Seperate Calibration for Inputs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-15-2007, 09:50 PM - Thread Starter
johnarbour's Avatar
Hi all, my questions is this: I know I need to calibrate every input on my 42" LG plasma. I have used DVE and done a pretty good job on the component through the DVD player. But, if I want to calibrate my HD OTA antenna input for instance, would it work to hook the DVD player up to that input, and calibrate using DVE? Or do I have to have a test pattern from that source? Same with HD DirecTv...would it help to hook up DVD player to the HDMI input and calibrate, or use HDNETs pattern on Tuesday mornings? Thanks for the help!
johnarbour is offline
post #2 of 7 Old 01-15-2007, 11:34 PM
Joelc's Avatar
Simple answers...you need a signal from the source....
Joel
Some people choose to have a pool, I choose to have a home theater!
Joelc is offline
post #3 of 7 Old 01-16-2007, 08:18 AM - Thread Starter
johnarbour's Avatar
So what's the best way to calibrate a source such as OTA or satellite?
post #4 of 7 Old 01-16-2007, 08:42 AM
noizemaker's Avatar
Well the correct way to do it would be with the use of a designated signal generator. You must be aware of the fact that even a properly calibrated OTA or Satellite or Cable input may not yield desirable results however. Reason being that broadcast signals vary from channel to channel.
Just my 2 cents.
Carmine.
noizemaker is offline
post #5 of 7 Old 01-16-2007, 09:39 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
Do it with a HD signal generator and cross your fingers that it gets close. (It usually gets close, but there will be channel to channel and program to program variations.) Fact of life.
Regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #6 of 7 Old 01-16-2007, 10:19 AM - Thread Starter
johnarbour's Avatar
Sounds like the easy way is to "eye-ball" it!
post #7 of 7 Old 01-16-2007, 02:29 PM
Quoted: 40 Post(s)
Liked: 142
Greetings
You can eyeball it, but the grayscale is still wrong.
With stuff like cable ... you find that there is a bit of variability with brightness and color and tint from program to program. A couple of clicks one way or the other usually fixes the variance.
Regards
Reply Display Calibration
