AVS HD 709 - Blu-ray & MP4 Calibration - Page 149 - AVS Forum | Home Theater Discussions And Reviews
 77Likes
post #4441 of 4464 Old 01-27-2017, 12:14 PM
HammerJoe's Avatar
Quoted: 123 Post(s)
Originally Posted by ConnecTEDDD View Post
No, there no patterns available to AVSHD for Color Gamut using 75% Saturation with 75% Luminance patterns.
And that's what i need for the 75%/75% procedure right?
HammerJoe is offline
post #4442 of 4464 Old 01-27-2017, 12:27 PM
ConnecTEDDD's Avatar
Quoted: 1219 Post(s)
Liked: 1722
Yes, 75%/75% means 75% Saturation/75% Luminance (Stimulus Level).
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #4443 of 4464 Old 01-28-2017, 09:31 AM
HammerJoe's Avatar
Quoted: 123 Post(s)
When doing contrast with a white clipping pattern is it okay to have flashing bars up to 250?
Is that too much? What would be the ideal set? 235 perhaps?
post #4444 of 4464 Old 01-31-2017, 01:03 AM
Liked: 1722
Hi, 235 is the reference white (100% White), the ideail is to see the all flashing bar above 235, not only to flash but to have a gray-ish shade also.
post #4445 of 4464 Old 02-07-2017, 07:35 AM
sranda03's Avatar
Quoted: 68 Post(s)
Hi guys, I am a newb to calibrating TV's. I just purchased a Samsung 4k for my bedroom and want to calibrate it using this free disk. However I do not have a blueray player in my room. Is it possible to stream this video from a source or boot from a USB to calibrate? I have a PS4 in my living room so worst case i can burn to a DVD and move it upstairs but my wires are going behind my wall so I would obviously like to avoid removing the cables and snaking them through again. Thanks in advance!
Samsung UN65JS8500FXZA - Samsung HW-E550 Soundbar - Logitech Harmony 700 Universal Remote.
sranda03 is offline
post #4446 of 4464 Old 02-07-2017, 07:39 AM
Quoted: 1314 Post(s)
Liked: 340
Originally Posted by sranda03 View Post
Hi guys, I am a newb to calibration and TV's. I just purchased a Samsung 4k for my bedroom and want to calibrate it using this free disk. However I do not have a blueray player in my room. Is it possible to stream this video from a source or boot from a USB to calibrate?
You can download the MP4 version of the AVS HD 709 patterns.
Dominic Chan is offline
post #4447 of 4464 Old 02-09-2017, 05:44 AM
Liked: 0
Are there any detriments for using the APL patterns for an LCD TV? I tried and ran the Greyscale and Color (100% A / 100% S) patterns with both the APL patterns and the Full Fields patterns and the results were mostly the same (the biggest differences were about 0,3 dE), except for the color blue, specifically in delta luminance. The Full Field patterns show a significantly lower amount of blue. All the other colors have almost the same delta luminance. I've turned all the auto dimming functions off, but I read that Samsung's LCD TV's have some sort of auto dimming features that can't be turned off which can occur when the screen shows a very bright image covering almost (or fully) the whole screen.
I know it is usually recommended to use Full Field patterns on LCD TV's, but are there any reasons not to use the APL patterns? If so, why? The reason why I might preder using the APL patterns, because if I understood correctly, my TV might auto dimm the test patterns with some full field test patterns and if it does so, the measurements are incorrect.
I'm using HCFR with the AVS HD 709 disc. The TV I have is a Samsung LE40C530. The colorimeter is X-Rite i1 Display Pro III.
Miku-91 is offline
post #4448 of 4464 Old 02-10-2017, 02:18 AM
Liked: 1722
Originally Posted by Daffypuck View Post
Wow, this is a lot of info to assimilate. Which file should I DL to burn a BD test disc? I want to calibrate my projector which is using a PS3 for BD. Are there instruction files included with the DL?
Originally Posted by willieconway View Post
AVCHD. It's all in the first post. There's also a link to a manual on how to use the patterns.
Hi, if you have plans to burn using a blank BD-R/BD-RE disc then download HDMV.exe from the first post of this thread.
If you want to burn it using a blank DVD-R/RW disc then download the AVCHD.exe.
