Basic Guide to Color Calibration using a CMS (updated and enhanced) - Page 58 - AVS Forum | Home Theater Discussions And Reviews
 19Likes
post #1711 of 1967 Old 05-20-2011, 07:25 AM - Thread Starter
TomHuffman's Avatar
Quoted: 770 Post(s)
Liked: 660
Originally Posted by dominickwok View Post
So you need to increase Saturation to get the perfect RGB combination (i.e. xy coordinate) of 107% / 107% / 0%. You get it?
This will provide excessive luminance. 100%, 100%, 0% is correct. RGB percentages are useful only for a human interface that provides RGB controls (Lumagen Radiance and Samsung CMSs come to mind). The Epsons have an HSL interface.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is online now
post #1712 of 1967 Old 05-20-2011, 03:01 PM
jmoakk's Avatar
Where do I get the correct color % combination for each color? Like 100%, 100%, 0 for yellow? Also I didn't know I could use the cie chart in live reading mode when displaying one color windows. That alone helped me a lot last night when I did another calibration. It let me see which way the color was moving when adjusting hue and sat.
jmoakk is offline
post #1713 of 1967 Old 05-20-2011, 03:04 PM
Kilgore's Avatar
Quoted: 728 Post(s)
Liked: 435
What calibration software are you using?
Kilgore is offline
post #1714 of 1967 Old 05-20-2011, 03:07 PM
jmoakk's Avatar
hcfr, I know where the reading is in the software. I just dont know what the reading should be for each color.
jmoakk is offline
post #1715 of 1967 Old 05-20-2011, 08:58 PM
dominickwok's Avatar
You can refer to the following post:
http://www.avsforum.com/avs-vb/showt...7#post16166537
In that post, it points you to the following link to download an Excel spreadsheet:
http://www.avsforum.com/avs-vb/showthread.php?t=1111066
The "Calibration Aid" tab of the spreadsheet lists out the correct RGB% for each 100% saturated primary/secondary (as well as for each 75% saturated primary/secondary). Please note that the RGB% (e.g. 107% / 107% / 0% for 100% sat. yellow) is the % shown by HCFR - that's nothing to do with anything else such as external video processor).
dominickwok is offline
post #1716 of 1967 Old 05-25-2011, 10:25 AM
Wizziwig's Avatar
Quoted: 1241 Post(s)
Liked: 897
Hi Tom,
Excellent guide. Any chance you could update it for Lumagen Radiance owners?
I'm mostly confused as to why the Radiance offers both a "Color Gamut" and "Color Decoder" setting under it's CMS system. Can't you adjust everything using just the Color Gamut controls? Why would you ever need to mess with the color/hue controls under the ColorDecoder menu?
Also, any general tips for calibrating the JVC RS40? It's difficult to decide what to adjust on the projector vs. on the Radiance.
Wizziwig is offline
post #1717 of 1967 Old 05-25-2011, 10:44 AM - Thread Starter
TomHuffman's Avatar
Quoted: 770 Post(s)
Liked: 660
The color decoder controls are legacy features that the CMS renders obsolete.
Use the PJ's controls to get the gamma/grayscale close, and then refine with the Lumagen's controls.
Tom Huffman
Springfield, MO
post #1718 of 1967 Old 05-27-2011, 01:50 PM
ericlhyman's Avatar
Originally Posted by krasmuzik View Post
zoyd
check out the front projector forum - Hugh2/hughman did that very study of changes to color control impact on the CIELCH measures (same dE as CIELUV) of his JVC - but it is rumoured the firmware version may behave slightly different. I would say it is generally the case that you have to shift color brightness significantly before color saturation moves with video color controls - he posted several sets of numbers on that starting here....
http://www.avsforum.com/avs-vb/showt...&#post10426396
I have observed similar with Sony Ruby/Pearl - the dL hit to move in the primaries with the color control per spec resulted in much worse dE than leaving primaries be and only shorting dL a bit under spec.
Of course Tom's post was how to use a CMS and video decoder that is capable of getting you the perfect result - as his other posts on color demonstrate - sometimes this can be an exercise in futility in picking the worst vs. best compromises.
The only thing I would add is to repeat the measures with 100% patterns - as sometimes displays can have settings impacting bright colors like DLP's BrilliantColor(tm) or any dynamic iris - which maybe can be turned off - but if not - compromise between light/dark colors time!
Also if doing tint with this method of sensoring rather than filtering - I would do it after greyscale not before - because secondaries shift with greyscale - with filters this is irrelevant because you have bluescale not greyscale!
Using red brightness to set color levels will only work if your set has no red push - if it does then the color will probably be too low overall - so again measure blue/green levels to find the compromise in between.
I also use 100% white for greyscale to first establish my clipping limits - I find hot white colortemp blowouts much more annoying than the tweak to contrast they give.
