Samsung Calibration Failure - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #181 of 233 Old 08-25-2014, 09:50 AM
JohnPulse's Avatar
Originally Posted by mike kaw View Post
Not good! While checking for my samsung h5000 hours, I accidentally selected av calibration. Now, My tv's colors are now too dark.
I don't want to ruin my warranty and spend on repairs. My question is, what if I leave the setting as failed?
Would my tv's life span get worst by leaving the calibration setting as failed?
I don't see any side effects of leaving the calibration as Failed apart from poor video quality on the AV and Tunner Channels.
Get yourself a couple of hours from your time and try to fix the problem, you can do it quite easily with (almost?) no risk of getting it worse
JohnPulse is offline
post #182 of 233 Old 08-25-2014, 09:53 AM
JohnPulse's Avatar
Originally Posted by darkvader001 View Post
Hi,
I looking for one owner of the Samsung LED UN65F8000 series. Like an idiot I played with my White Balance settings (couple of digits) in the service menu, but I cannot get back to original settings
So I'm looking for someone that can give me the original settings of this item in the service menu.
How to work:
Put the TV on an HDMI input source, Turn TV OFF, then press on the remote: MENU then 1, 8, 2 and in the end POWER to put the Tv on again. The tv is now starting up and service menu will appear in a couple of seconds.
Well now the settings:
Go to ADC/WB -> White Balance.
here you can see some settings like:
Sub Brightness
R Offset
G Offset
B Offset
Sub Contrast
R Gain
G Gain
B Gain
I need the digits behind thos settings.
I need the settings behind ADC/WB -> ADC Results too.
So can someone please send me an e-mail or post it here?
Kind Regards,
Darkvader
Hello,
With the data you requested the values might make your picture better but not optimal, as they are specific to the panel on your TV. Please do a calibration like explained to revert the problem.
post #183 of 233 Old 08-25-2014, 12:24 PM
darkvader001's Avatar
Originally Posted by JohnPulse View Post
Hello,
The calibration values are per device, almost as a Serial Number. So, actions like Factory Reset or Firmware Upgrades will not fix the problem. The calibration values remain unchanged.
Is interesting that calibration is specific to the panel, because I have a friend that Samsung end up replacing the panel for a UN65F8000 too, do to very bad uniformity, but they did't replace the board or did any re-calibration, they just put the old board on the new panel.
So if board calibration is specific to the panel, how is that Samsung replace panels without replacing the board or re-calibrating the existing one?
darkvader001 is offline
post #184 of 233 Old 08-25-2014, 01:49 PM
JohnPulse's Avatar
It seems that your friend might have ended with a not calibrated TV, however, the values didn't differ much for the two panels.
Like I said, copying the values from other TV will not give you optimal results, but it's better than having just a "Failed calibration" I guess.
But to correct me or to support me, I'll let the gurus take it from here.
John
post #185 of 233 Old 08-25-2014, 03:11 PM
Otto Pylot's Avatar
Quoted: 1507 Post(s)
Liked: 934
The panel itself is not calibrated but the electronic components (boards) that feed the display are. If the same type of panel is replaced (Samsung for another Samsung) they should respond very similarly to the components. If the panels are different (Samsung for an Optonics for example) the panel response could be different. That's why copying values from one set to another does not work very well at times, or at all. Board tolerances are different from tv to tv even within the same model and build. Add different panels to that and it can become a real mess.
Otto Pylot is offline
post #186 of 233 Old 08-25-2014, 06:41 PM
Well hopefully someone that have a Un65f8000 with a TS01 panel will be kind enought to help me with the numbers. That will be better than nothing.
post #187 of 233 Old 08-25-2014, 08:29 PM
Otto Pylot's Avatar
Liked: 934
^^^^^ good luck.
post #188 of 233 Old 08-25-2014, 09:06 PM
^^^^^ good luck.
One thing I just did is an HDMI Calibration using a 1920 x 1080 .png. 8x8 checkerboard pattern that start with a black box on the left, that give me HDMI Calibration Success in less than 3 seconds.
But the values im asking for, did' t changed. For example the ADC Results first 5 options still show 0.
Do you beleive im using the wrong pattern for calibration?
post #189 of 233 Old 08-25-2014, 09:48 PM
Otto Pylot's Avatar
Liked: 934
Are you still messing around in the SM?
post #190 of 233 Old 08-26-2014, 12:19 PM
Well since the values were not right, and for what I have read doing the HDMI calibration is what set the ADC/WB values, I follow some of the instructions I have found around the forums and give it a try. PQ did not took a hit, some I'm assuming I sue the correct pattern at the correct resolution. But none of the values I was expecting to change did.
