Basic Guide to Color Calibration using a CMS (updated and enhanced) - Page 53 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #1561 of 1967 Old 03-08-2010, 08:07 AM
spongebob's Avatar
Quoted: 38 Post(s)
Originally Posted by TomHuffman View Post
A CIE chart doesn't show dE values. All it shows is a rough visual indication of hue and saturation errors.
That's what I thought. Was was referred in post #1555?
thx
bob
spongebob is offline
post #1562 of 1967 Old 03-08-2010, 08:09 AM
ElwayLite's Avatar
Thanks Tom, and I do like the AVS disc pattern for Contrast and Brightness.
So, if I feel there is some crush/detail loss at 2.33, then I should set brightness properly and reduce the gamma slider(-3 to -2 or -1) to get closer to a 2.2 curve?
ElwayLite is offline
post #1563 of 1967 Old 03-08-2010, 08:09 AM
spongebob's Avatar
Quoted: 38 Post(s)
I want to comment on this because it has come up before. As I tried to make clear in the original post, the 2.2 advice for setting brightness should only be used as a way making a more precise adjustment to the one you have already made visually using a pluge pattern. In fact, the AVSHD has a kind of pluge pattern for setting brightness that is so precise that no further aid is necessary.
Tom
Where on the disc is that?
thx
bob
post #1564 of 1967 Old 03-08-2010, 08:10 AM
ElwayLite's Avatar
Check the AVS709 thread and download and burn it.
post #1565 of 1967 Old 03-08-2010, 08:10 AM - Thread Starter
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
The dE value of a color is a more accurate and comprehensive way of determining its accuracy than its position on a CIE chart.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
post #1566 of 1967 Old 03-08-2010, 08:11 AM - Thread Starter
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
Any gamma response between 2.2 and 2.35 is fine. Try to get it as linear within that range as possible.
Tom Huffman
Springfield, MO
post #1567 of 1967 Old 03-08-2010, 08:15 AM
ElwayLite's Avatar
When adjusting Tint/Cyan, using your method, I use the dE level too. On the 21% Red vs White, would the dE value be best for this too, or just trying to hit the 21% number?
post #1568 of 1967 Old 03-08-2010, 08:34 AM
bodosom's Avatar
Quoted: 210 Post(s)
Liked: 68
*) I have tried both Gamma 2.25 and 2.33, using the Gamma slider on the tv, and feel 2.33 loses a little bit of detail (appears to crush a bit). It also is not close to the 2.2 gamma at 10% Tom recommends.
Although he takes some pains to clarify this in the first post as well as here and elsewhere I think it's time to modify item 4.
bodosom is offline
post #1569 of 1967 Old 03-08-2010, 08:39 AM
ElwayLite's Avatar
Its looking like I should reset user settings, adjust bright and contrast, tighten up grayscale, then check the gamma slider starting at 0, and see which setting gives me the flattest line between 2.2 and 2.3. Then go back and check the other settings.
post #1570 of 1967 Old 03-08-2010, 08:59 AM
spongebob's Avatar
Quoted: 38 Post(s)
I have it. Wondered what pattern Tom was referring to?
thx
bob
post #1571 of 1967 Old 03-08-2010, 09:21 AM
ElwayLite's Avatar
I assumed it was the standard brightness pattern where you want bars 17 and higher showing and 16 and below off.
post #1572 of 1967 Old 03-08-2010, 09:22 AM - Thread Starter
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
dE is a comprehensive method for grading color difference. 21%-of-white is simply a straightforward way to set the brightness of red correctly. Since the Color control has the biggest effect on color brightness (within a reasonable range of adjustment), it's a good way to adjust the Color control.
Tom Huffman
Springfield, MO
post #1573 of 1967 Old 03-08-2010, 09:26 AM
spongebob's Avatar
Quoted: 38 Post(s)
Tom
Can you look at this reading and tell me why Magenta's de is 28, even though it looks closer than yellow that has a de of 8.9?
This is from a Pio PRO-101FD.
thx
bob
greenminus15cms.zip 0.84375k . file
File Type: zip greenminus15cms.zip (864 Bytes, 30 views)
post #1574 of 1967 Old 03-08-2010, 09:26 AM
ElwayLite's Avatar
Originally Posted by tomhuffman View Post
de is a comprehensive method for grading color difference. 21%-of-white is simply a straightforward way to set the brightness of red correctly. Since the color control has the biggest effect on color brightness (within a reasonable range of adjustment), it's a good way to adjust the color control.