Did you change your settings for the Ruby in the service menu or regular user menu? Do you have any instructions on how to use the Ruby's color management system in the user menu? I find it difficult to use.
ericlhyman
ericlhyman is offline
post #1719 of 1967 Old 05-27-2011, 02:17 PM
ericlhyman's Avatar
Originally Posted by TomHuffman
Thus, I think that a better method for setting Contrast is to just set it at a level consistent with good color performance and reasonable light output for a given display device. What's a reasonable level?
CRT tubes: 35 fL
Plasma: 35 fL
LCD flat panel: 50 fL
Digital rear projection: 35 fL
Digital front projection: 15 fL
If you use HCFR, you can determine fL by multiplying the peak output (100% Y) by 0.29
What would the recommendation be for an SXRD (LCOS) rear projection set?
ericlhyman
post #1720 of 1967 Old 09-08-2011, 12:45 PM
dpnaylor's Avatar
Greetings all.
I have been doing calibration now as a hobby on my own TV's as well as a few families TV's for a few years and have never really run into something I couldn't figure out.. It has been a while since I have done this and I ran into a question on a friends LG Plasma.
This LG Plasma is about 7yrs old. When I go into the color settings for the unit it has a USER option. Selecting the user option then brings up a RGB screen with a slider for each R, G, B, from minus 30 to plus 30 I believe for each color. Now normally there are two sets, one for Contrast and the other for Brightness to be able to set the grey scale properly but this set only has one. I know most computer monitors only have one set of sliders. So would I put up a 100% white pattern on the screen set my ref in Calman to D6500 and adjust the sliders till I am as close as I can get, probably starting with a warm setting?
I am trying to get the model number from the TV so I have a bit more info. I might be able to get into a service menu to give me some more options on this thing. I am using an eye-one pro meter with the Calman software.
Thanks guys! Any help appreciated!
Dave N
Joppa, Maryland
dpnaylor is offline
post #1721 of 1967 Old 09-08-2011, 01:43 PM
serialmike's Avatar
CRT tubes: 35 fL
Plasma: 35 fL
I dont believe this chart is correct. There is no reason whatsoever not to calibrate an LCD to 35ftl also. None the black level on bad lcd sets is .015 at worst generally.
35 is the standard and all sets should be calibrated to this. This is one reason why people dont liek the look of LCD. They are being calibrated incorrectly.
This made sense when black levels of lcd were .05 and higher in order to get some kind of contrast. It is no longer needed.
serialmike is offline
post #1722 of 1967 Old 09-08-2011, 02:27 PM - Thread Starter
TomHuffman's Avatar
Quoted: 770 Post(s)
Liked: 660
I agree. This is out of date.
Edit: In fact, this was edited some time ago to 30-50fL. I just edited it again to 30-40fL.
Tom Huffman
Springfield, MO
post #1723 of 1967 Old 09-08-2011, 03:05 PM
serialmike's Avatar
Good deal When I saw you posted I got worried I drew your ire. So often when I post something against what a sticky says or goes against the grain I get into.
Whew
post #1724 of 1967 Old 02-18-2012, 05:54 PM
SecondaryColors's Avatar
1) Setting Contrast
Why is 30 - 40 ftL the recommended LCD contrast setting? If movie theaters use 12 - 14 ftL settings, then I want to try those settings to see if they'll replicate the movie theater experience on the LCD screen. But if the 30-40 ftL are the standards used by post production people, then I'll give it a shot because accuracy is important.
2) Setting greyscale:
If my television is missing greyscale controls like RGB Cuts or Gains, then what can be done? Can I influence greyscale with other controls -- such as color temperature settings, dynamic range standard / out of standard settings, black expansion for shadow detail settings, contrast control, and C.M.S settings?
SecondaryColors is offline
post #1725 of 1967 Old 02-18-2012, 05:58 PM
PlasmaPZ80U's Avatar
Quoted: 2233 Post(s)
Liked: 683
Originally Posted by SecondaryColors View Post
1) Setting Contrast
30-40 fL is for direct view displays such as LED/LCD and Plasma Flat-Panel displays
12-14 fL is for front projectors
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha RX-A2070, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is online now
post #1726 of 1967 Old 02-19-2012, 03:31 AM
If your set has any setting related to color temperature, try the setting of warm / warm1 / warm2. Usually this sets it closer to D65 than any setting of normal / standard / cool, etc.
post #1727 of 1967 Old 02-19-2012, 11:02 PM
rickardl's Avatar
Quoted: 123 Post(s)
Liked: 95
Isn't 35 only for dimly lit/dark rooms?
I would love to have some kind of equation/calculation which takes into account the ambient lighting of the room when coming up with the target contrast ftL.
Now, it seems 35 ftL is just the lower end of the scale which probably is too dark for most people's viewing conditions.
rickardl is offline
post #1728 of 1967 Old 02-20-2012, 12:28 AM - Thread Starter
TomHuffman's Avatar
Quoted: 770 Post(s)
Liked: 660
No. 35 ft-L is the recommended peak luminance of color monitors under ordinary viewing conditions. See SMPTE RP 166.
