To Spyder2 or not to Spyder2? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
Old 01-31-2007, 05:48 PM
D-Nice's Avatar
Quoted: 81 Post(s)
Liked: 318
Did you attempt to calibrate the plasma in CRT mode? If not, can you give it a shot? Both charts look pretty bad for the Panasonic.
D-Nice is offline
Old 01-31-2007, 07:15 PM
Bear5k's Avatar
Tom - The reality is which calibration table better models the light source the meter is measuring. It could be that the CRT mode is the better choice for the phosphors in the plasma.
D-Nice - the goal here is to see how closely the D2 tracks the i1 Pro. Whethe the display is calibrated or not is largely irrelevant.
Bill
Color accuracy evangelist and CalMAN insider
Bear5k is offline
Old 01-31-2007, 07:24 PM
D-Nice's Avatar
Quoted: 81 Post(s)
Liked: 318
Bill
My bad. However, I would like him to test the CRT mode as I'm interested in getting either the i1pro or Display2 to calibrate plasmas.
D-Nice is offline
Old 01-31-2007, 07:51 PM
derekjsmith's Avatar
Liked: 116
Originally Posted by TomHuffman View Post
Derek: I ran this in test Normal mode. That is correct, yes? The CRT mode is just for CRTs and not for other types of direct view displays?
Tom - from everything I have read we will want to use CRT mode on the D2 for Plasma. Because the Plasma's are refreshed just like a direct view CRT tube, so we need the rate sync, which is very important for accuracy in the D2. Also for the phosphor cal table in the D2.
So Tom if you could run this again using CRT mode and let me know, thanks.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
Old 02-01-2007, 02:28 PM
TomHuffman's Avatar
Quoted: 685 Post(s)
Liked: 613
I'm scheduled to work on a Pioneer plasma Saturday. I'll test it again then with the CRT option.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
Old 02-01-2007, 04:49 PM
jvincent's Avatar
I did a very quick test on my plasma with my DisplayLT before going to bed last night.
Connected the DisplayLT, configured it for CRT, did a reading. Immediately followed that by a reading when calibrated for LCD.
The results were indeed different. Of course silly me forgot to save the results but the biggest difference was in the blue. I believe that the CRT reading of blue was lower than LCD. I'll try and confirm post results tonight.
jvincent is offline
Old 02-01-2007, 06:27 PM
jvincent's Avatar
Just reran the same test.
The readings for CRT mode result in a consistently HIGHER reading (about 2%) for blue than for LCD mode.
Red was closer, anywhere from equal to 2% or so LOWER in CRT mode.
Green was essentially dead on.
jvincent is offline
Old 02-03-2007, 05:38 PM
TomHuffman's Avatar
Quoted: 685 Post(s)
Liked: 613
The Display 2 problem with plasmas is confirmed.
Display 2 Gray scale
i1Pro Gray Scale
Note: Strangely, this problem manifests itself with gray scale readings only. Chromaticity readings seem fine. Using the CRT mode changes the reading somewhat, but it doesn't make it obviously more accurate. Furthermore, it reports an inability to read the scan rate.
Tom Huffman
Springfield, MO
Old 02-03-2007, 05:46 PM
jvincent's Avatar
Looking at the charts it appears that RED is being over reported for the D2 vs the i1Pro.
The differences between GREEN and BLUE look to track pretty well.
Speculating, is it possible that the D2 is more sensitive to infra red than the i1Pro?
And along the same lines, this would be likely be different from plasma model to model.
jvincent is offline
Old 02-03-2007, 08:32 PM
TomHuffman's Avatar
Quoted: 685 Post(s)
Liked: 613
If you look closer the difference is more profound than that. At 100 IRE
Display 2
R 114%
G 97%
B 89%
i1Pro
R 106%
G 100%
B 93%
Tom Huffman
Springfield, MO
Old 02-04-2007, 06:34 AM
jvincent's Avatar
The delta between the G and B differences is only 1.5% , which is probably withing the accuarcy of the probes. I think some normalization of the RGB % happens as well which may throw things off a bit.
jvincent is offline
Old 02-04-2007, 10:31 AM
Mist8rioso's Avatar
Anyone besides software developers with a D2 that can compare results between Calman and HCFR?
Mist8rioso is offline
Old 02-04-2007, 10:37 AM
TomHuffman's Avatar
Quoted: 685 Post(s)
Liked: 613
I know that this doesn't really address your question, but you might want to know that I went back and forth between CalMan and ColorFacts and got essentially the same results. You really shouldn't see any difference between competently engineered software packages. The real differences show up when you use different hardware.
