AVS HD 709 - Blu-ray & MP4 Calibration - Page 133 - AVS Forum | Home Theater Discussions And Reviews
 77Likes
post #3961 of 4467 Old 07-14-2014, 09:19 AM - Thread Starter
alluringreality's Avatar
Quoted: 57 Post(s)
Liked: 64
Originally Posted by Deaddy View Post
One thing I don't understand is the gamma setting, and how to set that. In Cinema mode I believe the default gamma is at -2 so I left it there. In other modes it's at 0.
The easiest way to look at gamma in the way it's usually discussed is with measurements. If you don't have a way to measure the display, then the best you can likely do is to try to find measurements from someone that has measured their TV of the same model. I believe on Sony displays lowering the gamma control tends to increase gamma. In that case the -2 setting would likely be intended for a room with very limited lighting (there's a misc. pattern related to room lighting), while the 0 setting would likely be intended for very bright rooms. For more information than you likely want to know about gamma see:
http://www.poynton.com/GammaFAQ.html
alluringreality is offline
post #3962 of 4467 Old 07-14-2014, 10:00 AM
m. zillch's Avatar
Quoted: 1958 Post(s)
Liked: 1239
Originally Posted by ConnecTEDDD View Post
Hi, If you have de-saturated a primary (for example Blue) it will contain green-red, it will not be a pure blue anymore, so viewing this throu a blue filter it will look no right.
A high quality blue filter effectively removes this green-red. Is it as ideal as using external instrumentation? No, I never said that, but if you can provide external documentation (a link), not written by you, which discusses your claim that blue filters simply aren't a valid method when adjusting a modern, non-CRT display that uses the three color primaries, such as traditional plasmas and LCDs, please provide it. I'd like to read more about it.
[Companies which manufacture or sell colorimetry instruments obviously have a stake in this game and might scoff at any "poor man's method", but if that's the only kind of link you can provide me with, I'll take that too. ]
In A/V reproduction accuracy, there IS no concept of "accounting for personal taste/preference". As art consumers we don't "pick" the level of bass, nor the tint/brightness of a scene's sky, any more than we pick the ending of a novel or Mona Lisa's type of smile. "High fidelity" means "high truthfulness", faithful to the original artist's intent: an unmodified, neutral, accurate copy of the original master, ideally being exact and with no discernable alterations, aka "transparency".
m. zillch is offline
post #3963 of 4467 Old 07-14-2014, 11:32 AM
ConnecTEDDD's Avatar
Quoted: 1237 Post(s)
Liked: 1761
Hi, I haven't found or searched about any document that is available on-line about that topic. My recommendation is coming by calibration experience with different display technologies over the years because I'm using meters to verify the calibration results, and they are not match any color filter, I have THX Glasses, Digital Video Essentials R/G/B Filters, Spears & Munsil v1 & v2 filters here....there is not perfect match of a filter to a perfect calibrated modern display.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #3964 of 4467 Old 07-14-2014, 12:19 PM
sawfish's Avatar
Quoted: 143 Post(s)
Liked: 144
Here's an hour-old post from Spears of Spears and Munsil fame, who sell a well-regarded setup disk and began to supply a blue filter in the 2nd edition due to popular demand, despite believing "they are not reliable":
Spears & Munsil HD Benchmark Blu-Ray 2nd Edition
ConnecTEDDD likes this.
sawfish is online now
post #3965 of 4467 Old 07-14-2014, 12:24 PM
m. zillch's Avatar
Liked: 1239
pending
[edited after having read the above post]
Poor man's solutions are never as good as using high quality external instrumentation, I've said that all along, however I don't agree with this:
Hi, Blue Filter Glasses are useless for displays other than CRT.
We now know that this assentation was based on personal experience, and is not an industry wide accepted opinion.
Blue filters vary from make to make (maybe even batch to batch), unfortunately making results slightly inconsistent, true, however the basic premise of attempting to visually replicate a display which has a true "blue mode only" setting works by using a good blue filter, at least for any display technology based on a three primary colors design, including conventional plasmas and LCDs.
post #3966 of 4467 Old 07-14-2014, 12:56 PM
Liked: 1761
Blue filters vary from make to make (maybe even batch to batch) unfortunately making results slightly inconsistent, true
Another reason that are inaccurate, if you use 4 different blue filters you will see slight different results.
however the basic premise of attempting to visually replicate a display which has a true "blue mode only" setting works by using a good blue filter for any display technology based on a three primary color design, including conventional LCD and plasmas.
If a display has a Blue only mode, then you don't need to use any blue filter.
