AVS HD 709 - Blu-ray & MP4 Calibration - Page 140 - AVS Forum | Home Theater Discussions And Reviews
post #4171 of 4196 Old 06-18-2015, 09:54 PM
LD-838D's Avatar
Quoted: 71 Post(s)
Liked: 25
I don't see anything in the HD 709 documentation about gamma adjustment.
Is there anything online that I can use to check?
LD-838D is online now
post #4172 of 4196 Old 06-21-2015, 09:20 AM
Liked: 0
I don't have the tools to calibrate color properly, so I ask: with color steps and color clipping, can/should I change my television's color setting to affect them? If so, should the setting go as low or high as possible while retaining the patterns' clarities?
typingwithmytoes is offline
post #4173 of 4196 Old 06-22-2015, 08:37 AM
LD-838D's Avatar
Quoted: 71 Post(s)
Liked: 25
Correct, on the color steps all should be distinct and not blend together at 235.
for color clipping ideally all should flash as at 235 and lower, a good percentage of time they will flash at different values.
From the documentation:
"Using this pattern you may find that red, green, and blue do
not necessarily clip at exactly the same levels, but you simply want to
make sure levels lower than 235 flash."
Have fun ^_^
ChromeJob likes this.
post #4174 of 4196 Old 06-22-2015, 09:02 AM
Barefoot Joe's Avatar
Quoted: 17 Post(s)
The color clipping pattern is designed to adjust contrast, not color. I agree, the name of the pattern can be misleading. If you haven't already, download the pdf for the instructions for the patterns. It explains what the various patterns are used for and how to use them.
Joe B
Barefoot Joe is online now
post #4175 of 4196 Old 06-22-2015, 09:08 AM
LD-838D's Avatar
Quoted: 71 Post(s)
Liked: 25
Joe B
Whoops, I forgot to mention that. ^_^
post #4176 of 4196 Old 06-22-2015, 10:59 AM - Thread Starter
alluringreality's Avatar
Quoted: 53 Post(s)
Liked: 55
There are patterns similar to the link below that are used to estimate gamma, but personally I find those sorts of patterns difficult to use. If someone has access to measurement equipment, I would suggest using measurements to estimate gamma. If you own one of the more popular displays and don't have access to measurement equipment, it might make sense to see what reviewers or other owners get from measurements on the same model display to find if there might be a common trend. On my Sony TV from last year I would generally expect that simply leaving the default gamma setting from the cinema preset might provide a reasonable setting for watching in a dim room, since my own measurements seemed to be in agreement with reviewers in regards to the gamma setting. This forum would label such things sharing settings and advise against the suggestion, but on my monitor I didn't have very good agreement in comparing what the following might suggest against measurements.
http://www-mddsp.enel.ucalgary.ca/Pe...ray/gamma.html
alluringreality is offline
post #4177 of 4196 Old 06-22-2015, 11:16 AM
LD-838D's Avatar
Quoted: 71 Post(s)
Liked: 25
Thank you,
I see what you mean, Difficult to display the above image in the link without the tv enlarging it as it is 640x480.
post #4178 of 4196 Old 06-22-2015, 11:20 AM
LD-838D's Avatar
Quoted: 71 Post(s)
Liked: 25
Whoops wrong thread, Sorry too many windows open!
post #4179 of 4196 Old 06-22-2015, 11:57 AM
Quoted: 17 Post(s)
Could some of you guys advise on what your gamma setting is?
I'm trying to determine if there is a common trend in settings.
A gamma setting can be two things. Firstly, a gamma target, which is what you decide to shoot for when calibrating a TV/monitor. Or, it can be the gamma adjustment setting on your particular TV/monitor. The later is pretty specific for your model of TV/monitor, so an across the board recommendation for a setting can't be made. You may have to search for calibration settings on your particular model and see if there is a trend in where calibrators set their gamma setting.
The reason I mentioned both, is that some sets have a choice of "gamma 2.2" or "gamma 2.4", or such. So, after you do your research and decide that you want a gamma of 2.2 (for example), don't assume that your TV's gamma setting of 2.2 will get you there, or even closest to a gamma of 2.2. If you find a common trend in calibrated settings for your particular model, then that's a different story.
post #4180 of 4196 Old 06-22-2015, 12:00 PM
LD-838D's Avatar
Quoted: 71 Post(s)
Liked: 25
Sorry about that!
I posted my reply in the wrong thread.
post #4181 of 4196 Old 06-23-2015, 08:45 AM - Thread Starter
Quoted: 53 Post(s)
Liked: 55
Thank you,
I'm simply not a fan of those sorts of gamma images, but it would be possible to open the image in an image editor and expand it to the native resolution of the TV without scaling. Paint.net is an example of a free windows program that could make the change.
post #4182 of 4196 Old 06-26-2015, 11:00 AM
ChromeJob's Avatar
Quoted: 320 Post(s)
Liked: 99
Would it be a concern that the image editing program didn't change the color space of the image when saving to a new resolution image? I know Photoshop (CS2, which I use) can, and does do this if the original color space is unusual.
