AVS HD 709 - Blu-ray & MP4 Calibration - Page 147 - AVS Forum | Home Theater Discussions And Reviews
 67Likes
post #4381 of 4396 Unread 08-21-2016, 01:20 AM
ConnecTEDDD's Avatar
Quoted: 716 Post(s)
Liked: 1151
Originally Posted by broadmarsh View Post
Now I am completely confused by all these links.
I have the following:
TX-65DX902B TV
and
DMP-UB900
Which one do I download to check and calibrate using the user the TV controls?
Please bear in mind I do not a Blu-ray burner but a DVD -R writer in my PC.
Thank you kindly.
Hi, download the AVCHD.exe and burn the extracted ISO to a blank DVD-R.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #4382 of 4396 Unread 08-21-2016, 04:18 AM
broadmarsh's Avatar
Yes. Already done that several times. It gives me a link and I end up with AVCHD-2d.exe. I have many different copies.
It is your signature that points to a link
With respect it causes the confusion and that is where I go to. Hence my question.
broadmarsh is offline
post #4383 of 4396 Unread 08-21-2016, 04:23 AM
Quoted: 716 Post(s)
Liked: 1151
Yes, that's they correct file (AVSHD-2d.exe), it's the AVCHD version of AVSHD 2.0d calibration disk.
My signature has link for another (free/lite) version of my calibration disk, not related with AVSHD.
post #4384 of 4396 Unread 08-21-2016, 04:42 AM
broadmarsh's Avatar
Yes, that's they correct file (AVSHD-2b.exe), it's the AVCHD version of AVSHD 2.0b calibration disk.
Thanks for the clarification.
The file I downloaded from the link shows AVCHD-2d.exe and creates AVCHD-2d.iso and I burnt and not AVCHD-2b.exe.
Typo on your behalf?
post #4385 of 4396 Unread 08-21-2016, 04:45 AM
Quoted: 716 Post(s)
Liked: 1151
Yes, typo from my end, it's the 2d (2.0d) the latest version
post #4386 of 4396 Unread 08-24-2016, 02:12 AM
Quoted: 20 Post(s)
Liked: 0
Hi, with OP links you can download the v2.0d (latest) while with the SpectraCAL links you can download some older versions (1.2b/1.2).
Thanks! I didn't notice that. SpectraCAL should update their site considering it's been over 5 years since the latest version released.
One more question for you guys. On a Mac, once I mount the ISO image to the disk, why won't it run? QuickTime supports Blu-ray as does VLC…
So if I wanna run the program directly from my Mac without burning a Blu-ray/DVD, is MP4 my only option?
Edit: QuickTime does not support Blu-ray. It does however support AVCHD.
avsproha is online now
post #4387 of 4396 Unread 08-24-2016, 02:28 AM
Quoted: 716 Post(s)
Liked: 1151
The version you have download is the AVCHD format which is not a native blu-ray format. If you want to download the blu-ray version, get the HDMV file.
Also you need to use a software player which can playback full blu-ray menus from ISO files. for MAC is the Macgo Mac Blu-ray Player.
post #4388 of 4396 Unread 08-24-2016, 04:11 PM
Quoted: 20 Post(s)
Liked: 0
So the default players on Mac will not playback ISO?
I tried both the HDMV and AVCHD versions. Both mount to disk just fine. But then when clicked on to open, HDMV says "cannot open". AVCHD does open but it just shows a bunch of raw files with no menus.
post #4389 of 4396 Unread 08-24-2016, 04:34 PM
Quoted: 716 Post(s)
Liked: 1151
Apple hasn't payed (& will never pay) to Sony for getting the license for Blu-Ray's DRM, so you will need a third party software for this, like the one I mentioned.
avsproha likes this.
post #4390 of 4396 Unread 08-28-2016, 09:35 PM
Quoted: 20 Post(s)
Liked: 0
Hey guys. I have an LG 55EG9100 1080p OLED TV. I've having some issues calibrating it properly. I'm using the AVS HD 709 HDMV version running on my Mac as an ISO image via HDMI to the TV.
I've gone through the "basic settings" calibration. The results are posted below along with my previous shared settings from Rtings.com, for comparison:
AVS HD 709 setting:
Brightness 55
Contrast 98
Sharpness 0
Color 55
Tint G3
Rtings shared setting:
Brightness 55
Contrast 95
Sharpness 0
Color 45
Tint 0
I came across a few issues when running through the calibration. I followed the instructions manual and started brightness calibration from 100 then went down, and contrast calibration from 0 then went up. In the Black Clipping screen for brightness calibration when at 100, I can only see 18-25 flashing. Literally everything to the left of 18 is completely black... Similarly, on the White Clipping screen for contrast calibration, starting from 0, I can only see 230-234. Everything to the right of that is completely white. So the only numbers that are visibly flashing on both patterns are only the ones that should be flashing at the ideal setting. I used the APL Clipping screen instead to calibrate the two to basically the highest and lowest setting before they drop off. I don't quite know what to make of this. Why can't I ever see both patterns flashing in full? Does this indicate an issue with the TV or something else?