This reply is from Joel, the lead programer of SpectraCAL's CalMAN software:
Originally Posted by sotti View Post
The blue filter is an old method that was designed for displays with color and tint only. Any display with a CMS fundamentally breaks the paradigm the blue filter is based off of. Blue filters work because red should have no blue and green should have no blue in them. But an oversaturated red or an over saturated green needs to have blue added to be de-saturated to it's target. So the blue filter now has blue light coming from all three primaries, making it's "match the luminance" method of adjustment no longer capable of giving you an accurate result.
And all of that is before we even get into the accuracy of the plastic filter itself. In case I need to elaborate on that, the filters don't aren't matched well enough to the response of the display. So even when the filters work, they are far less accurate than a meter.
This is coming from Michael Chen, THX/ISF Instructor:
Originally Posted by Michael TLV View Post
All the blue filters are not accurate. They were designed for CRT phosphors.
The purpose of the filter is to get you into the ballpark of where correct should be. YOu use your eyes as the final determiner after that.
regards
One does not use the blue filter for calibrating RGB on TVs. It is only a tool for doing color and tint and nothing else. Depending on the technology, its usefulness may also be limited. They are designed to work best with CRT type technology ... not LCD ... DLP ... Plasma.
Blue filters used before 10 years, when the calibration software/meter access were so limited and so expensive.....now in 2014 you can get an amazing for the performance colorimeter like i1d3 for 150$ and use an open source software for free, there is no reason to use any blue filter anymore.
Now all displays are coming with 6-Axis CMS controls, noone is using color/tint anymore.
post #3967 of 4467 Old 07-14-2014, 01:39 PM
m. zillch's Avatar
Liked: 1239
If anyone reading this has links to a third party source that doesn't sell/distribute colorimetry gear, software, or training in using them, which concurs that blue mode only or good quality blue filters used to simulate blue mode only, is for some reason useless for non-CRT displays, that use the three primaries, including plasmas and LCDs, please post it. Thanks.
Sorry, not looking for forum posts or personal blogs.
post #3968 of 4467 Old 07-18-2014, 04:03 PM
carillon's Avatar
Quoted: 162 Post(s)
Liked: 47
I downloaded the MP4 file, decompressed and burned it to a DVD-R. Viewing the disc on my laptop shows all the individual folders etc. My Xbox doesn't read it, when I insert it, all it says is mixed media content. What am I doing wrong? Thanks
carillon is offline
post #3969 of 4467 Old 07-18-2014, 04:10 PM
Keith Mickunas's Avatar
Quoted: 104 Post(s)
Liked: 81
You didn't read through the very first post apparently. You have to download the appropriate file type for what you are trying to do. The MP4 files are for using via a media PC or the like. You need to burn one of the other file types to a DVD-R, assuming your XBox can read a DVD-R with blu-ray formatted data.
Keith Mickunas is offline
post #3970 of 4467 Old 07-18-2014, 05:01 PM
carillon's Avatar
Quoted: 162 Post(s)
Liked: 47
Below is what I read and thought would work...
"MP4 (.exe) or MP4 (.7z)
Plays on: Many MPEG-4 AVC or H.264 video players. For example computer video players, or the Xbox 360 after update. See the player specifications for types of video supported.
Media: Depends on player, for example the Xbox 360 can play files from DVD media."
carillon is offline
post #3971 of 4467 Old 07-23-2014, 01:43 AM
Liked: 1761
Hi, there some other professionals that have the same opinion with my post about Blue Filters to this thread also.
post #3972 of 4467 Old 07-23-2014, 10:11 AM
m. zillch's Avatar
Liked: 1239
^Thanks, but I might not have been clear that my last sentence [which I've now underlined below, for emphasis] was referring to what sort of links I was seeking:
If anyone reading this has links to a third party source that doesn't sell/distribute colorimetry gear, software, or training... Sorry, not looking for forum posts or personal blogs.
But thanks anyways. Ideally I'm looking for original research and scholarly papers, although I realize those are often hard to come by.
And then there are some professionals in that same thread, such as Don Munsil, co-creator of the Spears and Munsil calibaration disc, which concurs with me that the basic premise of blue mode only calibration didn't "go away" when CRTs did and "is more than accurate enough to be used by professionals", even if using external colorimetry instrumentation is admittedly, generally more accurate, which I never questioned:
Originally Posted by dmunsil View Post
The blue-only mode is extremely accurate, and does not rely on your eyes' color sensitivity; it couldn't, because the image is monochromatic. The test relies on your eyes' sensitivity to small brightness differences, which works great. If the blue filter works for your display (i.e. it cuts out the red and green and you don't have wide-gamut display with an active CMS), then it's also quite accurate; more than accurate enough to be used by professionals. It's also fast and has very few gotchas. It's definitely the go-to way to adjust color and tint for displays that it works for. Using instruments is much slower.
