Free calibration soft (non-excel) - Page 28 - AVS Forum | Home Theater Discussions And Reviews
post #811 of 3254 Old 12-16-2006, 07:56 PM
JaconKin's Avatar
Originally Posted by HDholic View Post
Can't do anything with simulated sensor. You NEED a probe. Cheapest one to get started is Spyder2.
Okay then, I was intending to get one of those when I purchase a new PC monitor regardless.
I am having a rather interesting debate about Calibration on the thread about the 24 inch Gateway monitor.
JaconKin is offline
post #812 of 3254 Old 12-16-2006, 08:33 PM
richlo's Avatar
Go to Costo..cheapest..$59.99 or something like that..
Rich L
Go Chicago Bears
richlo is offline
post #813 of 3254 Old 12-16-2006, 10:05 PM
richlo's Avatar
For those who were not sure about Oppo 971 if they used 601 or the 709 color space.
Someone inquired about it and this was the response found:
http://www.avsforum.com/avs-vb/showt...&&#post8097391
btw..I ran both 601 and 709- and doing 11th calibration...
Although I can see where the perception is that 709 it is, I hit every point of the color gamut with 601
For those with the Beta Version...I was able to elimate my bluish tinge at 100% white previously and running continuos...I was able to hit the flattest response and a gamma curve that looks pretty good..no more RED clipping whatsoever..
calibration11_mitsDTP94.zip 1.1416015625k . file
Rich L
Go Chicago Bears
richlo is offline
post #814 of 3254 Old 12-17-2006, 07:07 AM
caymann's Avatar
Thanks RichL
To summarise....i need
1. Spyder2 attached to my plasma screen on one end
2. Spyder2 connected to my laptop thru USB port (i assume) on other end
3. HFCR running on my laptop
4. What displays the patterns on the plasma TV? Do i use a DVD player ? Where are the patterns?
thanks
caymann
caymann is offline
post #815 of 3254 Old 12-17-2006, 07:34 AM
audioholicJeffL's Avatar
One thing I forgot to ask about was which grey patterns should one use for a projector? The small windows or the full screen ones? and why?
audioholicJeffL is offline
post #816 of 3254 Old 12-17-2006, 08:27 AM
I Think my spyder meter went kaput. I droped it, it did not fall far but I went to recheck my measurements and see if I might be able to get a better gamma, and the readings are way off what I calibrated the other day. It is showing green way to high, so high you could tell if it was that high by sight. I can't believe the thing would be that sensitive. It only fell about 18 inches glanced off my center channel and landed on carpet. Anyone have a link to another meter that I can purchase to work with this software?
post #817 of 3254 Old 12-17-2006, 08:32 AM
richlo's Avatar
Jeff -
COSTO has them for 59.99 spyder2express..too bad because I sold my Spyder2 last week for less than that..
Rich L
Go Chicago Bears
richlo is offline
post #818 of 3254 Old 12-17-2006, 08:39 AM
Thanks, but I don't have a costco membership or one very near me. What about another meter? a better one.
post #819 of 3254 Old 12-17-2006, 08:39 AM
richlo's Avatar
Originally Posted by caymann View Post
Thanks RichL
thanks
caymann
1. - YES
2. YES
- Select LCD mode and increase the read time from its default)
3. YES
4. If you have a DVD player connected to your Plasma - then YES - it will be a DVD player..
AVIA /DVD/Getgray -any of these disk will do for patterns. IF your DVD player allows you to play PAL region disk, then Id suggest downloading the HCFR pattern disk (go to page 1 for the original download file- there is a updated version of it, pages later that I linked). All you will ever need is in this disk.
Rich L
Go Chicago Bears
richlo is offline
post #820 of 3254 Old 12-17-2006, 08:42 AM
richlo's Avatar
Jeff-
GET THE DTP-94 (solid build and no baffle on or off - super quick read - mine reads 10IRE)...try NormanCamera - its for $129..these are getting harder to get..DO IT before they go unaffordable for most of us - of what I hear...
Rich L
Go Chicago Bears
richlo is offline
post #821 of 3254 Old 12-17-2006, 08:50 AM
richlo's Avatar
Jeff - for CRT projectors (rear Proj) - Ive always read WINDOW patterns - why is a good question - sorry I can not answer that but I had my CRT before calibrated and the small windows where used and this guy is a TOP calibator who is retired now..I trust that this is correct. I think its because of the way the CRTS are placed..one side will favor RED the othe side will favor Blue, so you eliminate that by shutting that part out and CENTER where all three converge
For FrontProj - there is minimal (real Min) diff between using FULL or WINDOW..I use FULL, someone else may differ..Once again this is what I read...You may want to even do a FULL and a WINDOW run to see any diff..
Rich L
Go Chicago Bears
richlo is offline
post #822 of 3254 Old 12-17-2006, 08:59 AM
Thanks, I did not have that much difference between full screen and the windows, a little.
I did a search, I can't find that meter anywhere. Not at BH not at norman. Anyone have a link?
post #823 of 3254 Old 12-17-2006, 09:08 AM
richlo's Avatar
www.normancamera.com
$129.99..the cheapest and get it before ITS GONE..
search for the OPTIX XR (put it in exactly like this) this is the DTP-94 probe
http://www.normancamera.com/product-...ONACO_OPTIX_XR
Rich L
Go Chicago Bears
richlo is offline
post #824 of 3254 Old 12-17-2006, 09:16 AM
Sweet, thanks. I have never ordered from this company before. Are they reputable like B&H?
post #825 of 3254 Old 12-17-2006, 09:18 AM
richlo's Avatar
Yes, tons of people here have ordered this...
