AVS HD 709 - Blu-ray & MP4 Calibration - Page 132 - AVS Forum | Home Theater Discussions And Reviews
 78Likes
post #3931 of 4474 Old 06-23-2014, 09:56 PM
sawfish's Avatar
Quoted: 143 Post(s)
Liked: 144
See what effect Color has on the color clipping.
Deaddy likes this.
sawfish is offline
post #3932 of 4474 Old 06-25-2014, 12:06 AM
Deaddy's Avatar
Okay, I experimented with the Color setting, and if I turn it way up, the green eventually clips where it's supposed to, but then all of the flashing bars for red and blue disappear, they are clipping at every number. My blue filter combined with the flashing blue/white boxes test (http://i.imgur.com/OsiOl0H.png) tells me the correct color setting is 54, and to make green clip at the right point I had to turn it to 69.
When I view this pattern http://i.imgur.com/8CWoGJb.jpg I can see each box's individual defined shade, it seems to look fine.
I'm worried that those flashing green bars not clipping is a sign that the colors are out of balance or something.
Deaddy is offline
post #3933 of 4474 Old 06-25-2014, 01:26 AM
sawfish's Avatar
Quoted: 143 Post(s)
Liked: 144
These things don't always work perfectly, and you may have to compromise between what the clipping patterns are telling you vs. the filter vs. real material. The behavior can also vary between different viewing modes. I know it does on my Panasonic 50ST60. Extreme changes to Color are probably inadvisable, and 54 for a Sony LCD sounds a lot more right than 69.
Deaddy and tubetwister like this.
sawfish is offline
post #3934 of 4474 Old 06-25-2014, 01:44 AM
Deaddy's Avatar
Thanks for the feedback. I guess it sounds like as long as the image doesn't look severely imbalanced when viewing content, that I shouldn't worry about it. I tried the Hue setting which I believe is the same as tint, didn't look any better in either direction so I've left that at zero. The colors seem all right for the most part. I trust the blue filter.
Deaddy is offline
post #3935 of 4474 Old 07-03-2014, 04:12 PM
Keith Mickunas's Avatar
Quoted: 104 Post(s)
Liked: 81
Originally Posted by *88 View Post
AVS HD 709 downloads - http://color.spectracal.com/downloads/calibration-discs
Download and burn with ImageBurn.
A search led me to this vid where I found the link above. They cover cal basics with the AVS HD 709, starts at 13:42.
http://www.youtube.com/watch?v=qG0Xgpqk7EY
Originally Posted by alluringreality View Post
Quote:Originally Posted by Ronstang
I would really like to try this disc out on my two new Sony TVs but the download links seem to be dead.
I can't seem to get access to the Wuala files, so I moved the w6rz links to the first page. I think the downloads should now work.
I had to use the spectracal links, the w6rz links are currently downloading at only a few kb/s.
Keith Mickunas is offline
post #3936 of 4474 Old 07-05-2014, 06:03 AM
NickFlare's Avatar
I've been trying to download the disc to burn and I keep getting download failed. Not to mention the downloads are taking forever and always failing at the end. Is there a torrent somewhere? Or maybe a link that's hosted on a more reliable, faster server?
NickFlare is offline
post #3937 of 4474 Old 07-05-2014, 07:36 AM
Quoted: 104 Post(s)
Liked: 81
Look at my post just before yours for the link.
post #3938 of 4474 Old 07-05-2014, 02:09 PM
dr1394's Avatar
Quoted: 141 Post(s)
Liked: 65
Sorry to hear that. However, the server is just a regular shared host. It will usually be fine, but may have periods of funkiness.
I just tested it right now, and it sustained 15 Mbps during the entire download.
Since alluringreality changed the links on page 1, the traffic at w6rz.net has tripled.
Ron
HD MPEG-2 Test Patterns http://www.w6rz.net
dr1394 is offline
post #3939 of 4474 Old 07-05-2014, 02:18 PM
dr1394's Avatar
Quoted: 141 Post(s)
Liked: 65
Are the spectracal links up to date? They look like an older version.
Ron
dr1394 is offline
post #3940 of 4474 Old 07-05-2014, 03:32 PM
Quoted: 104 Post(s)
Liked: 81
I don't know about the spectracal links. And I don't know how to determine version on these. I'm trying the w6rz links again and am getting between 60 and 70 KB/s. It'll speed up occasionally, but I have yet to see 100KB/s.