Although it is true that not all blue filters are created equal in there ability to filter away red and green (some having higher quality than others), so how well they replicate using a display with a true "blue only" mode switch is a good question, let's not forget that using external instrumentation can have some possible drawbacks compared to using blue mode, as well:
With a colorimeter, you have the problem that some of them are really inaccurate with light sources with spiky spectra, and that sadly describes a lot of modern display technologies. So it's very possible to get a worse calibration with a colorimeter, if it can't read your display accurately.
post #3973 of 4467 Old 07-23-2014, 10:23 AM
Liked: 1761
^Thanks, but I might not have been clear that my last sentence [which I've now underlined below, for emphasis]But thanks anyways. Ideally I'm looking for original research and scholarly papers, although I realize those are often hard to come by.
No problem, I understand, but it's dificult to find published documents for calibration methods that was used the last 2 decades @ 2014.
Calibration is not possible by any type of filter 1$ that is coming with disks or by photographic use quality and more expensive ones (Rosco E-Colour Tokyo Blue #071 or Lee Sheet Colour Filter #071 Tokyo or Kodak Deep Blue Tricolor #47B ) or by user eyes.
Just the blue filter glasses report is no matching of the results from my JETI 1211 (11.000$) spectro of a calibrated display. JETI says that I'm correct, the glasses that I'm off....
post #3974 of 4467 Old 07-23-2014, 12:08 PM
m. zillch's Avatar
Liked: 1239
No problem, I understand, but it's dificult to find published documents for calibration methods that was used the last 2 decades @ 2014....
I guess companies continue to produce non-CRT displays to this very day, including ISF certified ones, with "Blue Mode Only" switches [which is sort of like using a "perfect" blue filter] is because many experts like Don Munsil are of the mind that the method is still fundamently, "extremely accurate" and "is more than accurate enough to be used by professionals" as he put it in that recent, 07-14-2014 quote above.
Without knowing what your actual dE value is[see:http://www.colorwiki.com/wiki/Delta_...lor_Difference], knowing that your particular blue filter's calibration measures differently than another method doesn't really do anything for me. As an analogy, if one amp measures as having .001% THD and another one as .0001%, that means nothing to real world, human perception. [No offense, but you also don't strike me as being a "neutral, unbiased calibrator" when it comes to carefully using either a good blue filter or an actual blue mode only non-CRT display, since some patience and diligence is involved and we already know you deem the method "useless", as you put it, plus there's no need to tell me the price of your calibration gear, by the way.]
On a side note, I find that source material varies so widely, even just changing from one TV broadcast station to the next or movie disc to movie disc, that any attempt to reach a magical "perfectly accurate color calibration" seems pointless to me. Getting a display "in the ballpark" is usually good enough for me. [This statement of course opens me up to condescending put down attacks of "Well, obviously you just aren't a discerning individual who has a taste for the finer things", etc., but such insults stick to me about as well as water to a duck's back.]
post #3975 of 4467 Old 07-23-2014, 12:29 PM
Liked: 1761
[No offense, but you also don't strike me as being a "neutral, unbiased calibrator when it comes to carefully using a good blue filter or an actual blue mode only design, and there's no need to tell me the price of your calibration gear.]
Any use of Blu-Filter is useless if you have reference measuring gear. Anyone can use any type or filter that makes him happy with the results or makes him believe that he has calibrated his CMS with that 1$ filter. No problem.
Most of people prefer dynamic mode from any calibrated mode...
post #3976 of 4467 Old 07-23-2014, 12:40 PM
Liked: 1761
Thank you for the dE link, I will read it carefully, I have seen this dE numbers to my reports many times but I was aware what these number means exactly.
post #3977 of 4467 Old 07-23-2014, 12:43 PM
airscapes's Avatar
Quoted: 358 Post(s)
Liked: 289
looks like this thread is a wee bit off topic!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3978 of 4467 Old 07-23-2014, 12:57 PM
Liked: 1761
I guess companies continue to produce non-CRT displays to this very day, including ISF certified ones, with "Blue Mode Only" switches [which is sort of like using a "perfect" blue filter], is because many experts like Don Munsil are of the mind that the method is still fundamently, "extremely accurate" and "is more than accurate enough to be used by professionals" as he put it in that recent, 07-14-2014 quote above.
ISF/THX Displays have a lot of wrong descriptions to their controls, for example:
They say Brightness....someone will think that this is adjusting the display's backlight for more peak output.....the correct term is Black Level.
