AVS HD 709 - Blu-ray & MP4 Calibration - Page 137 - AVS Forum | Home Theater Discussions And Reviews
 78Likes
post #4081 of 4473 Old 10-26-2014, 08:24 AM - Thread Starter
alluringreality's Avatar
Quoted: 57 Post(s)
Liked: 65
By default most computers use a full RGB range, which uses 0 for black and 255 for white. Video instead uses 16 for black and 235 for white. In order for video to fit with the full RGB range typically computers will expand video so that 16 goes to 0, 235 goes to 255, the video information between 16-235 is expanded accordingly, and any possible video information from 1-15 or 236-254 is removed. In this scenario of playing video on a computer that outputs a full RGB range, you would only expect to see the 17-234 bars flash on the clipping patterns.
Video expansion on a computer is a practical way to get video to fit with the full RGB range commonly used for computers, and using video expansion is easily the most common way to play video on a computer. From a video purist standpoint expansion is not necessarily ideal, since the ideal is to pass the original video information to the display without such alteration. One item introduced from expansion is grayscale banding. Because there are 256 values for black through white in the full RGB range and only 220 values for black through white in the video range, some grayscale values are assigned a step of two digits, instead of the original intent that all grayscale steps would be a single digit. Fortunately most video includes color information, and the amount of strictly grayscale information in most video is limited, so usually the grayscale banding from expansion will not be noticeable. Another argument against expansion is how it removes the video information outside the 16-235 range. Certainly there is information that decodes outside the 16-235 range from a lot of video, but usually the majority of the information outside 16-235 appears to be due to video compression in my opinion. There are people that consider these sorts of topics to be their profession that claim video often contains "specular highlights" above 235, but personally I was never able to happen to run across any examples to support such claims, which makes sense considering most people are unlikely to ever be able to notice how expansion limits the range to 16-235 when watching video on a computer. Basically expansion is an easy way to play video on a computer, and it's uncommon for the effects to be noticed, but from a video purist standpoint the general recommendation would be to pass video information from the video player to the display with very little alteration.
Often video driver or video playback software will have controls to affect expansion. There can be ways to set a Windows computer to decode at least some video so that black remains at 16 and white remains at 235, and the entire video grayscale from 1-254 is retained within the computer output. The issue with this scenario is that the video values may no longer match the computer desktop, so you might have a black level at the desktop that does not match the black level from video, and you would need some way to switch between the two outputs. If your video card has two outputs you might be able to setup one display input for video as 16-235 and one display input as 0-255 for computer desktop use, but most people don't care to go to this sort of trouble in dealing with two non-matching levels from their computer depending on what task they are doing. So video drivers and video software may have controls to affect how expansion is handled in some situations, but for convenience usually video is expanded to match the full RGB range when using a computer.
alluringreality is offline
post #4082 of 4473 Old 11-04-2014, 04:28 PM
uncola's Avatar
Quoted: 46 Post(s)
Liked: 39
alluring reality, should I set my amd driver settings to pc standard full rgb or limited studio? I know limited is better for video, but I assumed jriver with built in lavfilters automatically changed that when playing video? or am I kidding myself and I should use rgb limited on my HTPC all the time? I only play video on my htpc
Gear list: Main setup - Kef Q900, Svs sb12-nsd subwoofer, onkyo 609 receiver, epson 8350 projector, elitescreens sable 92" screen, mac mini htpc
Bedroom setup: Philharmonic Audio New Philharmonitors, Odyssey Kismet Monoblocks, Soekris Dac, Hattor active preamp
uncola is offline
post #4083 of 4473 Old 11-05-2014, 12:04 PM - Thread Starter
Quoted: 57 Post(s)
Liked: 65
If you only use a computer for video, you could try setting it to output video levels. I think on my AMD card the limited range setting under the video properties with the default RGB full pixel format setting was one way that seemed to avoid any obvious video expansion, and my TV can be set to accept that sort of input. Generally I don't use my computer primarily as a video player, so I haven't used those settings enough to say for sure if there might be any items to specifically watch out for in various situations.
