AVS HD 709 - Blu-ray & MP4 Calibration - Page 108 - AVS Forum | Home Theater Discussions And Reviews
 77Likes
Old 02-16-2012, 03:41 PM - Thread Starter
alluringreality's Avatar
Quoted: 57 Post(s)
Liked: 64
Originally Posted by boreas21 View Post
Should I do the calibration using avs hd 709 if I only watch satellite tv with two receivers. I mean I can connect the TV - LG37LK450 to my computer but does that make sense?
Computers typically do not output standard video levels. So no, it is not reasonable to expect that calibrating for the computer would work for satellite.
alluringreality is offline
Old 02-21-2012, 08:10 AM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Hi everyone, this thread is great - so much information.
I have a few questions I liked to ask before going ahead to buy equipments for calibration.
My Setup:
Epson 8100 Projector
DIY 90" Painted Gray Screen
HTPC - Windows 7 Media Center
What I Would Need
EyeOne LT kit
HCFR software
HD Basics disc
Greyscale & Colour Calibration For Dummies
I assumed I want to playback the disc with Windows 7 Media Center, since it will be my primary video source?
Am I missing anything else?
Thanks much!
smokarz is offline
Old 02-23-2012, 03:41 AM
SecondaryColors's Avatar
DVE-HD Basics and AVSHD709 gave me different black settings. The results should've been identical. But with DVE-HD, I can go darker a few notches.
SecondaryColors is offline
Old 02-23-2012, 05:14 AM - Thread Starter
Quoted: 57 Post(s)
Liked: 64
Typically you want to play calibration video with the same video player that you'll use for playing other video, such as movies.
Old 02-23-2012, 05:22 AM - Thread Starter
Quoted: 57 Post(s)
Liked: 64
If you go with the description in the PDF for the second pattern the two should be generally close. I believe the first level above black is 20 on DVE, and I think Avia uses 19. So in certain conditions DVE will allow you to clip off a few video levels above black.
http://www.avsforum.com/avs-vb/showt...8#post20767638
Old 02-23-2012, 04:40 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
hey guys, so how many hours should i have on the bulb before calibrating?
some says 40, some says 200. what's the general consensus?
if i need to wait for 200 hours, it's going to be over a year before i get there.
smokarz is offline
Old 02-23-2012, 05:01 PM
airscapes's Avatar
Quoted: 357 Post(s)
Liked: 289
If you are doing it yourself do it as soon as you want. The idea of waiting is so you don't spend $400 and 4 months later need a touch up ..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Old 02-23-2012, 05:30 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
great.
can anyone confirm if i can use the AVS HD 709 disk with HCFR?
smokarz is offline
Old 02-23-2012, 06:29 PM
Jim McC's Avatar
Quoted: 123 Post(s)
Liked: 62
alluringreality, can you explain in simple terms the best way to set contrast? My display is a Mits. DLP projector, the HC3800. I know the 3 rules of setting contrast(No clipping, no color shifting, no eye strain) but which one takes priority? My projector is clippping red. Do I reduce contrast until clipping disappears(-12)? Or do I raise contrast until pinkish color shift starts(-4)? Or do I disregard both of these things and go with the result of the contrast pattern, which is pinkish(17)? Thanks.
Jim McC is offline
Old 02-23-2012, 06:54 PM
kjgarrison's Avatar
great.
Yes, you can.
kjgarrison is offline
Old 02-24-2012, 05:31 AM - Thread Starter
Quoted: 57 Post(s)
Liked: 64
I prefer to use a meter to set contrast.
Usually you don't have to worry about eye strain on most projectors, so clipping or color shift would be the main consideration. Clipping and color shift are typically related on most displays. What I mean is that if red clips before green and blue you will have a color shift away from red. Typically the color shift will happen where the color clips or a few levels lower. If you can objectively judge color shift, then probably use color shift as the primary consideration. When judging color shift it would make sense to use something like the grayscale ramp or APL clipping pattern, to limit the amount of information above reference white.
If the projector is subjectively bright enough for you, use the most conservative setting of -17. If you prefer to make the image brighter, use the higher setting of -4. It sounds like 17 may be too high and introduces color shift or has negative effects on the color patterns in Misc. Patterns A.
Old 02-24-2012, 12:31 PM
Jim McC's Avatar
Quoted: 123 Post(s)
Liked: 62
Thanks alluringreality.
Jim McC is offline
Old 02-25-2012, 02:17 AM
visca blaugrana's Avatar
Originally Posted by visca blaugrana View Post
@alluringreality
I have now completed the making of the iso file and it plays fine on my Philips BDP9500.
All.
I am at the moment without a meter, so I was hoping someone could try to download the iso file and burn it and test the 75 & 100% compared with the one on the avsHD disk, just to know if they are right
http://www.2shared.com/file/-EcaaQ3F/AmpLiu.html
thank you
Just to confirm what I already said. the above test patterns have been verified and is OK. the new link contain the same patterns but in full screen - they have also been verified.
http://www.2shared.com/file/GIpF32UT/AmpLiu-full.html
If anyone have any experience in setting up a menu system, any would like to help me a bit, it would be greatly appreciated, I have been trying Multi HVSHD but have nothing but problems with it on my laptop.
visca blaugrana is offline
Old 02-25-2012, 12:35 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
hi everyone.
i've downloaded the HDMV version. i'll then mount it to a virtual drive as a blu-ray disc.
i'll then launch it from Total Media Theater 5.
my question is:
in calman source selection, which one should i select?