“Say, was you ever bit by a dead bee?”
A: Yamaha RX-V775. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Samsung UN40ES6150, Panasonic DMP-BDT215, Yamaha DVD-S550.
ChromeJob is online now
post #4183 of 4196 Old 06-28-2015, 05:33 AM
LD-838D's Avatar
Quoted: 71 Post(s)
Liked: 25
New question about banding if I may, I understand all LCD/LED's have some minimal banding.
Using 1-Grayscale Ramp what would be considered unacceptable?
The left image is my my Linux Kodi setup (This is expected as i'm having some minor driver support issues) my PS4 gives a similar result.
The right is from my Dune HD Smart D1
Would the left image's vertical lines breaking up the smoothness of the gradient be considered unacceptable enough consider a replacement for the display, if it of course was not being caused by the source device?
ID:	799626   Click image for larger version
post #4184 of 4196 Old 06-30-2015, 04:29 AM
Quoted: 349 Post(s)
Liked: 54
Pretty much all LCD's have banding like this, I wouldn't stress for a replacement.
It does look a little too red though, is this calibrated?
Chase Payne is offline
post #4185 of 4196 Old 07-01-2015, 02:24 PM - Thread Starter
Quoted: 53 Post(s)
Liked: 55
I'm not familiar with potential problems for editing the image, but based on the web browser warning I suppose it might be possible that an image editor could have undesirable effects.
post #4186 of 4196 Old 07-02-2015, 12:24 PM
LD-838D's Avatar
Quoted: 71 Post(s)
Liked: 25
I thought I had the white level ok, do you see red in both images?
Oddly I see a bit of yellow in both.
I should lower the white level a bit more?
EDIT: Rechecked the contrast settings, Looks like majority of the blooming was in the digital picture.
But thanks for pointing that out.
post #4187 of 4196 Old 07-10-2015, 02:54 PM
Liked: 0
Can contrast be too high using the calibration pattern and arriving at 100? I could probably go farther than 100 if the television let me...
post #4188 of 4196 Old 07-20-2015, 09:51 AM
cgramer's Avatar
Hello! Just hearing about AVS HD 709 for the first time, and this may have been asked and answered already, but with 140 pages of posts to go through (and no promising search results), I'll ask anyway.
Can I use this calibration disc on my PS3, but instead of burning it to a Blu-ray disc (I have no Blu-ray burner), can I play it from a USB flash drive? If so, are there instructions on how to "burn" it to the flash drive, etc.? I have a 32GB drive that'd work nicely. I assume I'd have to format it as NTFS.
Any help greatly appreciated. Getting a new TV soon and want to make sure it's properly set up (likely the Vizio E55-C1 or -C2).
cgramer is online now
post #4189 of 4196 Old 07-20-2015, 10:05 AM
LD-838D's Avatar
Quoted: 71 Post(s)
Liked: 25
You can, Just download the .MP4 files (Link in first post in thread)
cgramer likes this.
post #4190 of 4196 Old 07-20-2015, 10:16 AM
cgramer's Avatar
Thanks, I'll go back and look.
post #4191 of 4196 Old 07-20-2015, 10:36 AM
HDTVChallenged's Avatar
Liked: 198
... Also, FWIW, at least one of the disk images can be burned to a DVD-R which will then play on the PS3 ... yes in HD. (122)
HDTVChallenged is offline
post #4192 of 4196 Old 07-20-2015, 08:41 PM
ChromeJob's Avatar
Quoted: 320 Post(s)
Liked: 99
Be sure to download and read the manual. I put it on my Android and iPad Mini tablets for reviewing while using it. Handy as heck.
post #4193 of 4196 Old Today, 07:01 AM
atek99's Avatar
Can I use this calibration disc on my PS3, but instead of burning it to a Blu-ray disc (I have no Blu-ray burner), can I play it from a USB flash drive? If so, ....
Cgramer, other folks here could give you more details, but I think you would be better off burning to DVD-R than using MP4 files on your PS3. I find that the MP4 files on my PS3 do not allow for proper adjustment of contrast and black level specifically. It seems to have something to do with the video settings of the PS3 (i.e. RGB etc. ) and how it treats video on a dvd or Blu-ray versus video from an MP4 file stored on the hard drive or USB. I am not sure of all the technical reasons but I believe it has been discussed in this forum previously.
atek99
atek99 is online now
post #4194 of 4196 Old Today, 07:09 AM
cgramer's Avatar
atek99
Good to know, thanks! Should be getting the TV in the next day or two, so I'll burn the DVD-R in the meantime.
post #4195 of 4196 Old Today, 07:11 AM
cgramer's Avatar
I went old-school and actually printed the manual. :-)
post #4196 of 4196 Old Today, 08:22 AM
ChromeJob's Avatar
Quoted: 320 Post(s)
Liked: 99
NICE. I've used Fedex's Print To Go service (14¢ a page at my local places), never thought to do these that way.
Reply Display Calibration
Lcd Hdtv , Led Hdtv , lg bp530
Gear in this thread - bp530 by PriceGrabber.com