Tom Huffman
Springfield, MO
Old 02-04-2007, 11:11 AM
Mist8rioso's Avatar
It answers somewhat . On page 2 there was some debate stating that Calman was the only one providing accurate results w/ D2 compared to HCFR. If anyone else can test this, please inform us all .
Old 02-05-2007, 06:34 AM
Georges G's Avatar
Hi Mist8rioso
It wasn't a debate, it was just a claim from Calman authors
Regards
Georges
Georges G is offline
Old 02-10-2007, 06:09 AM
benven's Avatar
Total noob here with calibration. But I have a SpyderII and HCFR. DLP front projector, LG upconverter DVD player. I nailed down grayscale a few weeks ago, but went to recheck last night and I am not even close anymore. Reds are way down across the entire IRE spectrum. Really frustrating. This isn't the first time I have recehcked and got a different result. The good thing is the picture looks great to me now and that's what matters. But, I am going to change my screen and would like to recalibrate but I can't trust this thing. Any suggestions other than buying another probe? Anyone else experience this? Thanks.
Meow.
benven is offline
Old 02-10-2007, 06:26 AM
jimwhite's Avatar
If it's a new projector, it could be your lamp is in the rapid-initial-decay mode....
Jim White
St. Petersburg, FL
jimwhite is offline
Old 02-10-2007, 10:17 AM
greeno's Avatar
Liked: 25
It might also be the S2 probe. It can give you variations that might be big just from temperature variations.
Best,
jeff
greeno is offline
Old 02-10-2007, 10:49 AM
benven's Avatar
Projector bulb has over 800 hours on it. And I hadn't changed a single thing with the PJ setup. When I turned on the room lights red did go up as it should have. So it is responding. If I try to adjust GB down or R up, I will end up with an overly red image.
greeno, can you please further explain what you mean by temperature variation? Is it bulb temperature, room temperature, colour temperature?
Are any of the other probes more repeatable?
Meow.
benven is offline
Old 02-10-2007, 11:33 AM
Liked: 116
The Spyder2 is very sensitive to ambient temperature changes, as little as 5 degs you can get 5% change in readings. So it's not a problem as long as your ambient temperature is not changing with you are calibrating and not trying to compare day to day readings.
Yes the Display2 has been very good on all display types except Plasma because it does not have a IR filter like most other tristim meters. But we do have a plan for that
Derek
Old 02-11-2007, 08:17 AM
benven's Avatar
Thanks Derek. I guess I shouldn't have been cheap!
Meow.
benven is offline
Old 02-18-2007, 05:07 PM
TomHuffman's Avatar
Quoted: 685 Post(s)
Liked: 613
I had a chance to test the Display 2 against the i1Pro on an uncalibrated LCD flat panel. It does quite well
i1Pro Grayscale
Display 2 Grayscale
i1Pro Chromaticity
Display 2 Chromaticity
They deviate a little with respect to green, but not enough I think to be perceptible. All in all, very good performance with this inexpensive colorimeter.
Tom Huffman
Springfield, MO
Old 02-18-2007, 06:59 PM
Mist8rioso's Avatar
Tom,
Would you mind doing a quick run on ColorHCFR with a Display2 and compare its result to Calman? I really want to see how they compare. PM me if need be. Hope it's not much to ask .
Old 12-13-2007, 08:50 AM
Najeeb's Avatar
Anyone try either of these two yet?
Najeeb
Najeeb is offline
Old 12-14-2007, 06:59 AM
Bear5k's Avatar
Najeeb
Yes. The Spyder3 is a bit faster than the Spyder2, but cannot use its internal CRT calibration table (as of 12/14/07). I would not recommend it for anything other than a direct-view LCD given some of the issues we've seen with ours. This is only a sample of 1, so take this with the grain of salt. The deactivation of the CRT table is done via the Colorvision software, so that is not something that varies from meter to meter.
The Platinum are the "hand picked" Spyders, and they test well. The only issue is filter degradation over time. At the pricing for these, though, you are getting fairly close to an i1 Pro...
Bill
Bear5k is offline
Old 02-09-2008, 10:15 PM
SnakeEyes's Avatar
Curious, is there a way to get into support mode with the Mac software?
SnakeEyes is offline
Old 03-04-2009, 02:52 AM
williswine's Avatar
Derek,
I know it has been a while but has Calman been confirmed to work fine, eventually modified since then, with an EyeOne Display 2 and a plasma? I would be interested in calibrating my Kuro Pro-111fd with Calman and the Display 2 but don't know whether this makes sense due to that problem with red.
Williswine
williswine is offline
