AVS HD 709 - Blu-ray & MP4 Calibration - Page 138 - AVS Forum
post #4111 of 4116 Old 01-05-2015, 06:12 PM
Arkanius's Avatar
Greetings everyone:
I have a question.
I have an AMD 280X which I have connected to my HDTV through HDMI.
I'm also connected to my PC monitor through DVI and I'm mirroring the displays.
I've set my HDTV output to RGB Limited and I have set the HDMI Black Levels on my set (LG) to Low.
However on my PC side, when I open the MP4 videos with VLC or Media Player Classic, I either get all the levels below 16 and above 235 clipped, or if I set the video to display the limited RGB range, I get everything washed out (I think as intended, since on my HDTV it shows fine and I can calibrate correctly by dropping Brightness to 38 for example)
My question here is: How can I, considering Full RGB on my PC side, calibrate correctly without clipping anything from the MP4 videos? I've tried everything but I always get clipped information. Even from Youtube videos with the same AVS HD 709 patterns. What am I doing wrong? Or is it supposed to clip?
Arkanius is offline
post #4112 of 4116 Old 01-13-2015, 07:55 AM
Quoted: 79 Post(s)
AVS Brightness Calibration question
On my PN51F8500, when using AVS Brightness Calibration, brightness 47 & 48 work, showing everything up to bar 16. With brightness at 46, bar 17 disappears, 49 bar 16 starts to appear and 50 the entire screen dithers green.
Should I go with brightness of 47 or 48 as both seem to be "right" and show no dithering on letterboxes either. I assume 48 might give me more shadow detail with 47 possibly crushing blacks a little?
Michael Vincent Praino is online now
post #4113 of 4116 Old 01-15-2015, 12:28 PM - Thread Starter
alluringreality's Avatar
Quoted: 46 Post(s)
Liked: 43
Without anything else to go on, I'd probably go with the lower of the two settings, but I'm not familiar with the display to really comment on how exactly it might behave.
alluringreality is offline
post #4114 of 4116 Old 01-15-2015, 12:41 PM - Thread Starter
Quoted: 46 Post(s)
Liked: 43
I don't think my AMD card allows any way to display video and the computer desktop at matching levels and avoid clipping levels from video. My AMD card seems to be able to scale the full-range desktop into a limited-range output, but in that scenario it still cuts off the extra video information. There are ways that it's possible to output the video range without clearly clipping levels by having different ranges for video and the computer desktop, but most people don't want to deal with different levels depending on what they're doing, so usually people just stick with the default expansion when watching video on a computer.
Here are some further comments about displaying video on a computer:
bmcn likes this.
post #4115 of 4116 Old 01-16-2015, 05:39 AM
DrFaxe's Avatar
Liked: 76
MPC-HC + madvr should do the trick. Set Your graphics card to 0-255, configure madvr to output 16-235 and set Your TV also to limited (16-236).
Some graphic cards will output strict 16-235 if they reconize a TV, for this madvr has a levels tweaker to force the card to output 0-255.
When You set Your card to mirror (clone) can You configure Your both displays independent? Maybe You should use extended desktop to have an independent configuration enabled.
DrFaxe is offline
post #4116 of 4116 Unread Today, 10:09 AM
Liked: 0
First, I'd like to thank the creators of this awesome disc as well as this community for being an invaluable educational resource! Thanks!
I have a couple quick questions- I did search for answers, but couldn't locate anything definitive.
1) There seems to be numerous "duplicated" patterns included- e.g. "20% grayscale window" shows up under CalMAN, ChromaPure, etc... Are these patterns all identical, or are there differences between them? If they are the same, are they just duplicated simply to better serve the specific calibration software packages in some way?
2) I understand the idea that "windows" should be used instead of "fields" for measuring plasma/CRT devices to avoid automatic "level limiters" kicking in, but is there any reason why "windows" shouldn't be used for other display technologies as well (e.g. LCD)? Why wouldn't a "best practice" be simply to always use windows vs. fields?
bytor102 is online now
Reply Display Calibration
Lcd Hdtv , Led Hdtv , lg bp530
Gear in this thread - bp530 by PriceGrabber.com
