right sides are no longer vertical. They are tilted.
If you imagine the image is a section of fence, and the posts are perfectly vertical, then the problem is that the left fencepost is lower than the right one. I want to lift that left post so it's the same height as the right post.
Any idea how to do this? I've checked the geometry pages of the service manual. Maybe it's some combination of service menu adjustments?
fogcity is offline
post #3246 of 3254 Old 02-10-2010, 01:57 AM
jangaboo's Avatar
the diy colormeter on hcfr site, do they sell them? I'd do it myself if i wasn't inexperienced with soldering
i'm surprised how expensive some colormeters are when they look so cheap in make and build, the markup profit they must make on them must be high
$80 for the cheapest all the way up to $500 and they probably cost under $15 to make
jangaboo is offline
post #3247 of 3254 Old 02-10-2010, 06:24 AM
angryht's Avatar
I would suggest an eye one LT to start with.
-Greg
angryht is offline
post #3248 of 3254 Old 02-10-2010, 10:18 AM
jangaboo's Avatar
everyone suggests eye one, it seems so fishy to me like they are advertising it
Its $120-$150
these Do it yourself colormeters are like $15 but i can't build one myself, if someone sold the one made by the HCFR guys for $30-$40 that would be great
jangaboo is offline
post #3249 of 3254 Old 02-10-2010, 10:34 AM
jimwhite's Avatar
then it needs to be calibrated.... $$$
Jim White
St. Petersburg, FL
jimwhite is offline
post #3250 of 3254 Old 02-10-2010, 10:40 AM
jangaboo's Avatar
the calibration business is fishy!
lower the prices of the colormeters, its ridiculous
after reading the dummy guide its not that hard for anyone to do it themselves especially with the great free software out there available to everyone
jangaboo is offline
post #3251 of 3254 Old 02-10-2010, 11:59 AM
jimwhite's Avatar
let us know how you make out...
Jim White
St. Petersburg, FL
jimwhite is offline
post #3252 of 3254 Old 09-18-2011, 08:34 PM
Shevy's Avatar
Best Buy Calibration = 100$?
Good price?
Shevy is offline
post #3253 of 3254 Old 10-09-2011, 09:41 AM
Chief Ediri's Avatar
Should this free software be able to calibrate backlight settings?
Chief Ediri is offline
post #3254 of 3254 Old 10-09-2011, 11:27 AM
audioholicJeffL's Avatar
Good price?
No, it is not a full ISF calibration and I have heard reports of them making things worse than if you just used DVE or something similar.
audioholicJeffL is offline
Reply Display Calibration