I'm not familiar with the video playback software listed, but the video patterns here may be able to help you to determine how various software might affect the video, and you may find that the patterns display differently depending on which settings you select. For example by looking at the color clipping pattern I found that the Blu-ray player software I bought a few years ago decoded color differently than the other video players on my computer, as indicated by the bars that flash depending on the player used. Some video players will allow you to check RGB values with programs like colorcop or a print-screen, but other video players will have copy protection that doesn't allow such ways to easily check RGB values. Basically I can't really provide specific settings for what you want to do, and even if I could, it still would be a good idea to try to check for yourself how your computer is operating, since I've personally seen some video driver versions with errors that caused video to playback differently than what would be expected from other versions.
bmcn likes this.
post #4084 of 4473 Old 11-05-2014, 03:29 PM
uncola's Avatar
Quoted: 46 Post(s)
Liked: 39
thanks alluringreality, I'll play around with it. what difference should I notice? better black levels in video?
uncola is offline
post #4085 of 4473 Old 11-05-2014, 06:07 PM - Thread Starter
Quoted: 57 Post(s)
Liked: 65
Assuming things are set correctly, you have a display that is able to equally accept video or computer levels, and the display level matches light output for black and white, I'll suggest there probably is little reason to necessarily expect readily-noticeable differences depending if you are using video or computer levels. For example, I doubt if I could quickly pick out if I was looking at a limited or full-range signal in a blind test on my TVs. It's possible that items such as the previously mentioned grayscale banding or loss of video information above reference white might be noticeable from video expanded to computer levels in certain situations. Generally for those sorts of reasons the recommended practice is to deliver video levels to the display, but considering how common video expansion is used for practical reasons on computers, generally I wouldn't expect most people to be able to easily pick out differences with a majority of commercial video content.
post #4086 of 4473 Old 11-08-2014, 08:11 AM
Liked: 0
I'm trying to calibrate my display which is connected to a HTPC, but I've got the issue where nothing below 16 ever flashes in the Black Clipping test pattern, and nothing above 235 ever flashes in the white clipping test pattern. Regardless of whether I have the brightness/contrast set to 0 or 100 the same lines flash, so it's impossible to calibrate.
Reading through some of this thread I thought the issue would be that my PC was outputting the full colour range (0-255) instead of the video colour range (16-235). In the Intel Graphics Control Panel there's a section under Video->Input Range, which by default is set to Application Settings. I changed it to Driver Settings and Limited Range, but this didn't solve the problem. I also read that outputting YCbCr might solve the problem, so I enabled that but it didn't help.
I'm at a bit of a loss. Should I be able to make lines below 16 and above 235 flash or am I misunderstanding the manual? If they should, can anybody suggest what might be going wrong in my setup?
I'm using the MP4 test patterns with:
Graphics Chip: Intel HD4000
OS: Windows 7
Codec Pack: CCCP
Media Player: MPC-HT with MadVR for output
Eino is offline
post #4087 of 4473 Old 11-08-2014, 08:32 AM
Liked: 0
I've been messing around with this for six hours and then a minute after writing that post I found the problem. After typing "with MadVR for output" at the end of the post I started to wonder if that was the issue. I had a look at the MadVR options and found a setting to output 16-235, and now everything is working.
Sorry for the above post. Unfortunately I can't edit/delete it, so please just ignore it.
Thanks a lot for the test patterns
Eino is offline
post #4088 of 4473 Old 11-09-2014, 07:39 PM
Liked: 1
Hey there, I'm having an issue with VLC. I tried using the first file, Black Clipping, and the only bars that flash are 18+, no matter how high I set the brightness. Is this a VLC issue or does my TV just suck that much?
complicity is offline
post #4089 of 4473 Old 11-09-2014, 07:41 PM
Liked: 1
oops, sorry, apparently I should read up more. Would edit my post if I could.
post #4090 of 4473 Old 11-09-2014, 08:12 PM
Liked: 1
Okay, I fixed it in MPC-HC + madVR, but I can't find a way for VLC to output 16-235, even after a lot of googling... does anyone know how to?
post #4091 of 4473 Old 11-15-2014, 02:31 PM
mika91's Avatar
Hi,
I tried the whole evening to calibrate my display, without success.
