Color Space & xvYCC options on my 1080p Samsung LCD - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 05-10-2007, 09:56 AM - Thread Starter
cybersoga's Avatar
I've just got a brand new Samsung 1080P LCD and am curious about these two settings in the TV's picture, detail settings menu - under what circumstances should they be on or off? I have a Toshiba HD-E1 and Sony PS3 connected via HDMI.
Colour Space - Auto or Wide (default: Auto)
xvYCC - On / Off (default: Off)
cybersoga is offline
post #2 of 14 Old 05-10-2007, 10:01 AM
jvernon's Avatar
Well, there won't be any xvYCC color sources for years, except for some upcoming PS3 games and new and expensive Sony camcorders, so I would guess off would be the default.
jvernon is offline
post #3 of 14 Old 05-10-2007, 10:34 AM
David Abrams's Avatar
cybersoga,
jvernon is correct! xvYCC is not being utilized by many sources at the moment and should be left in the off position unless your particular source states that it is mastered for xvYCC.
Best,
Dave
David Abrams is offline
post #4 of 14 Old 05-10-2007, 10:37 AM - Thread Starter
cybersoga's Avatar
Does Colour Space have anything to do with 609 (SD) or 709 (HD)? best left on auto?
post #5 of 14 Old 05-10-2007, 10:55 AM
Cybersoga,
Unfortunately, many manufacturers use terms such as 'wide' and 'normal' when describing color space because they use their own arbitrary settings. More specifically, they do not conform to a standard and; therefore, do not call it as such. In order to verify which color space setting is the best, it is necessary to measure and calculate which one is closest to the standard. Some displays allow for this to be adjusted/calibrated within the service menu allowing for the desired results to be achieved.
Good Pictures!
Dave
post #6 of 14 Old 05-10-2007, 11:01 AM - Thread Starter
cybersoga's Avatar
Thanks guys
post #7 of 14 Old 05-11-2007, 12:00 AM
my_pacman's Avatar
Contray common sense it looks like xvYCC=on and Colorspace=Wide gives you a "good" gamut (one would think that "off" and "Auto" would be the best option for HD/SD-soruces...). At least acordning to hdtvtest.co.uk.
Auto/Off:
Wide/Off:
Auto/On:
Wide/On
http://www.hdtvtest.co.uk/Samsung-LE...alibration.php
my_pacman is offline
post #8 of 14 Old 05-10-2009, 01:54 AM
Edo Glvez's Avatar
Sorry to necrobump this thread. I was doing some research on the samsung color space and xvYCC settings and found the above post stating that the best results were attained with the 'Wide' and xvYCC 'On' settings.
If you dig into the article you will find that they actually used the 'Custom' option to tweak the color space.
Edo Glvez is offline
post #9 of 14 Old 12-02-2012, 01:51 AM
ChromeJob's Avatar
Quoted: 1191 Post(s)
Liked: 623
Send a message via Yahoo to ChromeJob Send a message via Skype™ to ChromeJob
Another necrobump. I just bought a UN40ES6150 (6100 series) and after applying the calibration on lcdtvbuyingguide.com, I decided to go with YCbCr instead of RGB out of my Panasonic BDT215. With the 10pt white balance settings from their reviewer, and Color space in Auto, I switched on xvYCC to see if it "increased detail" as Crutchfield says, or "expanded the color space" as Samsung claims it would. Nope. Only saw a diminishing of color vibrancy in some day and night scenes (e.g. the belly dancer at the gypsy camp) from the FROM RUSSIA WITH LOVE BD. It was a bit like switching from Warm2 to Warm1 or Standard (things get colder, blue shades are crunched, faces lose their "flesh" appearance). Blech.
Since nothing I have really outputs xvYCC, I think it's still a needless feature in search of an application (or dumb users?).
“Phil? Phil Connors?!”
Are ya new here? Please read FAQs and forum stickies. Like posts that help you. Don't ask a question and then disappear.
A: Yamaha RX-V775. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Samsung UN40ES6150, Panasonic DMP-BDT215, Yamaha DVD-S550. Apple TV 4gen. Chromecast 1gen.
ChromeJob is offline
post #10 of 14 Old 12-02-2012, 12:58 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 353
xvYcc does nothing if the source is not xvYcc. At least that's the way it is SUPPOSED to work... xvYCC allows chroma values outside the range of 16-240. If the source you are playing (test patterns, etc.) have no color content beyond 16-240 you get just normal Ycc color space (601 or 709). You don't "add" anything by enabling xvYCC. If the TV does something different for 0-240 color patterns when xvYcc is enabled, something is not right but it might turn out to be useful if you need to expand a limited gamut... it's not SUPPOSED to work that way, but if it does, it might help in some cases.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #11 of 14 Old 12-04-2012, 05:43 PM
Tyrone Burton's Avatar
I had no idea video games used xvYcc. I'm guessing if they do it will say on the case or something like that?
Tyrone Burton is offline
post #12 of 14 Old 12-04-2012, 07:21 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 334
They don't
sotti is offline
post #13 of 14 Old 12-04-2012, 09:22 PM
Originally Posted by sotti View Post
They don't
I know, but will it happen if future? Not that I'm bothered really as honestly I think the picture quality and Color is just fine now.
post #14 of 14 Old 12-04-2012, 10:18 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 334
Not on this generation.
Who knows about next gen.
I do know that most game studios have no clue how they would even start to do that, some definitely do. Truth be told, xvYCC will likely never be implemented for games, getting wide gamut will likely happen via ultraHD.
sotti is offline
Reply Display Calibration
