How to calibrate a front projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-30-2007, 01:10 PM - Thread Starter
rotelmania's Avatar
I am going to buy eyeonedisplay calorimeter to calibrate my projector. Where do you put the calorimeter? Do you put it on the screen? How would one do that? What kind of software I should use with the calorimeter?
thanks in advance
rotelmania is offline
post #2 of 10 Old 08-30-2007, 01:40 PM
angryht's Avatar
Start reading here:http://www.avsforum.com/avs-vb/showthread.php?t=737550
I would suggest getting the eye-one LT - because it is cheaper than the display 2 and you should use either Cal Man software or HCFR. The software that comes with the eyeone probes is not as good for this application. I would also recommend using the getgray dvd. Keep in mind that these are quick and dirty answers to your fairly general questions. Keep asking them.
-Greg
angryht is offline
post #3 of 10 Old 08-30-2007, 01:46 PM
angryht's Avatar
Most of the time people mount it to a tripod and angle it up towards the screen - about 3 to 4 inches away. Be careful not to measure the shadow.
-Greg
angryht is offline
post #4 of 10 Old 08-30-2007, 05:15 PM - Thread Starter
rotelmania's Avatar
So the calorimeter does not need to be placed right up against the screen?
post #5 of 10 Old 08-30-2007, 07:35 PM
angryht's Avatar
Well, no. Actually, there are two ways to do it with a FP: 1. Aim the probe towards the projector. or 2. Aim it towards the screen. The trick is that when you aim it at the screen, you need to make sure that you are not just aiming at the shadow made by the probe. Most people have their projector mounted on the ceiling. That means that the probe is usually on a tripod aimed upwards at about a 45 degree angle at the screen. So, I guess it is right up against the screen but with enough space to read the light not the shadow. Does that make sense? What type of FP do you have?
-Greg
angryht is offline
post #6 of 10 Old 08-31-2007, 11:02 AM
JDLIVE's Avatar
Quoted: 95 Post(s)
Liked: 51
Send a message via Yahoo to JDLIVE
With a front projector setup, the screen is reflecting the light from the projector back to the viewing area. This is different than most television displays (either flat panel or rear projection) where the light source is behind the screen. As angryht notes, you can either measure the light source directly, or the reflections off the screen. You can't measure the screen itself directly.
JDLIVE is offline
post #7 of 10 Old 09-01-2007, 10:01 AM
davehancock's Avatar
Quoted: 111 Post(s)
Liked: 60
As the screen does have an effect on the color, to get an accurate measurement you need to either use method 2, OR determine an offset (in terms of x and y) between methods 1 & 2 and apply that offset to method 1. The principal problem with method 2 is that very little light is reflected from the screen at the lower IREs and many colorimeters are not sensitive enough to accurately read at these very low levels (+ are very sensitive to stray light).
Dave Hancock
davehancock is offline
post #8 of 10 Old 01-07-2013, 03:17 PM
wingman1659's Avatar
Just so I (and anyone else) can be clear. To get an offset adjustment would you recommend measuring about 80IRE off the screen at an angle, then rotating the sensor to be in the light path of the projector and take a measure at the same IRE. Then calculate the offset that way?
wingman1659 is offline
post #9 of 10 Old 01-07-2013, 03:23 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Depending on your application, if you NEED to read from the projector, you can simply create a profile in CalMAN 5 using the same meter with the reference readings being from the screen and the target measurements being from the lens.
I would read directly from the screen unless your meter is not sensitive enough to read low light.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #10 of 10 Old 01-08-2013, 09:52 AM
jdoostil's Avatar
The screen is part of the system. Aiming at the projector will not give you an accurate calibration
ISF certified in 2008
ISF Level II certified in 2010
ISF instructor certified in 2012
ISF International Trainer since 2014
ISFJasonD65@gmail.com
Serving Florida
jdoostil is offline
Reply Display Calibration