So I'm still on the hunt for some UN65F8000 numbers for those settings I asked before.
post #191 of 233 Old 08-26-2014, 12:29 PM
Otto Pylot's Avatar
Liked: 934
Just be very careful and understand that even if you find values, the version number of the board(s) could also affect how those numbers interact with the panel. One set looks great and the other looks like crap. You'd almost have to find a tv with the same version and build number of components to get back to what your factory settings were. I hope you can find values that you can live with.
post #192 of 233 Old 08-26-2014, 01:20 PM
I hear you. I guess the question is what make those numbers change? What exactly I need to do (other than calling service tech) to get them to update after the HDMI Calibration is successful. So far HDMI Calibration being successful is not changing them so maybe im missing something on the steps I followed.
The other thing I was hoping was a Firmware update that will update the values. I think someone reply to me that Firmware updates don't update those values, but is worth the try.
Unfortunately I have all the latest update so there is nothing new out there that I can make the TV auto update.
Do you know if there is a way to force a re-install of the latest update that is already install on the TV?
post #193 of 233 Old 08-26-2014, 01:35 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
the grayscale values for red/green/blue are not affected by anything other than a manual setting.
I never been in a LCD service menu.
I have telneted in to adjust the scale but don't know what the starting values were.
some TVs have a scale for HD and a different scale for SD.
the values should be the same from the factory so if your Tv operates that way, feed it a SD signal and look.
from what I have seen, the service manual will give cut values and gain starting point values and then how to set normal mode using a meter and then add a certain amount to each gain to get the warm/cool values.
where are you located?
Loving D65
CalWldLif is offline
post #194 of 233 Old 08-26-2014, 01:49 PM
Otto Pylot's Avatar
Liked: 934
As far as I know those are factory set values that can only come from the factory. That's why it's called the Service Menu. An authorized service technician could probably get the correct values but that's something that most, if not all, tv mfrs will not cover in their warranty or do. Entering the SM voids your warranty in a lot of cases. Firmware updates do not change those values because they are usually held in an area on the mobo that is not affected by the firmware updates.
post #195 of 233 Old 08-26-2014, 02:14 PM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
The HDMI ADC calibration procedure on Samsungs only affects the D/D (8 to 10 bit) values (it is purely a bit mapping calibration with no white balance involved since there is no meter to tell the display what the white point of the display is). The only values that will change are the ADC Result values 2nd_R_L, etc. So if you have gotten the "success" talkback you are done, these values are now correct.
The WB values in the service menu are for adjustment only if you have a meter and wish to alter the baseline WB.
ConnecTEDDD likes this.
zoyd is offline
post #196 of 233 Old 08-26-2014, 02:57 PM
Thanks for the info, I'm in Florida.
post #197 of 233 Old 08-26-2014, 05:36 PM
Those settings are on the t-con board or the main MOBO?
post #198 of 233 Old 08-26-2014, 06:09 PM
So is ok if the values for 1st stuff are 0 like the picture below?
post #199 of 233 Old 08-26-2014, 06:57 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
yup
those are not color temp values, those are Ycbcr HDMI mapping
values I believe.
for the 4:4:4 and 4:2:2 mapping.
Loving D65
post #200 of 233 Old 08-26-2014, 07:35 PM
Otto Pylot's Avatar
Liked: 934
Don't know.
post #201 of 233 Old 08-26-2014, 08:16 PM
yup
values I believe.
Cool that is good news :-), assuming that my 1920 x 1028 checkerboard 8 x 8, black first left top corner block, was the correct one to use.
What you think?
Thanks a lot for your replies
post #202 of 233 Old 10-09-2014, 01:42 PM
DiscountTv's Avatar
Calibration Fail on HDMI Samsung H/F Series
What you think?
Goto this link. http://wiki.samygo.tv/index.php5/Calibration
Copy the image as posted to a flash drive. Use a Blu Ray player that reads USB Media. Put the image on the USB Flash Drive. Put the Blu Ray player on the ARC HDMI Port and open the photo in the media portion of your Blu Ray player to display this on the Screen Via HDMI. Then run the test again.
Good Luck
-Mike
DiscountTv is offline
post #203 of 233 Old 10-14-2014, 05:08 PM
specd_out's Avatar
I just did this exact same stupid move on my 1 day old 64f8500. after researching around, I found that in the service menu under the SVC tab there are test screens.
These might not be call the same tabs in all samsung tvs but I am pretty sure I have seen test patterns in many samsungs.
mute-1-8-2- pwr
SVC tab
Look for test patterns
scroll through the patterns until you see the checkerboard pattern
select that pattern
go back to the ADC/WB
ADC
hdmi calibration
start the calibration.
Took about 3 seconds and it brought my tv right back to how it was before.