They say Contrast, the correct term is White Level.
They say 10-IRE , 20-IRE etc.....wrong too..IRE is term for analog signal...the levels are different...7.5IRE is the reference black in analog term. They have to say 10% Gray etc.....
They say Sharpness.....we live in digital world, artificial detail control...the digital signal no need any sharpness adjustment...does PC monitors need sharpness controls?
Control descriptions are all coming from CRT analog world.... Blu-Filter too.
post #3979 of 4467 Old 07-23-2014, 12:59 PM
Liked: 1761
I'm moving out... sure it's off-topic.
post #3980 of 4467 Old 07-24-2014, 12:54 PM
RyanHomsey's Avatar
Quoted: 113 Post(s)
Liked: 42
I recently calibrated my plasma (samsung F5350) via PS3 with this disc (blu ray version). RGB set to limited. Got everything real nice (attacked grey scale and gamma via i1d2/HCFR).
Decided to move my Xbox One into that room with the plasma. Xbox One will not allow burned blu ray discs so I had to burn the AVC version on a DVD to use with it.
Where everything was perfect with the PS3/BluRay AVS Disc, with the XB1/AVC AVS Disc the grey scale is shifted way red ... and all bars are visible in the white clipping pattern (there's nothing that can be done to make them visible).
What gives?
XB1 is also set to limited.
Is the AVC disc burned to a DVD giving me skewed readings? The picture looks good, aside from an issue I had from one clip in netflix (which prompted me to check it with the AVC disc), which makes me think something is off with what the disc is telling me. Something is off....
**UPDATE** : I put in my spears/munsil calibration blu ray and it revealed the same thing. That rules out the calibration disc being a problem... Not sure what the issue is.
I'm stumped. I've been through every setting attempting to get white level right to no avail. Anyone have any insight on this? I feel like I must be overlooking some trivial/simple thing.
**UPDATE AGAIN** :
I hooked up both my XB1 and PS3 to a different TV (Vizio FALD LED-LCD) to see if there was any difference in white level readings. They were exactly the same, the patterns turned white at the reference white level (bar #235 ).
Why can I not get a white level with the XB1/Plasma while I can with the PS3/Plasma? Doesnt make any sense to me.
(all settings left he same)
PS3/LCD - Works Great!
XB1/LCD - Works Great!
PS3/Plasma - Works Great!
XB1/Plasma - Whacked out grey scale and severely crippled white output!??!?
alluringreality likes this.
RyanHomsey is offline
post #3981 of 4467 Old 07-25-2014, 11:50 AM - Thread Starter
Quoted: 57 Post(s)
Liked: 64
The Xbox 360 requires an online update to play the MP4 video. If you're online and navigate to select a file to play it, an update downloads and then it can play.
post #3982 of 4467 Old 07-25-2014, 12:19 PM - Thread Starter
Quoted: 57 Post(s)
Liked: 64
Interesting, they must have added AVCHD playback. At launch neither version worked. I tried it and sure enough after an update the AVCHD played. Anyway, thanks for the reply.
I'm not sure that I have any sort of a good guess, but my first idea would be that maybe it's something related to how the TV refreshes the screen. My TV is indicating that the Xbox One is sending the encoded 24fps signal from the AVCHD, and a 60fps signal when doing other things. Not all TVs would expect to receive a 24fps signal, and there is an option to turn off 24hz in the "Disc & Blu-ray" settings. I'm not familiar with the plasma, so I suppose 24fps could be a possible issue. Otherwise I don't have much of a guess.
RyanHomsey likes this.
post #3983 of 4467 Old 07-25-2014, 01:10 PM
RyanHomsey's Avatar
Quoted: 113 Post(s)
Liked: 42
Thanks for your help. I have posted about this issue in a number of places and gotten no where thus far.
After reading your advice I hooked the XB1 back up and turned off the 24hz option in the XB1. It caused the opposite effect. Blacks were completely crushed and whites blown out completely. No setting on the TV could bring anything back. The TV did indicate that the XB1 was outputting 60fps via the AVCHD disc. The greyscale looked clean this way though.
So it seems my two options are: 24p w/underpowered whites and significantly off greyscale (doesnt matter if cinema smooth is activated or not) or 60p w/crushed blacks and blown whites and a good greyscale !?
Unless I'm missing something - it appears the XB1 is basically incompatable with the samsung f5300 lineup?