Whatever limited/full settings on both tv and video driver I choose, only 19+ bars flash.
With full range, the display is washed out.
With limited it's seems OK (the dark are really dark) but changing brightness doesn't work. The bars bellow 19 are not visible, instead of 17.
Any suggestions?
For the record, I use xbmc on windows, with Intel 4600 driver set as limited and Sony hx920 as limited too.
mika91 is offline
post #4092 of 4473 Old 11-21-2014, 07:48 AM
Liked: 0
How is this going to help in 2014-2015 when the last update was in 2010?
bbace is offline
post #4093 of 4473 Old 11-21-2014, 07:58 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 2987 Post(s)
Liked: 2240
Welcome to AVSForum.
What is it not doing that you want it to do?
The standards it addresses have not changed since 2010. If it was correct then it is correct now.
4K and Rec 2020 are coming in now. I suspect they will require a new project.
-Bill
Wayne Corgan likes this.
Review older films here: 1979 and earlier | 1980s | 1990s | Combined reviews: Strange Picture Scroll
Unofficial OPPO FAQS: UDP-203 | BDP-103 | BDP-93 | BDP-83 | BDP-80
wmcclain is online now
post #4094 of 4473 Old 11-23-2014, 12:35 PM
umenon's Avatar
Quoted: 668 Post(s)
Liked: 228
So I played this on my Samsung 4K 55 inch set through various sources
The results for black bars were consistent (brightness). However the results for white bars (contrast) were all over the place.
1 - via USB plugged into TV port - Almost all white bars upto 253 were blinking.
2 - via youtube app on samsung - Almost all white bars upto 253 were blinking
3 - via apple TV connected via HDMI to Samsung - Only 3 white bars below blinking (rest were all white). Changing contrast setting had no impact.
4 - via roku 3 connected via HDMI to Samsung - Only 3 white bars were blinking (rest were all white). Changing contrast setting had no impact.
5 - via Tivo premiere via HDMI to Samsung - Only 4 white bars were blinking (rest were all white). Changing contrast setting had no impact.
Colors were spot on. But I am confused about the inconsistencies shown above. What could be going on? It seems to be the HDMI connectivity. I know there is some basic knowledge that is escaping me.
Please help.
umenon is offline
post #4095 of 4473 Old 11-26-2014, 11:43 AM - Thread Starter
Quoted: 57 Post(s)
Liked: 65
Someone familiar with the TV or listed devices could probably give a better guess at how your TV handles various inputs and if any adjustment settings might be available. I'm not familiar with the TV or what sort of output to generally expect from most of the listed devices. My Sony TV devotes a lot of the available light output to the levels above 235, so with a video-level input my TV generally performs similarly to the #1 description with contrast at maximum. If I use a computer or full-range signal, where the video is expanded to computer levels, then no flashing will happen from the 235-253 bars on my TV, since those levels have been removed at the computer. I have seen Samsung TVs remove the information above reference white (235), even when using a video-level input. For example I could play the video on a Blu-ray player that would display all the bars on one TV, but when the same player was plugged into the Samsung only levels below reference white would display, so clearly the additional levels were lost at the TV. I don't know if Samsung offers settings to change that sort of behavior, so someone familiar with the TV or devices might have better information on exactly how the display, devices, or available settings perform. Basically if I had the TV I would have to either read up about the TV or go through some trial and error on the available settings to find out how the TV performs and what settings are available.