Hope it helps
specd_out is offline
post #204 of 233 Old 11-25-2014, 12:52 PM
Liked: 0
Originally Posted by Talachas View Post
SPANISH<br><br>
Hola mi ingles no es muy bueno pero quiero compartir con ustedes lo del Lattice pattern chess.<br><br>
yo tengo la tv modelo EH5300 Samsung Smart TV y me pasa lo mismo que a todos el maldito cuadro magenta no se movia por mas imagenes que le pusiera de fondo.<br>
cada vez que hacia el AV CALIBRATION me pasaba lo mismo simplemente el cuadro magenta no se movia.<br><br>
Mi televisor ya casi no se veia, las imagenes eran totalmente borrosas y aunque tal vez no quedo del todo bien.<br><br>
Puedo decirles que la imagen mejoro muchisimo y estoy contento por eso asi que quiero compartir con ustedes lo que hice y como logre que la calibracion del AV finalmente dijera SUCCESS.<br><br>
Entre en modo servicio de la Tv ya saben como es: Mute - 182 - power<br><br>
-SVC<br>
-Test Pattern<br>
-Pattern Sel<br><br>
alli con la flecha derecha del control escogemos el patron que estamos buscando ( el que parece ajedrez blanco y negro)<br>
despues de esto le presionamos el boton del control remoto:<br>
-Return<br><br>
asi llegaremos al principio del menu de servicio y ahora nos dirigimos al menu para realizar la calibracion para esto elegimos lo siguiente que seguramente ya lo han hecho mil veces:<br><br>
-ADC/WB<br>
-ADC<br>
-AV Calibrate<br><br>
Una vez que hagamos esto nos dara SUCCESS<br><br>
y la imagen mejorara.<br><br>
IMPORTANTE:<br>
Cuando estemos en el menu PATTERN SELECCION y hayamos elegido el patron de ajedrez una vez que salgamos del menu SVC, NO SE VERA EL PATRON. REPITO NO SERA VISIBLE EL PATRON. pero la prueba sera exitosa es como si el patron estuviera alli pero de forma subyacente.<br><br>
Saludos y mucha suerte!!!
amigo esto no me funcionó, pude hacerlo con la hdmi poniendo el calibrador de 4 cuadros blancos y negros en el ps4, pero en av no se que hacer... La señal de cable luce horrible ya he tratado de calibrar con este metodo muchas veces... alguna idea?
antoaular is offline
post #205 of 233 Old 11-25-2014, 01:01 PM
Liked: 0
Originally Posted by mrweek View Post
I'm successed,the picture turn mormal finally!! Instead run the calibratation process just set 1st_Y_GH &amp; 1st_Y_GL manualy till the picture looks great, Thanks everybody!!!<img alt="" class="inlineimg" src="http://www.avsforum.com/avs-vb/images/smilies/wink.gif" style="border:0px solid;" title="Wink">
what values did you use? thanks. I'm looking for the av.
post #206 of 233 Old 11-25-2014, 01:03 PM
Liked: 0
Originally Posted by videobruce View Post
A <b>AV</b> ADC calibrate was done when on the TV input (analog channel) and it not just failed, it won't allow any further calibrations using a checkerboard (or lattice pattern as Sammy calls it) as their Service manual calls for. According to the SM, Sammy calls for a lattice or checkerboard pattern with the AV input as with allothers. Others in then thread state it needs color bars.<br><br>
Now, when I use a split gray scale pattern, the Y steps below 50% are at or around black and the others are at a overall reduce level, probably topping out at 50%. Only the analog sources are affected (analog TV channels and the composite input). Component, VGA, digital tuner channels and HDMI are fine.<br><br>
When I re-tried the calibration, that magenta square does not move as it is suppose to do. Even after doing a factory reset, it just sits there. Lastly, even though only a 'AV' calibrate was originally attempted, HDMI &amp; component also show failed. Of the four types of tests, only 'PC' shows success. No other input calibrate was done.<br><br>
Why won't a factory reset allow the calibration to proceed?
could you repair the av calibration? I'm freaking out...
post #207 of 233 Old 11-25-2014, 05:04 PM
Liked: 0
can anyone please pass me his data numbers, I can't make it work,....
post #208 of 233 Old 01-06-2015, 04:51 PM
avfanatic1's Avatar
Quoted: 74 Post(s)
Liked: 30
mute-1-8-2- pwr
SVC tab
select that pattern
ADC
hdmi calibration
Hope it helps
Can't thank you enough - life saver!
avfanatic1 is offline
post #209 of 233 Old 01-06-2015, 05:03 PM
specd_out's Avatar
Glad my stupidity help someone out. Now i feel its kinda justified ha ha
post #210 of 233 Old 01-22-2015, 08:53 AM
Liked: 0
Hello
I have a Samsung p51d6900 and i did the same stupid thing with the HDMI calibration in the service menu.
I did get a succes calibration with the checkboard pattern but the Colors are not the same al before.
There is Some kind of Brown red filter over the screen , light Colors Sems Ok but black looks more Brown.
Do Somebody know what went wrong and how to fix this ?
Cgdj is offline
Reply Display Calibration
