Calibrating SD and HD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-11-2007, 05:17 PM - Thread Starter
jjthenovice's Avatar
Quoted: 130 Post(s)
Liked: 70
I have a Samsung HL-S5687W. I use the Motorola 6200 connected via component input for my HD and SD. How can I calibrate this input (what type of source etc)? I thought about temporarily hooking up my dvd player to the component input and use DVE to calibrate the input. Will this get it atleast close for SD and HD?
Vizio M75-C1 Go Big or Go Home
jjthenovice is offline
post #2 of 3 Old 01-12-2007, 07:13 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
For HD calibration ... you need HD signal patterns and upconverting SD to HD does not do it.
For SD calibration ... you need SD patterns.
The optimal settings for both signal types will almost always be different.
Regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #3 of 3 Old 01-12-2007, 11:18 AM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
There are a couple of things to consider.
- There are different SD and HD color spaces.
- Many displays store unique settings for different resolutions on the same input.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
Reply Display Calibration