Not sure if it makes any difference but my particular model (60 inch F5300) is a pentile based panel...
post #3984 of 4467 Old 07-25-2014, 05:52 PM - Thread Starter
Quoted: 57 Post(s)
Liked: 64
It reads like you've already seen the few "Display & sound" settings, and that's about the extent of the adjustment on the Xbox One output. The only thing else I've ever ran into would be to try a different connection type. If you've used both HDMI and component cables with the Xbox One, then I'm out of ideas.
post #3985 of 4467 Old 07-26-2014, 07:00 AM
wolf9545's Avatar
Calibration via chromecast
I tried doing a search for this but didn't come up with anything.
I have used the MP4 files on my PS3 to calibrate my HDTV before. I just bought the Chromecast and I thought that I can cast the MP4 files to my TV. Is there a good player for android that will not compress the files, they are stored on Google drive, so I get the original quality? That way if I want to calibrate someone TV I can take my tablet and the Chromecast with me.
wolf9545 is offline
post #3986 of 4467 Old 08-10-2014, 03:55 AM
Silencers's Avatar
I've used Spears&Munsil disk on XB1 yesterday with the same result, both black and white have been clipped severely, I couldn't see any bars beyond 231 for whites, and nothing below 17 for blacks. I've messed around with settings for quite some time, before I changes output from PC (RGB full) to TV (RGB limited), and then immediately I could see everything that was clipped before. To me this doesn't make sense, I would expect this to be the other way around.
I've read that you already use TV (RGB limited) setting, but I suppose changing this might change the results for you. Also, if you connect XB1 to TV via a receiver, it might be possible that clipping occurs somewhere on the receiver. Or TV settings (although this doesn't explain why everything else works fine).
Silencers is offline
post #3987 of 4467 Old 08-10-2014, 12:52 PM
sawfish's Avatar
Quoted: 143 Post(s)
Liked: 144
When the TV is set to "RGB Limited" (the norm), Black is 16, and White is 235. These are "Video Levels".
When the TV is set to "RGB Full", Black is 0, and White is 255. These are "PC Levels".
When a video device is outputting "Video Levels" (the norm), the video is output unaltered. It can contain RGB values < 16 and > 235. The AVS HD 709 bars contain the values they are labeled with.
When a video device is outputting "PC Levels", it expands Video Levels to PC Levels. This means replacing values < 16 with 0, values > 235 with 255, and scaling the values in the range [16, 235] into the range [0, 255]. The AVS HD 709 bars do not contain the values they are labeled with; instead, they reflect this expansion.
The TV setting and video device setting must match. Both should be using either Video Levels or PC Levels.
When using Video Levels, you should adjust Brightness on the TV so that Bar 17 just flashes, and Bars 16 and below are deepest black, blending into the background. You use Contrast to set the white level, and you should see flashing at least up to and including Bar 234, though it's OK for higher-numbered bars to flash.
When using PC Levels, you will never see bars < 17 or > 234 flash for reasons already given. The "blacker than black" (BTB) and "whiter than white" (WTW) values have been crushed to 0 and 255, respectively, and you can't use them to help you set Brightness and Contrast.
When you have a levels mismatch, what you see depends on who's using what. When the TV is at Video Levels and the video device is PC Levels, there will be black and white crush. The picture will look darker and super-saturated. When the TV is at PC Levels and the video device is Video Levels, the picture will look gray and washed out; on AVS HD 709, you will see Bars < 17 flash.
Another wrench is that some devices can artificially clip BTB and/or WTW when using Video Levels.
post #3988 of 4467 Old 08-18-2014, 02:21 PM
Josh128's Avatar
Quoted: 259 Post(s)
Liked: 104
I used the disc and to my surprise found my settings were crushing whites and oversaturating colors quite a bit.
One question though, does anyone know if theres a similar disc I can download for SD DVD players? I'd love to be able to do a basic black/white crush and color saturation setting on my component inputs for my game systems-- I have a Sony DVD only player and a PS2, but the AVCHD DVD wont play in them.
Any suggestions for a pattern disc that works with SD DVD players?
Josh128 is offline
post #3989 of 4467 Old 08-18-2014, 02:47 PM
carillon's Avatar
Quoted: 162 Post(s)
Liked: 47
A long time ago I used the Avia DVD to calibrate SD. It wasn't free but probably could be found pretty cheap. It worked pretty well.
carillon is offline
post #3990 of 4467 Old 08-18-2014, 02:51 PM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2894 Post(s)
Liked: 2150
This: http://www.calibrate.tv/. It's downloadable but not free. I liked it better than the commercial discs of the DVD era. Some of the patterns are used in AVS HD 709.
I recall free mpeg2 patterns somewhere. Check the calibration forum.
-Bill
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
Reply Display Calibration
Lcd Hdtv , Led Hdtv , lg bp530
