KDF 46e2000 CAlibration? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-09-2007, 07:54 AM - Thread Starter
Jay-Stew's Avatar
Just wondering, What would the best choice be to calibrate my Sony kdf46e2000 RPTV? I have been searching the forums and I am a little confused to which one to use . I also see that some of these DVD's have versions or have the version year on them . Does this matter? I figure i will get the Avia or DVE . Any thoughts.. Thanks!!
Jay-Stew is offline
post #2 of 3 Old 02-09-2007, 12:14 PM - Thread Starter
Jay-Stew's Avatar
bump
Jay-Stew is offline
post #3 of 3 Old 02-09-2007, 07:52 PM
like.no.other.'s Avatar
Have the same TV and used Avia and worked wonderfully. Just to warn you it's not for
daytime use because when your eyes is used to sharp, bright, and vivid picture, Avia's
calibration will be the opposite but not in a bad way.
There is always someone out there that gives you opinion of a product that they don't even own.
like.no.other. is offline
Reply Display Calibration
