AVS HD 709 - Blu-ray & MP4 Calibration - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 85Likes
post #361 of 4541 Old 01-29-2008, 08:27 AM - Thread Starter
alluringreality's Avatar
Quoted: 57 Post(s)
Liked: 65
Can anyone, not running AVG, give any more information regarding Norton and Kapersky that David Susilo reported as indicating a virus? I uninstalled AVG and installed the Kapersky trial, updated, and it reports nothing. The online Kapersky file scanner could not be used because the file is too large. Norton doesn't seem to have a trial, so I can't check what it's reporting. From now on, if anyone reports anything other than what seems to be a spurious AVG report, please include a screen shot using the avsforum attachment. The way to do a screen shot in Windows is to press the print screen button, then paste it into paint or another image editor where you can crop and save.
alluringreality is offline
post #362 of 4541 Old 01-29-2008, 09:29 AM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 193 Post(s)
Liked: 154
Originally Posted by rover2002 View Post
The latest which i assume is 1.5. After hooking her up to the net the MSG was i'm up to date
You are useing DVD-R ?
Yes, DVD-R. You are also using DVD right?
GetGray is offline
post #363 of 4541 Old 01-29-2008, 10:24 AM
Kilgore's Avatar
Quoted: 728 Post(s)
Liked: 435
My F-Secure antivirus program detected no viruses on the AVCHD Beta2.exe file.
Have you guys who are finding this virus considered the possibility that this virus was already on your machines before you downloaded this file, and it attached itself to the file?
Have you guys done a full system scan to see if any other files on your machines are infected?
Kilgore is offline
post #364 of 4541 Old 01-29-2008, 10:38 AM
rover2002's Avatar
After checking Samsung HK site it seems i was not up to date. Iv now updated via CD to 1.5 and will check tomorrow to see if the AVC HD disc still works.
rover2002 is offline
post #365 of 4541 Old 01-29-2008, 10:57 AM
GetGray's Avatar
Quoted: 193 Post(s)
Liked: 154
Thanks, much appreciated.
GetGray is offline
post #366 of 4541 Old 01-29-2008, 11:34 AM
rmw82's Avatar
Just to let everyone know... My AVG software detected a virus this morning as well attached to the AVS_HD_Beta1.exe file. But, is it just an AVG thing?
rmw82 is offline
post #367 of 4541 Old 01-29-2008, 12:14 PM
jimwhite's Avatar
many of these questions should be going to the AVG developers....
Jim White
St. Petersburg, FL
jimwhite is offline
post #368 of 4541 Old 01-29-2008, 02:10 PM
do not freeze's Avatar
at this point, it really looks like the anti-virus is wrong.
do not freeze is offline
post #369 of 4541 Old 01-29-2008, 06:32 PM
BRILL's Avatar
My Trend Micro Internet Security 2008 shows virus too. also downloaded the files and the RARs show empty once I unrar
Bri
'I have found some kind of temporary sanity in this...' - Maynard
BRILL is offline
post #370 of 4541 Old 01-29-2008, 10:39 PM - Thread Starter
Quoted: 57 Post(s)
Liked: 65
I don't know what the mention of RAR is about because that's a different compression format. I uninstalled Kapersky, downloaded the Trend Micro Antivirus trial, updated, redownloaded the AVCHD, and ran a scan on the folder. The program deleted some internet cookies and that was it. Trend Micro did not indicate anything about a virus on the computer that created the files.
Again, if someone can confirm the report that Trend Micro singles this file out, please provide a screen shot. The way you screen capture in windows is to press print screen. You can then paste into paint or a similar program in order to crop and save. You can attach a file here in avsforum, and the image can be put in a zip file if the resolution exceeds the image resolution allowed.
post #371 of 4541 Old 01-29-2008, 10:53 PM - Thread Starter
Quoted: 57 Post(s)
Liked: 65
post #372 of 4541 Old 01-30-2008, 09:28 AM
rover2002's Avatar
Still works
post #373 of 4541 Old 01-30-2008, 10:16 AM
denze's Avatar
I scanned AVCHD Beta2 (.exe) with NOD32 Update 2836 (20080130). It's clean as far as I can tell.
denze is offline
post #374 of 4541 Old 01-30-2008, 04:34 PM
Scott_R_K's Avatar
Quoted: 30 Post(s)
Originally Posted by alluringreality View Post
Can anyone confirm the third item here http://forum.grisoft.cz/freeforum/re...,backpage=,sv= ?