I got mine from Adorama Camera, but I have read several times people, even in this forum (posting) that this is a place to get it now. Adorama sold out on all of them..$108 shipped..I think I got the last one
Rich L
Go Chicago Bears
richlo is offline
post #826 of 3254 Old 12-17-2006, 10:18 AM
Athlonstein's Avatar
Norman Camera also sells these on eBay. So if you have the time to wait for an auction to close you should be able to get it for $109.95 + $8 shipping. I grabbed one a couple of days ago.
Athlonstein is offline
post #827 of 3254 Old 12-17-2006, 10:21 AM
greeno's Avatar
Liked: 25
you use the windowed patterns because full screen, on some displays, will produce spurious clipping effects.
jeff
greeno is offline
post #828 of 3254 Old 12-17-2006, 10:46 AM
richlo's Avatar
Here are some JPEGs..of my results..hope you can see them okay..
Rich L
Go Chicago Bears
richlo is offline
post #829 of 3254 Old 12-17-2006, 11:34 AM
jeff
I kinda thought that, that might explain my gamma numbers. Well looks like I will have to order that meter and calibrate it again. Although, it looks pretty darn good now.
post #830 of 3254 Old 12-17-2006, 11:36 AM
Sweet, how do use that meter? does it have a mounting bracket for a tripod? or did you just rig something up? I assume you face toward the screen like the spyder meter.
post #831 of 3254 Old 12-17-2006, 11:58 AM
richlo's Avatar
No, and do not bother gluing a nut onto it (like what you can do with the spyder2), because the back is curved, so what I used is velcro on the tripod and wrap it around the sensor..it works, but its a pain when I do it..If I take off the screw on the tripod,Im sure it will work better, but Im not sure if I want to.
Rich L
Go Chicago Bears
richlo is offline
post #832 of 3254 Old 12-17-2006, 12:06 PM
Gotcha, velcro, the wonder material lol I just placed an order, should be here tuesday.
I noticed that there were display profiles in the software for this meter. What are those for exactly?
post #833 of 3254 Old 12-17-2006, 12:11 PM
richlo's Avatar
Jeff-
you are going to LOVE the DTP-94, the spyder2 is respectable for the price, but once you use the DTP-94..You'll never have a reason to use the spyder2..In fact, I sold mine the same day I got mine DTP-94
Rich L
Go Chicago Bears
richlo is offline
post #834 of 3254 Old 12-17-2006, 12:14 PM
Jeff-
Sounds good, is it just way more accurate I assume and faster.
I should have asked if somebody wanted to trade for these http://www.audioholics.com/productre...ngine-A5p1.php I still have them from the review and I have no place for them.
post #835 of 3254 Old 12-17-2006, 12:18 PM
richlo's Avatar
absolutely.more accurate, even down to 10IRE and as you can see in my JPEGS, it even read on mine a respectable 0IRE at .313 .313 was my x,y value
Rich L
Go Chicago Bears
richlo is offline
post #836 of 3254 Old 12-17-2006, 03:38 PM
Captain3's Avatar
First try with this proggy and Spyder on new 60xbr2. Would someone please check it out and let me know what you think. I already have learned so much here spending hours reading. Thanks to all in advance.
Color2.zip 4.9892578125k . file
Captain
Captain3 is offline
post #837 of 3254 Old 12-17-2006, 04:06 PM
HDholic's Avatar
Good job on your initial pass. You can still tighten up the grayscale a bit more. About you gamma, if your target calibration gamma is "2.2" set it to Standard. If target gamma is 2.5 which w/ your display type I doubt, then select 2.2. If display offers color decoder controls, you could tweak the CIE chart. The fun continues...
HDholic is offline
post #838 of 3254 Old 12-17-2006, 05:13 PM
richlo's Avatar
Sonys are known to have some of the most accurate color decoders, so I think you need to correct this, possibly in the service menu..there are color matrixes in some of them that allows you to change the parameters to fall in place, some other sonys have more advance features.
Also make sure you select 16-235 in the Pref/ref tab, check to see if your colorspace is NTSC or HDTV. I would start with NTSC..
Good job on the 1st pass through...and as HDholic states -THE FUN CONTINUES..
Remember, do not worry about 6500K, what you want is to get as many of your IRES hitting the D65 point. Go to your 50IRE (higlight the column) and Hit your DISPLAY MEASUREMENT INFORMATION icon and look at the top and it will state your DELTA E is 3 - that is really good, but as you go down, they go higher and higher, what you want is to get as many of those hitting Delta E (D65) between 0-3...the closer you get those , the more accurate you will be..
1st set your color/tint as close as possible to the CIE points(running your primaries and secondaries)
2nd set your contrast and brightness (go back to these since your greyscale adjustment affect these)
3rd run continuous for 100IRE until you get that close, then check 30IRE..then do a full run of it..The reason I state 30 is because with the spyder it struggles a bit with 20IRE, but use your own judgement and try 20IRE, it might work since its a directview LCD if I am correct.
- and as stated previously - make sure to recheck contrast and brightness.
lastly - make sure you write your initial settings, just in case things get out of whack you can revert back to those..
Rich L
Go Chicago Bears
richlo is offline
post #839 of 3254 Old 12-17-2006, 05:49 PM
Gino AUS's Avatar
Jeff-
Richlo- can this DTP-94 be used for CRT front projection?
( B ) ( G ) ( R ) BlendZilla DownUnder ( R ) ( G ) ( B ) - Tubes of Fury
Gino AUS is offline
post #840 of 3254 Old 12-17-2006, 05:56 PM
richlo's Avatar
OH YEAH..I used it on Mits 55807 CRT..
THe other great thing about the DTP - NO BAFFLE issues
ALthough on the DTP you will actually select CRT mode, for the Spyder2, you will select LCD mode with the Baffle on..
Rich L
Go Chicago Bears
richlo is offline
Reply Display Calibration