Second, I've calibrated the color and tint to the flashing Color Pattern perfectly, and the color seems a little too vivid. It pops a little too much but according to the flashing color pattern, its just right. In addition, skin tones def look way too red. when I compare it to my iPhone screen it doesn't look natural on the TV. Maybe with the color I might just need some time to adjust to it but the tint is definitely off. Skin tones look too red. Will I need to mess with the color settings in the White Balance setting? Can I do that by eye or will it require a meter and software?
Lastly, where should the Color Temperature setting be? I'm used to keeping it on neutral because I've always associated that as being the most natural since the sun is rated around 6000k. The TV has Cool, Neutral, Warm 1, and Warm 2. Neutral and Warm 1 look the most natural depending on the scene. Warm 2 is way too yellow
Sorry this is long. I wanted to explain exerything! Thanks!
P.S.: The color fields test at 5% look terrible with lots of banding. It gets better at 10% and completely evens out by 20%.
P.P.S.: I asked this in another thread and one responder got really kinda hostile. I'm asking here instead since it pertains more to the AVS HD 709 disc.
post #4391 of 4396 Unread 09-17-2016, 01:02 AM
eival's Avatar
just got a new HDTV the 40" Samsung J6200 and look forward to calibrating it, so many more options that my prior Sharp 32" didnt have including native full color range option and more gamma options
glad to see the mp4 links were finally officially supported and put into the OP, i remember a year or two ago they were hidden buried away on a random page within this thread.
eival is offline
post #4392 of 4396 Unread 09-18-2016, 06:58 PM
ChromeJob's Avatar
Quoted: 490 Post(s)
Liked: 159
... where should the Color Temperature setting be? I'm used to keeping it on neutral because I've always associated that as being the most natural since the sun is rated around 6000k. The TV has Cool, Neutral, Warm 1, and Warm 2. Neutral and Warm 1 look the most natural depending on the scene. Warm 2 is way too yellow...
A couple of review sites for my Samsung TV recommended Warm2, and while I was skeptical, the more movies I watched, the more I realized that was correct. Warm1 was a bit subdued, Normal had a definite bluish cast to things. A great test was the opening chess match in FROM RUSSIA WITH LOVE. The drapes and background furnishings change dramatically from Normal to Warm2.
This doesn't apply to your TV other than ... keep watching some films and testing out both settings. Eventually you'll see that one seems more accurate for the films you know.
“What a funny, dirty little mind you have.”
A: Yamaha RX-V775. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Samsung UN40ES6150, Panasonic DMP-BDT215, Yamaha DVD-S550.
ChromeJob is offline
post #4393 of 4396 Unread 09-23-2016, 02:47 PM
Turrican4D's Avatar
Quoted: 701 Post(s)
Liked: 401
Ted, how long does it normally take to get a download link for your Lite Disk? I wait for four days already and still nothing in my Inbox.
Prof. Dr. Turrican M.D.
Turrican4D is offline
post #4394 of 4396 Unread 09-23-2016, 02:54 PM
Quoted: 716 Post(s)
Liked: 1151
Hi, the email with the download link is automatically delivered after a successful submited download link request.
If there errors in the captcha or other filling info tab, it's pointing the error with red letters and background color.
You can send me msg here to send you the info manually here: http://www.displaycalibrations.com/contact_us.html
or re-submit to the form.
Turrican4D likes this.
post #4395 of 4396 Unread 09-25-2016, 01:30 PM
Turrican4D's Avatar
Quoted: 701 Post(s)
Liked: 401
You can send me msg here to send you the info manually here: http://www.displaycalibrations.com/contact_us.html.
Thank you, Ted. I did just that a few seconds ago.
EDIT: It seems, like my Thunderbird discarded the original messages as Spam and deleted it. So the problem was on my side, Ted's response was actually lightning fast as he is today when he sent me the link again half an hour ago. Thanks Ted!
ConnecTEDDD likes this.
post #4396 of 4396 Unread Yesterday, 10:35 PM
Quoted: 20 Post(s)
Liked: 0
Yeah in the end, normal did look too neutral. I did some comparisons and ended up putting it on Warm 1 for everyday watching. While I agree for movies Warm 2 would probably be just right, however for regular tv, it just looks too warm. White button-down shirts end up looking yellow.
Reply Display Calibration
Lcd Hdtv , Led Hdtv , lg bp530