Just downloaded "AVCHD Beta2.exe" again and ran AVG 7.5.516 269.19.16/1251 updated today 01/30/08 and all is well . AVG DID NOT detect a Trojan this time .
No false positive .
Scott............
"Home Theatre is a Journey , not a Destination "
Scott_R_K is offline
post #375 of 4541 Old 01-30-2008, 05:05 PM
GetGray's Avatar
Quoted: 193 Post(s)
Liked: 154
Still works
Thanks, I'll update mine too and see if it fixes it.
GetGray is offline
post #376 of 4541 Old 01-30-2008, 07:50 PM
GetGray's Avatar
Quoted: 193 Post(s)
Liked: 154
No dice I loaded FW ver 080114.01_XAA. Still give message "cannot play this disc" and ejects it. I D/L'd a fresh copy, file size uncompressed was identical. Im burning another one to be sure, but I'm pretty skilled at that end of things, unlikely that's the problem. Oh well.
GetGray is offline
post #377 of 4541 Old 01-30-2008, 08:19 PM
hwjohn's Avatar
Have you tried different media (brand, +/-R) and different burners?
AVS HD 709 - Free calibration disks
The 2007 Patriots: 18 -1
Tom who?
"...the small of napalm in the evening breeze, as I crouch behind a shopping cart in the parking lot..." - The Mall Ninja
hwjohn is offline
post #378 of 4541 Old 01-30-2008, 08:44 PM
rover2002's Avatar
I have mine burned to a Maxell DVD-R, maybe its brand related?
post #379 of 4541 Old 01-31-2008, 05:35 AM
hwjohn's Avatar
Sometimes you run into that... but as manufacturers get more and more experience with the older formats like DVD, you generally see less and less compatibility issues. That isn't to say that they don't still exist, which is one reason I would recommend using different media if you have it available.
You also run into burners (sometimes the combination of burners/media) that produce a poor disc. Cheap burners and cheap media can easily produce a poor quality burn that standalones can't read. In that case, it isn't so much that the player refuses to read it, but rather that it can't read it.
I doubt either one of these is the case for GetGray, but it is worth a shot.
Tom who?
hwjohn is offline
post #380 of 4541 Old 01-31-2008, 07:45 AM - Thread Starter
Quoted: 57 Post(s)
Liked: 65
I think Blu-ray is region coded, so even if you're both running the most current firmware I question if a player in Hong Kong is running the exact same firmware as one in the USA. If anyone can run AVCHD with a region A Samsung player, please reply.
post #381 of 4541 Old 01-31-2008, 10:25 AM
rover2002's Avatar
HK is region "A".
post #382 of 4541 Old 01-31-2008, 10:44 AM
GetGray's Avatar
Quoted: 193 Post(s)
Liked: 154
Not much chance there's any error on the DVD making process. I'm pretty versed in the creation of DVD's. It was that experience that led to the GetGray calibration DVD. From something completely unrelated, I'm had to make hundreds of DVDs for others. I learned early on what it took to be compatible. I use a particular NEC burner for writing. I use a different drive for reading. Drives that read-write are on different busses, I use Taiyo Yuden high end media, and burn at medium-low speeds (4x). In hundreds of DVD's made and sent to strangers with everything from $20 Apex players, to high end Denon's, I just don't get any player incompatibility. But that's not to say the Samsung BR couldn't be the first. So I tried a different brand (Verbatim -R) and redownloaded the image. There is no checksum avail, but it unzips without issue and all indications are that the iso is fine. It's a small burn, nothing on the more problematic perimeter of the DVD. The image looks fine, no sign of a bad burn. So it appears that it is probably the player.