post #4096 of 4473 Old 11-30-2014, 09:36 PM
Liked: 0
FINALLY!! I calibrated some awesome settings for a Mitsubishi WD-82738 ... These settings/calibrations have been so hard to find/configure!!!! My settings are:
Mode: Bright
Contrast: 60
Brightness: 45
Color: 31
Tint: 31
Sharpness: 25
Color Temp: High
Video Noise: Medium
Edge Enhance: On
Deep Field Imager: On
Khouze369 is offline
post #4097 of 4473 Old 12-10-2014, 12:43 PM
Liked: 0
Hi, i have 2 questions, I don't see any mention of PS4 in the first post: -does it make sense to use this calibration disc with a PS4 for calibrating the display with games? (I'm not interested in movies) -my display is an Asus VE278H and my PS4, when set to automatic, detects both "RGB Range" and "Y Pb/Cb Pr/Cr Range" to limited. That display is a PC monitor, not a TV, so shouldn't it be to Full range? Maybe it's just a wrong detection? Thanks
dictionary is offline
post #4098 of 4473 Old 12-11-2014, 12:26 PM
drmax's Avatar
downloadable DVD software?
So is this calibration dvd still available? I'm looking and either blind, or it's not available. I have a Samsung UN65H7150. and will use a Samsung BD-H5900 3D Blu-Ray Disc Player
Thx DM
drmax is offline
post #4099 of 4473 Old 12-11-2014, 12:44 PM
drmax's Avatar
Thx DM
ok, I may see the downloads on the 1st page, but are from 2010? Don't seem right.
drmax is offline
post #4100 of 4473 Old 12-11-2014, 12:55 PM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
zoyd is offline
post #4101 of 4473 Old 12-11-2014, 06:28 PM
drmax's Avatar
disregard. what a pita this would be. will correct factory setting by eye, like i did my other set.
drmax is offline
post #4102 of 4473 Old 12-12-2014, 12:56 AM
Liked: 0
Anybody on my questions please?
post #4103 of 4473 Old 12-13-2014, 08:04 AM - Thread Starter
Quoted: 57 Post(s)
Liked: 65
There haven't been any replies about the PS4, so I don't know exactly what it can play. Based on the following, I would guess the PS4 may be able to play the AVCHD from a DVD or the HDMV from a BD-R or BD-RE disc.
http://manuals.playstation.net/docum...videodisc.html
The usual expectation is for a video game console, like the PS4, to use the same levels for video and games. While some electronics do have ways to output different levels, and some games have settings that affect levels, the general expectation is that video and games would be output at the same levels. So it's not unreasonable that video and games might be output at the same levels, but there could be settings to affect such behavior, and I'm not familiar with the PS4. Personally I've always used similar settings for my video game consoles to what I use for video playback, so it may make sense to see what the video patterns suggest, even if you plan to only use the console for games.
I'm not familiar with the electronics, but yes, my general expectation would also be to send a full-range signal to a computer monitor.
post #4104 of 4473 Old 12-16-2014, 05:47 AM
Liked: 0
Thank you alluringreality.
post #4105 of 4473 Old 12-16-2014, 07:12 AM
umenon's Avatar
Quoted: 668 Post(s)
Liked: 228
http://referencehometheater.com/2014...ll-vs-limited/
dictionary likes this.
umenon is offline
post #4106 of 4473 Old 12-17-2014, 02:00 AM
Liked: 0
Thank you umenon, that article + FAQs confirmed that I chose my settings correctly.
post #4107 of 4473 Old 12-26-2014, 10:34 PM
Liked: 0
Late to the party.
I have a Samsung la40b650 lcd tv.
I don't know why but I have persisted with the terrible settings on this tv since new, mostly terrible night scenes ie too dark with no shades of detail.
Anyway downloaded the file and went through calibration process for contrast and brightness. I found it was impossible to achieve the correct level of black and white, but I was able to get a decent compromise.
I needed to increase backlight to 10, contrast to 100, and brightness to between 50 and 55.
I also needed to go into advanced settings and change black tone to darkest to increase and improve the dynamic range.
