Video Essentials Vs Digital Video Essentials - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-30-2006, 01:04 AM - Thread Starter
SunKing9's Avatar
I have an old dvd copy of Video Essentials from Joe Kane Productions that I bought years ago to calibrate a rear projection tv.
I am now trying to calibrate a 50" plasma display.
Do I need to buy the newer DIGITAL Video Essentials or is the old Video Essentials the same thing?
SunKing9 is offline
post #2 of 5 Old 12-30-2006, 08:42 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
Older version had errors ... associated with early DVDs. You can still use it for the plasma. but it won't be as close ... (from an instrumentation stand point)
It does have more test patterns than the normal DVE though since it was a professional tool versus DVE being a common man item.
Regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #3 of 5 Old 01-01-2007, 05:49 PM - Thread Starter
SunKing9's Avatar
Ok, thanks. DVE is ordered and on its way.
I went ahead and calibrated using the old disk. It will be interesting to see the difference in the two Video Essentials.
SunKing9 is offline
post #4 of 5 Old 01-01-2007, 07:26 PM
jakekit's Avatar
How does this compare to just using the THX settings stuff found on Star Wars Ep3 disc? I did get considerably different settings from the THX setup than from my old VE disc.
I'm also just waiting for the hdnet test pattern to tivo so i can setup other input from the cable box.
jakekit is offline
post #5 of 5 Old 01-02-2007, 11:50 AM
D-6500's Avatar
Color to me is already over exaggerated at midpoint. The color ended up so high with the THX optimizer I knew something was wrong. People have enough problems setting contrast with DVE and Avia; THX is hopless there. One standout: THX has patterns to check if your monitor ratio is correct for what you are watching the film on, 4:3 or 16:9. AVIA and the others already have those.
D-6500 is offline
Reply Display Calibration