If your region is the same, what about the FW version? What is your's? Sure seems odd one woudl do it and another not. Also I saw on Samsungs site several models of the 1400 listed. (A,C,C IIRC). Mine is a "plain" BR-P1400. Your's?
Thanks, Scott
GetGray is offline
post #383 of 4541 Old 01-31-2008, 10:49 AM
hwjohn's Avatar
Not much chance there's any error on the DVD making process. I'm pretty versed in the creation of DVD's. It was that experience that led to the GetGray calibration DVD. From something completely unrelated, I'm had to make hundreds of DVDs for others. I learned early on what it took to be compatible. I use a particular NEC burner for writing. I use a different drive for reading. Drives that read-write are on different busses, I use Taiyo Yuden high end media, and burn at medium-low speeds (4x). In hundreds of DVD's made and sent to strangers with everything from $20 Apes players, to high end Denon's, I just don't get any player incompatibility. But that's not to say the Samsung BR couldn't be the first. So I tried a different brand (Verbatim -R) and redownloaded the image. There is no checksum avail, but it unzips without issue and all indications are that the iso is fine. It's a small burn, nothing on the more problematic perimeter of the DVD. The image looks fine, no sign of a bad burn. So it appears that it is probably the player.
Thanks, Scott
If you used Taiyo's and any good NEC, then you definetely shouldn't have a problem.
Kind of odd that one model works and another doesn't. Which model is newer? Which is "higer end"?
Tom who?
hwjohn is offline
post #384 of 4541 Old 01-31-2008, 10:56 AM
GetGray's Avatar
Quoted: 193 Post(s)
Liked: 154
I agree. I dont' know which is newer. I picked mine up just a few weeks ago direct form the distributor (AVAD) and it had been on backorder so it wasn't old stock. But I think a suffix model number would imply something different. That said, I looked and there is a listing for a N and C suffix. Neither of those had FW listed, only the "plain" version took you to a page with FW. The N model listed nothing, the C model, only a user guide. Maybe they aren't out yet, dunno.
BD-P1400 US Firmware link
The international site lists several versions but all apparently "1.5" (which isn't anything like 08... shown above, but opening them they all say ...080114_01_BDP1400[varying suffix]):
BD-P1400 International
GetGray is offline
post #385 of 4541 Old 01-31-2008, 12:24 PM - Thread Starter
Quoted: 57 Post(s)
Liked: 65
I had no idea that HK was region A, but it still seems quite possible that the XSS (Asis) could be different than the XAA (US) firmware.
post #386 of 4541 Old 01-31-2008, 02:50 PM
GetGray's Avatar
Quoted: 193 Post(s)
Liked: 154
Rover2002: If your FW isn't XAA, are the menus in english by chance? Maybe I can live on the edge and try the Asia FW if that's what you have.
GetGray is offline
post #387 of 4541 Old 01-31-2008, 07:00 PM
rover2002's Avatar
Menus are in english.
http://www.samsung.com/he/support/pr..._rayplayer.sec
If this does'ent work its the player so you may need to exchange it.
post #388 of 4541 Old 01-31-2008, 08:22 PM
GetGray's Avatar
Quoted: 193 Post(s)
Liked: 154
What the hell, I'll try it tomorrow...
GetGray is offline
post #389 of 4541 Old 01-31-2008, 08:38 PM
hwjohn's Avatar
Be sure to wear your lucky underwear
Tom who?
hwjohn is offline
post #390 of 4541 Old 02-01-2008, 11:58 AM
Topher's Avatar
Sorry if this has been answered, but I did a search & didn't find anything.
I use an HTPC (running MediaPortal) for my media. I don't have either an HD-DVD play nor a Blu-Ray player.
Can this software be used by mounting the image with Daemon Tools & using CoreAVC or PowerDVD to play back the 'disk'?
Edit: If so, which version should I use, or doesn't it matter?
Topher is offline
Reply Display Calibration
Lcd Hdtv , Led Hdtv , lg bp530
