Samsung Service Menu Calibration Guide - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 123 Old 08-11-2011, 02:36 PM
alwilli's Avatar
I don't really know. See this thread. This is all the information I could ever find on the subject.
http://www.avsforum.com/avs-vb/showt...r+decoder+menu
Alvin
alwilli is offline
post #122 of 123 Old 08-11-2011, 03:00 PM
chruzek's Avatar
Originally Posted by alwilli View Post
I figured out what controls luminance but never figured out what combination of adjustments would make it respectable. CBB, CRR, CBG, CRG (movie) is what you would adjust but they have a weird interactive behavior. If your overall Delta E's 94 are below 3, I would not worry about it.
Alvin
The Delta E's in HCFR for Greyscale and Colors are shown in the attached image. I am not sure if these are Delta E 94 values. Can you enlighten me (no pun intended).
chruzek is offline
post #123 of 123 Old 09-08-2012, 10:17 PM
PiratesCove's Avatar
Quoted: 82 Post(s)
Liked: 176
Does anyone know how to restore the Resolution/Time displayed when pressing "info". on the remote
A Best Buy service tech changed a value in the service menu and now the Resolution/Time is plain and grey now.
Also my Menu Screen has a purple square in the center where it used to be translucent.
Is there a service menu fix? A week later another Best Buy tech had no clue how to fix this.
PiratesCove is offline
Reply Display Calibration
