Need Help - Display anomaly on Panasonic TH-42PX75U - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-27-2007, 06:09 PM - Thread Starter
StevieD's Avatar
I posted this on the Plasma forum without luck so far - other than a suggestion to post this here:
I know this will be an easy one for someone - I just bought a Panasonic TH-PX75U Plasma TV. Hooked it up to my cable box (Comcast) (HD and DVR), bingo - display is working fine, picture looks great. However I have a small red "bug" which is sequentially moving around my display (like a screen saver) - It is:
CHK
D:2C
DG:23
The second and third lines change slightly (different numbers) when I change channels with my cable Stb. I have tried turning off the display and turning back on -no luck. What is this? How do I get rid of it?
Hope someone can help.
Steve
Steve Doyon
Ashburn, VA
StevieD is offline
post #2 of 4 Old 05-29-2007, 10:39 AM
HoustonPerson's Avatar
take a picture of it if you can. It really sounds like something weird you are getting from Comcast. Do you have ANT only you can try? (by pass the comcast box). Also, you may be getting something from Closed Caption and/or information bar......can those be turned off on this model?
HoustonPerson is offline
post #3 of 4 Old 05-29-2007, 10:53 AM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
Unplug the TV and see what happens.
regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #4 of 4 Old 05-29-2007, 10:55 AM
Ratman's Avatar
Quoted: 1291 Post(s)
Liked: 1032
Try unplugging the cable box and TV from power for a few minutes (to reset).
Ratman is offline
Reply Display Calibration