Tom Huffman
Springfield, MO
post #1729 of 1967 Old 02-20-2012, 01:24 AM
rickardl's Avatar
Quoted: 123 Post(s)
Liked: 95
I don't have RP 166, but does the doc specify what "ordinary viewing conditions" are?
rickardl is offline
post #1730 of 1967 Old 02-20-2012, 10:20 AM
den110's Avatar
Hi everyone
I have a quick question regarding calibration. How often should you recalibrate your projector? I have an Epson 8700UB. I calibrated it when it had 0 hrs on the bulb using Eye One Lt, AVSHD disc and HCFR software. It now has 500 hrs. Should I do a recalibration?
"It's time to nut up or shut up."
den110 is offline
post #1731 of 1967 Old 02-20-2012, 10:55 AM
airscapes's Avatar
Quoted: 379 Post(s)
Liked: 302
Originally Posted by den110 View Post
Hi everyone
Yes, typically if you are going to pay someone to do the calibration you would wait at least 200 hours to allow the lamp to settle in. I now have my own equipment and plan to check my own projector every 500 hours (6 months)
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #1732 of 1967 Old 02-20-2012, 12:09 PM - Thread Starter
TomHuffman's Avatar
Quoted: 770 Post(s)
Liked: 660
  • All light sources in use during picture assessment or adjustment should approximate D65.
  • The ambient light reflected from the screen should be the lowest possible level.
  • Reflections on the monitor screen should not cause a perceptible impairment from the normal viewing position.
  • Illumination at the viewing area should be between 20-100 lux.
Other than warning against direct light reflecting off the screen surface, there is no requirement for "dimly lit/dark rooms".
Tom Huffman
Springfield, MO
post #1733 of 1967 Old 02-20-2012, 02:04 PM
gregr's Avatar
The most important factor (other than minimizing ambient reflected light) related to the brightness of a direct view monitor is the brightness of the surround - i.e. the lighted area around the screen that is visible to the viewer. It should be D65 and 10% of the screen brightness, i.e. 3.5 fL. The brightness of the surround changes the optimum gamma and optimum brightness of the monitor. Those are the specified conditions for telecine rooms, so you would ideally duplicate those conditions in your direct-view monitor viewing room.
Greg Rogers
Video Engineer/Product Designer
gregr is offline
post #1734 of 1967 Old 02-21-2012, 07:28 AM
rickardl's Avatar
Quoted: 123 Post(s)
Liked: 95
rickardl is offline
post #1735 of 1967 Old 02-21-2012, 09:53 PM
post #1736 of 1967 Old 03-05-2012, 04:00 PM
tbaudoin's Avatar
So, what's the preferred method, measure the fL avg behind the screen with a handheld, add ~10%, adjust monitor backlight or contrast to be at +10% (38.5 fL) as the starting point. Or, is there a valid way to use a colorimeter for this? T
tbaudoin is offline
post #1737 of 1967 Old 03-14-2012, 12:29 AM
If I warmed up my tv for 60 minutes before calibrating, does that mean that I have to warm up my tv for 60 minutes before watching movies afterwards?
post #1738 of 1967 Old 03-14-2012, 04:07 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
no, 1 hour warm-up is overkill. I've never measured any changes in color/gray scale even after 5 minutes of on time. warm-up is more important for the meters but 20 minutes for those are adequate.
edit: [was referring to plasma display, measured change in Y over 1 hour was 1%, maximum shift in gray scale 0.3 dELuv ]
zoyd is offline
post #1739 of 1967 Old 03-14-2012, 04:31 PM
breadvan's Avatar
A good article if you have not read it yet
http://www.spectracal.com/downloads/...s%20Enough.pdf
breadvan is offline
post #1740 of 1967 Old 03-14-2012, 07:18 PM - Thread Starter
TomHuffman's Avatar
Quoted: 770 Post(s)
Liked: 660
I just tested a Samsung LED, and I got very different results.
I would agree that CCFL LCDs take forever to warm up. You may still get meaningful increases in luminance 30 minutes after turning it on. However, LED LCDs--at the least this Samsung--are much more stable than the SpectraCal test suggests. An hour after turning it on, its luminance was down only 2.8%, which is a negligible change.
More interesting to me is the change in chromaticity, which, although small, is probably worth considering.
In my opinion, 30 minutes is adequate warm-up time, but this is obviously a matter of judgment and practical time constraints.
Tom Huffman
Springfield, MO
Reply Display Calibration
X Rite Eodis3 I1display Pro , X Rite Cmundis Colormunki Display , X Rite Eye One Display Lt , Calman 4 0 Calibration Software Home License , Aemc Ca813 Peak Function Lightmeter 200 000 Lux Range 0 01 Lux Resolution 3 Accuracy