10-4.
post #1575 of 1967 Old 03-08-2010, 09:37 AM
spongebob's Avatar
Quoted: 38 Post(s)
Using, HCFR, when I hover my mouse over a reading on the CIE chart, It gives me a de reading. Am I missing something?
thx
bob
post #1576 of 1967 Old 03-08-2010, 10:05 AM
spongebob's Avatar
Quoted: 38 Post(s)
I have trouble with that pattern
bob
post #1577 of 1967 Old 03-08-2010, 10:13 AM
ElwayLite's Avatar
bob
post #1578 of 1967 Old 03-08-2010, 10:33 AM
spongebob's Avatar
Quoted: 38 Post(s)
hard to distinguish the difference in the flashing bars. I think there are better pluge patterns.
bob
post #1579 of 1967 Old 03-08-2010, 10:52 AM - Thread Starter
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
No, that's just something HCFR provides. It is not part of the CIE chart itself.
Tom Huffman
Springfield, MO
post #1580 of 1967 Old 03-08-2010, 11:19 AM
bodosom's Avatar
Quoted: 210 Post(s)
Liked: 68
That's because you have an Elite monitor (or it's too bright for proper calibration) -- although they might reduce the brightness of the labels in the next version which is also a problem for Kuro monitors in a light controlled environment.
bodosom is offline
post #1581 of 1967 Old 03-08-2010, 02:04 PM
spongebob's Avatar
Quoted: 38 Post(s)
If you guys have HCFR, can you check mile file above (#1573) and see why the magenta Delta E is so high compared to where it is on the chart and compared to the other colors?
thx
bob
post #1582 of 1967 Old 03-08-2010, 02:18 PM
bodosom's Avatar
Quoted: 210 Post(s)
Liked: 68
There's a thread for C-HCFR reports/advice.
bodosom is offline
post #1583 of 1967 Old 03-08-2010, 02:30 PM
spongebob's Avatar
Quoted: 38 Post(s)
Done, but I thought this was CMS related and that most people here used or were familiar with HCFR.
thx
bob
post #1584 of 1967 Old 03-08-2010, 02:34 PM - Thread Starter
TomHuffman's Avatar
Quoted: 701 Post(s)
Liked: 622
I don't know what you are looking at.
Tom Huffman
Springfield, MO
post #1585 of 1967 Old 03-08-2010, 02:45 PM
spongebob's Avatar
Quoted: 38 Post(s)
Using HCFR, I am looking at the Delta E readings for the pri/sec. colors. You can check it in the measurements window under primaries and secondaries or you can hover the mouse over the reading on the CIE chart. Magenta DE is 28 and looks to be fairly close on the chart where it should be. Other colors are much closer (Delta E) Sorry if I'm not being clear enough.
bob
post #1586 of 1967 Old 03-08-2010, 02:56 PM
glaufman's Avatar
What Tom's saying is that when we open your file, the dE for the Magenta primary is 7.4, not 28, whether you look at it in the measurements window or hover of the Magenta in the CIE chart.
-Greg
glaufman is offline
post #1587 of 1967 Old 03-08-2010, 02:59 PM
PlasmaPZ80U's Avatar
Quoted: 1970 Post(s)
Liked: 565
thx
bob
I've replied to your post in the ColorHCFR thread. It appears magenta is 7.1% too dim relative to the target luminance.
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #1588 of 1967 Old 03-08-2010, 03:40 PM
spongebob's Avatar
Quoted: 38 Post(s)
I must be having a twilight zone day, then
It says DE 28 when I open it. I'll post again after i just confirmed that.
I did get your response on the other thread, Plasma. Thanks
bob
post #1589 of 1967 Old 03-08-2010, 03:55 PM
glaufman's Avatar
Check what you have set as your references.
-Greg
glaufman is offline
post #1590 of 1967 Old 03-08-2010, 04:35 PM
spongebob's Avatar
Quoted: 38 Post(s)
REC 709.
thx
bob
Reply Display Calibration
X Rite Eodis3 I1display Pro , X Rite Cmundis Colormunki Display , X Rite Eye One Display Lt , Calman 4 0 Calibration Software Home License , Aemc Ca813 Peak Function Lightmeter 200 000 Lux Range 0 01 Lux Resolution 3 Accuracy