If we could get some torrents for these that would be helpful and take the burden off your server.
post #3941 of 4474 Old 07-05-2014, 06:56 PM
Quoted: 104 Post(s)
Liked: 81
Ah, I just noticed the iso I downloaded from Spectracal is named AVCHD-v1_2b. So it is older.
post #3942 of 4474 Old 07-07-2014, 07:28 PM
big.d's Avatar
Liked: 0
Unhappy
I'm not sure what I'm doing wrong here. I am trying to use the mp4 version to calibrate my PC monitor and my TV, which are both connected to my PC (cloned). I fired up the first black clipping test and my monitor does it fine, it flashes from 17 up. My TV doesn't flash any of the lines below 21, though, even with brightness, contrast, backlight, and sharpness turned all the way up. The monitor is an Asus VW246 connected via DVI, the TV is a 40" Changhong LED40YC1700UA connected via HDMI, and they're connected to my PC which runs an XFX 7870 Ghz Edition.
big.d is offline
post #3943 of 4474 Old 07-08-2014, 04:17 PM
Jerry Curl's Avatar
Sorry if this has been asked before, but I'm not sure which file I need to download to burn on a Mac. I have Roxio Toast and a BD burner, but these don't appear to be in a format I'm used to seeing to burn disc images.
Also, do the THX glass work with these tests?
Thanx.
Jerry Curl is offline
post #3944 of 4474 Old 07-09-2014, 04:50 PM
ConnecTEDDD's Avatar
Quoted: 1296 Post(s)
Liked: 1809
Hi, Blue Filter Glasses are useless for displays other than CRT.
The blue filter was an old method that was designed for CRT displays where they had only color and tint controls only and meter/software were not available these years.
Now most of the displays are coming with CMS controls.
Blue filters (on CRT) can work where for example the Red Primary is fully saturated and have no blue or green...blue primary has no green or red etc....But a fully saturated Primary needs to have the other 2 primaries added to be able to de-saturated it to it's target....so viewing throu the blue filter you will have light coming from all three primaries and this will make it's blue filter porpose of maching the luminance method no longer work.
This is the reason that blue filter fails to color/tint test on a fully calibrated CMS display.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #3945 of 4474 Old 07-11-2014, 02:08 AM
Liked: 0
Unfortunately these links only have the PC version (which downloads OK) and the Mac files on the link at the top of this topic result in pages of code opening on my Mac instead of the compressed file. Are there any other sources to download from?
In reply to Keith Mackunas re Spectracal links.
Steve Jay is offline
post #3946 of 4474 Old 07-11-2014, 05:04 AM
Jerry Curl's Avatar
I was able to download and burn the AVCHD (.7z) version of this successfully. You need to have software to extract the .7z format. There are links to some in that first post.
post #3947 of 4474 Old 07-11-2014, 09:15 AM
Liked: 0
Thanks for your suggestions but ...
I have no problem opening compressed .7z files I have Unarchiver installed and EZ7Z. If I click the .exe file link I get a window with the file icon asking me if I want to download. If I click on the .7z file link I get pages and pages of code appearing - not a compressed file icon in a window as above just apparently the actual bare programme code. I am using Firefox and Safari in OS 10.6.8. Same thing happens with both and with the other .7z files on the page. I have also tried with a later OS.
post #3948 of 4474 Old 07-11-2014, 09:25 AM
Jerry Curl's Avatar
Hmmmmm... I just tried the links in Firefox. Got the same thing you did. Use Safari. That worked for me.
post #3949 of 4474 Old 07-11-2014, 12:04 PM - Thread Starter
alluringreality's Avatar
Quoted: 57 Post(s)
Liked: 65
Apparently getting kicked off of Wuala might have had to do with their going to a paid service. I'll take a look around over the weekend to see if there's another file host that might work.
alluringreality is offline
post #3950 of 4474 Old 07-11-2014, 12:16 PM
dr1394's Avatar
Quoted: 141 Post(s)
Liked: 65
The spectracal site is fast. It saturates my 30 Mbps connection. If they could update the links with the latest version, that might work.
BTW, I have no problem hosting the streams. I pay the same amount ($8.99 a month) for the hosting no matter what the traffic is. I'm that one customer that actually takes advantage of "unlimited" bandwidth and storage.
I just posted the bandwidth stats to show how popular AVS HD 709 still is.
Ron
dr1394 is offline
post #3951 of 4474 Old 07-11-2014, 12:32 PM - Thread Starter
Quoted: 57 Post(s)
Liked: 65
I took a look at the wiki page, and maybe Google drive might work. Mainly I just switched the links because I didn't want to upload everything again, but it wouldn't hurt to have a second source. After we moved off the original host I really had no idea how much it was being downloaded. Anyway, I'll see if something works out without spending a lot of time on it.
post #3952 of 4474 Old 07-11-2014, 12:51 PM - Thread Starter
Quoted: 57 Post(s)
Liked: 65
Originally Posted by Deaddy View Post
Red and blue stop flashing past the 235 line as they should, but green flashes all the way through to the right end of the screen.
Flashing below 235 is the minimum recommendation. If the higher numbered bars also flash it's okay, so there's not really any issue here. It's not necessarily uncommon for the different colors to clip at different levels.
Personally I don't trust blue filters, but my TV is only a few clicks too high when using a blue filter, so I left in the typical instructions from other sources. Some of the newer TVs do seem to go even more out of whack using a blue filter. I can't comment on other brands, but my impression in looking at settings from measurements is that the default color setting on a Sony is probably going to be more accurate than using a blue filter.