Not sure if that helps anyone but it definitely is a big improvement over stock. Not sure why I can't achieve the desired calibration but definitely happy with the improvement.
positron007 is offline
post #4108 of 4473 Old 12-27-2014, 03:48 AM
Liked: 0
Originally Posted by capillariancrest View Post
Hey thanks a ton for creating this video setup guide. I have managed to get the disc to work perfectly on my Sony BDP S550. My TV is a Samsung LN52A750. One of the settings that is giving me difficulty is the contrast and white settings. When I use the white clipping and colour clipping videos, I have to either drop my red offset and gain significantly or crank up the green offset and gain. The contrast when set to max and the white balance red, green and blue are set to neutral (25/50), in the white clipping contrast video the flashing bars take on a reddish tinge. When I use the colour clipping video and crank the green up to about 40/50 to get bars 235-251 to stop flashing, those flashing bars in the white clipping video take on a greenish tinge.
I find it difficult to get the flashing bars to stop flashing after their recommended levels for green and blue. Red seems to be affected significantly by the contrast setting while the others are not as affected by a high contrast setting. All the superfluous settings are turned off such as dynamic contrast, black adjust etc. Colour temperature is set to Warm 2 and gamma is set to 0. I've got my black level to perfect according to the black level test on the disc, and my colour saturation is set to 52/100.
Unless I'm misinterpreting the manual where bars 219-235 most certainly need to flash but 235-251 are allowed to blend or flash.
I have a different Samsung model but same problem.
This is what I have discovered so far.
1) Brightness effects both black and white level but contrast effects only white level, meaning if you want more accurate white you actually need to increase the brightness a little and compromise a little on the black.
2)increasing the backlight to maximum ie 10 improved the White level
3) In advanced settings, changing Black Tone to Darkest and Gamma to -3 allows you to increase the brightness further while still maintaining your previous black level. This further improves the White.
I have set mine up with it evenly compromised on both black and white but I am wondering whether it makes more sense to get white or black perfect while having the other more severely compromised eg Black perfect with white more compromised. Either way the steps above gave the best dynamic range to get the settings close to perfect as possible.
My settings are
Backlight 10 (max)
Contrast 100
Brightness anywhere between 50 to 55
Black Tone: Darkest
Gamma: -3
The next settings have no effect but for interest here they are
Warm 1
Sharpness 15
Colour 48
Tiny 50
None of the colour temps give an accurate 6500k white level. Warm 1 is closest. Been thinking of playing with rgb settings to get it right.
post #4109 of 4473 Old 12-27-2014, 04:20 AM
Liked: 0
My settings are
Backlight 10 (max)
Contrast 100
Black Tone: Darkest
Gamma: -3
Warm 1
Sharpness 15
Colour 48
Tiny 50
For completeness, with these settings in a darkened room, 12 to 25 flash on the black (11 and lower does not flash), and 230 to 241 flash on the white (242 and higher does not flash)
If I drop brightness to 50 (from 55) then black is set perfectly but now 230 to 245 flash on the white.
post #4110 of 4473 Old 01-05-2015, 05:12 PM
Arkanius's Avatar
Greetings everyone:
I have a question.
I have an AMD 280X which I have connected to my HDTV through HDMI.
I'm also connected to my PC monitor through DVI and I'm mirroring the displays.
I've set my HDTV output to RGB Limited and I have set the HDMI Black Levels on my set (LG) to Low.
However on my PC side, when I open the MP4 videos with VLC or Media Player Classic, I either get all the levels below 16 and above 235 clipped, or if I set the video to display the limited RGB range, I get everything washed out (I think as intended, since on my HDTV it shows fine and I can calibrate correctly by dropping Brightness to 38 for example)
My question here is: How can I, considering Full RGB on my PC side, calibrate correctly without clipping anything from the MP4 videos? I've tried everything but I always get clipped information. Even from Youtube videos with the same AVS HD 709 patterns. What am I doing wrong? Or is it supposed to clip?
Arkanius is offline
Reply Display Calibration
Lcd Hdtv , Led Hdtv , lg bp530