- AVS calibration disc 1.2b
- AVS calibration disc 1.3
- Manual Control
thanks
smokarz is offline
Old 02-25-2012, 05:46 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
hi everyone.
my question is:
- Manual Control
thanks
nevermind. i mounted with Daemon tools i tried to launch it with TMT5 but the disc is not recognized.
looks like i need to download the AVCHD version.
smokarz is offline
Old 02-26-2012, 04:58 PM
Razz1's Avatar
my question is:
- Manual Control
thanks
I would also like to know this. Why hasn't Calman updated their software to reflect the latest updates?
Razz1 is offline
Old 02-27-2012, 06:46 PM
dunan's Avatar
Quoted: 62 Post(s)
Question - I have a sony bravia 46v5100 and am using the blu ray AVCHD version. I have set the black levels correctly but am getting confused on contrast. No matter how high I set the contrast I still see all the lines, so if that happens, where do you stop?
The blu ray player I have is a sony BDP S360 and seems to have only the most basic of settings, as I've heard that if there is a contrast problem then it could be a setting on the player.
Any suggestions?
dunan is offline
Old 02-27-2012, 08:08 PM - Thread Starter
Quoted: 57 Post(s)
Liked: 64
I am not familiar with your display, but my Sony has very little color shift at the maximum picture setting. My main point is simply that it's possible the maximum picture setting may be fine.
Old 02-27-2012, 08:12 PM - Thread Starter
Quoted: 57 Post(s)
Liked: 64
The CalMAN settings have to do with the automation they have built in, where the program can change the pattern. If you're changing the pattern manually it's doesn't apply. I would guess that it's probably some work to program the automation, so that's likely why it remains on the previous versions. For the most part I'm guessing, because the only automation I've used in CalMAN is with their computer pattern generator software.
Old 02-28-2012, 08:51 AM
dunan's Avatar
Quoted: 62 Post(s)
Mine has a pretty distinct difference between 100 and where its set at, 81 (factory). I can see all bars up to 100 without color shift (pink hue) but its far too bright to use. The way I take it, there isnt supposed to be any white clipping like there is for the blacks, correct?
dunan is offline
Old 02-28-2012, 10:55 AM - Thread Starter
Quoted: 57 Post(s)
Liked: 64
Unless doing so causes other issues, generally with LCD based TVs (including most LED models) the recommendation is to use a very low backlight setting and a high contrast setting. If the lowest backlight setting is too bright, it's reasonable to also lower contrast (picture).
Yes, ideally the color clipping pattern in Misc Patterns A would go beyond the 235 marks. Not all displays can be as bright as LCD based TVs, so with other display types giving up limited contrast may be less reasonable.
Old 02-28-2012, 12:19 PM
dunan's Avatar
Quoted: 62 Post(s)
Interesting, the backlight is at its lowest setting unless it gets really bright in the room for whatever reason then I bump it up a few notches but 99% of the time it's always minimal.
I usually watch tv in the evening with very little light so bumping the contrast up any more than 81 on this particular unit is eye straining even though I can still see all the bars. Apparently it's difficult to get a good contrast setting without some sort of hardware calibration. Since I can still see the bars I would assume I would have to set it up to where it 'looks good' without eye strain?
dunan is offline
Old 02-28-2012, 03:44 PM - Thread Starter
Quoted: 57 Post(s)
Liked: 64
If you don't have a way to measure the light output of the display, and there's no noticeable clipping or discoloration, all you can really do is to set it for whatever white-level you consider reasonably bright but not too bright.
Old 02-29-2012, 08:11 AM
AVS66's Avatar
I just pained my room and wanted to re-calibrating my Mits HC3800. However, I lost the blue filter glass. Where can I get one?
AVS66 is offline
Old 02-29-2012, 10:40 AM - Thread Starter
Quoted: 57 Post(s)
Liked: 64
There are some options mentioned in the PDF such as the glasses from http://www.costore.com/THX/welcome.asp
Old 03-02-2012, 07:30 AM
MPBGUITAR's Avatar
Hello people of the forum I'm new here and you guys would like me to calibrate my tv ajudassem.Quero AVSHD by 709 so that n know how, lack precision in adjusting d sharpness, backlight and other settings of you would like to know if there is a complete tutorial or someone I teach the steps to get my perfect image according to a calibration done well, as this is my doubt of you would like the collaboration forum! My TV is LG LCD lh50yd 42!
Grateful.
MPBGUITAR is offline
Old 03-02-2012, 10:28 PM
Old 03-02-2012, 11:08 PM
Quoted: 1448 Post(s)
Liked: 601
Grateful.
Welcome.
There is a fairly good tutorial on the top menu of the DVD.
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is online now
Old 03-05-2012, 04:39 PM
tbaudoin's Avatar
I'm really glad you said this. My 929 is my first real backlit. I kept jacking with this concept on a Rear projection sony LCD, until I realize that the key for getting a reasonably good picture (read left the adjustments alone for more than a week) was adjusting for contrast and keeping the white at least slightly clipped, else it just didn't seem to come alive. Now I'm in the process of figuring out, with the aid real tools, if I am being fooled completely. I like to see data.
tbaudoin is offline
Old 03-06-2012, 07:36 PM
smokarz's Avatar
Quoted: 30 Post(s)
Liked: 83
Anyone able to mount either version of the blu-rays with Daemon Tools and play it with TMT5?
i can't seem to get either version to play.
smokarz is offline
Lcd Hdtv , Led Hdtv , lg bp530