ConnecTEDDD likes this.
post #3953 of 4474 Old 07-11-2014, 07:51 PM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 623
AVD\ HD.709 is a good program . I recommend to others as well . I have used it to visually optimize(maybe partially calibrate ) 5 sets here
In some cases the improvement was nothing short of miraculous especially on my 2013 Sony 40" R4 it made an OK set very good .
In all other instances (my other 4 sets and a few others ) the improvements were readily apparent and significant .
Thanks to AVS and all the organizations and individuals that made this software and supplemental information available to the enthusiasts here .
Note : I'm not a trained calibrator just an enthusiast AVS HD.709 has worked well for me and others .
The best results can usually be obtained from a full on optoelectronic Professional or expert enthusiast DIY calibration.
for *your specific set in your environment * Short of that AVS HD.709 and the supplemental information is a very good alternative .
tubetwister is offline
post #3954 of 4474 Old 07-11-2014, 08:15 PM
Liked: 623
As an enthusiast I like modified Cinema modes on Sonys and similar setting on some other sets (with increased brightness and contrast from defaults .)
AVS HD .709 otherwise can improve color saturation ,contrast ,brightness on a visual optimization (and obviously a measured calibration as well and /or any available CMS setting that may be needed on an individual or particular model set it's indispensable here . I do not use blue filters and thus have nothing to add there.
post #3955 of 4474 Old 07-11-2014, 08:44 PM - Thread Starter
Quoted: 57 Post(s)
Liked: 65
ALTERNATE DOWNLOAD LINKS
HDMV (.exe) or HDMV (.7z) - See Download Note A
Iso MD5: ad5006398671a54f96c314a3425621b0 - See Download Note D
AVCHD (.exe) or AVCHD (.7z) - See Download Note A
Iso MD5: 654920d1f3f1182423ecfbb75ff52263 - See Download Note D
MP4 (.exe) or MP4 (.7z)
PATTERNS MANUAL (.pdf)
post #3956 of 4474 Old 07-13-2014, 09:31 AM
James Freeman's Avatar
Quoted: 515 Post(s)
Liked: 340
Set me straight please.
I've been calibrating LCD for years, but its going to be my first time on Plasma.
After 150 hours of D-Nice slides, what order should it be done and what method.
I'll be using PS3 (YCbCr) + AVS709HD + i1D3 + HCFR.
The order is like LCD: Brightness -> Contrast -> WB (2pt then 10pt) -> Gamma (preset then 10pt) -> CMS, right?
WB: Windows or APL (small/large)?
Gamma: Windows or APL (small/large)?
CMS: Windows or APL (small/large)? 75% Saturation (What looks/measures best, I know)?
James Freeman is offline
post #3957 of 4474 Old 07-13-2014, 06:44 PM
m. zillch's Avatar
Quoted: 1958 Post(s)
Liked: 1242
Originally Posted by ConnecTEDDD View Post
....so viewing throu the blue filter you will have light coming from all three primaries.
No, it effectively turns off, or actually filters out of existence, two of them. It acts as a poor man's "blue only mode" setting (which some displays actually have) and while not being as good as using outboard instrumentation, it is better than nothing.
http://en.wikipedia.org/wiki/Blue_only_mode
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #3958 of 4474 Old 07-13-2014, 11:41 PM
Liked: 1809
Hi, If you have de-saturated a primary (for example Blue) it will contain green-red, it will not be a pure blue anymore, so viewing this throu a blue filter it will look no right.
post #3959 of 4474 Old 07-14-2014, 12:03 AM
Deaddy's Avatar
Well on my Sony with Cinema mode and Warm 2, and if you consider default color being 50/100, the blue filter has me turn it to 54 so that's fairly close to default.
One thing I don't understand is the gamma setting, and how to set that. In Cinema mode I believe the default gamma is at -2 so I left it there. In other modes it's at 0.
Deaddy is offline
post #3960 of 4474 Old 07-14-2014, 08:57 AM - Thread Starter
Quoted: 57 Post(s)
Liked: 65
This sort of thing might get more of a response in the main forum. The measurements I've looked at on plasma tend to vary xy, Y, and gamma depending on the chosen measurement patterns, so I consider it a given that the display will also vary to some extent in typical use. My impression is that the general opinion is to choose smaller windows than are available from this project for both xy and Y measurements. Exact recommendations might vary to some extent depending on the model, since discussions across various models seem to suggest potential operational differences. I never encountered what I considered a well-documented explination for how to approach plasma calibration across various models with a single measurement series in a way that clearly compares against how fixed-backlight LCDs measure, where xy and Y are absolutely tied to the video level displayed, but there are some other pattern sets that are more focused around providing various patterns for measurements. Zoyd and Chad B have posted some very thorough measurement data on a couple plasma displays, but otherwise the plasma discussion was too subjective for my taste, and I decided I would just measure how my own display operates with a few pattern series if I ever bought one.
Reply Display Calibration
Lcd Hdtv , Led Hdtv , lg bp530