AVCHD format uses a disc structure designed for Blu-ray (with some limitations), you will get 1080p24 (23.976) when you will playback that dvd disc.
post #4449 of 4464 Old 02-28-2017, 04:50 PM
gold333's Avatar
Thanks for this.
I will use it to calibrate 3D mode on an Epson 3700/6700 3LCD projector. Will post back the results. Anything I should know before starting?
gold333 is offline
post #4450 of 4464 Old 03-13-2017, 06:02 PM
Leo_AV's Avatar
Hi guys, I have a couple questions:
- Is the 2010 version still the latest version?
- Is there any reason why my (W1070) projector seems to work better when its HDMI input is set to PC instead of Video? That seems contrary to everything I've been told to do. This is at least when outputting from a PS$ playing blu-ray (the Spears & Munsil disc).
Leo_AV is offline
post #4451 of 4464 Old 03-13-2017, 07:00 PM
aaranddeeman's Avatar
Quoted: 1646 Post(s)
Liked: 574
Why do they say it's "above" 235, when actually it's "below" (i.e 234, 233, 232...)?
aaranddeeman is offline
post #4452 of 4464 Old 03-14-2017, 05:05 AM
Liked: 1722
Hi, see there: 2016 LG C6-B6 owners thread
It can happen if you calibrate with meter/software your Grayscale the near 100% Reference White bars to look grayish but the bars above 100% Reference White to have strange tints.
Also a very important pattern is the Color Clipping Pattern, look what are you checking with that one here: AVS HD 709 - Blu-ray & MP4 Calibration
post #4453 of 4464 Old 03-14-2017, 07:30 PM
Liked: 574
Hi Ted, my question was if 235 is reference white then anything above 235 (236,237...) can either flash or clip. However anything below 235 (234, 233...) should flash and have grey tint.
If this is correct, then statement "235 and above" should flash confuses me. Shouldn't that be 235 and below must flash?
or I got it totally wrong?
post #4454 of 4464 Old 03-14-2017, 09:17 PM
Liked: 340
It's a "given" that 235 and below should not flash when properly calibrated. However, what Ted is saying is that even above 235 there still shouldn't be any clipping or discolouration, i.e., ideally 235 and up should still be flashing without tint.
Note that there are two schools of though regarding this; some people think that you "must" clip at 235, but that's a separate debate..
JVC DLA-RS4910
HCFR Bug List
post #4455 of 4464 Old 03-15-2017, 02:47 AM
Liked: 1722
Hi, 235 and below in Contrast and Color Clipping Patterns has to flash, to the Contrast pattern, if you have meters and pre-calibrated Grayscale up to 100% (so 90% or 95% will be calibrated also) then they will not have any shade other than neutral gray-ish. For the levels above 235, the ideal is to see them flashing also. (in both Contrast or Clipping Patterns).
Commercial movies from YCbCr 4:2:0 data (which is video levels) inside a disk -> chroma subsampling/player colorspace conversion -> TV internal (to input or to processing) conversions...can affect the signal, and there specific pixels where @ YCbCr -> RGB conversion are giving above 235 RGB Triplets, so to be sure that all are fine during movie playback, you set your contrast with patterns to see above 235 also.
Now with peak levels display has, there to problem with reducing contrast ratio when you reduce some contrast slider to see more bars flashing since any display can reach about 300-400nits while you have to reduce that to 100-120 nits to match the mastering luminance levels of SDR blu-ray's.
If you read the link I posted it's say the same.
post #4456 of 4464 Old 03-15-2017, 04:50 AM
Liked: 574
Thank you. This is making it much clear(er).
ConnecTEDDD likes this.
post #4457 of 4464 Old 03-15-2017, 07:27 PM
Liked: 574
Oh. I was somehow thinking that 235 is the end. Anything above should not be their in real world material. Looks like that is not the case.
post #4458 of 4464 Old 03-27-2017, 09:42 AM
Liked: 0
Hey there. Extremely new to the forums here. I really appreciate the effort you guys have put into this calibration resource over the years.
I just wanted to mention that the link to the Patterns Manual doesn't seem to be working, unless I'm stupid and missing something. Thought you might like to know. Thanks again!
montana49kc is offline
post #4459 of 4464 Old 03-27-2017, 10:00 AM
Liked: 340
For some reason it no longer works. However, the alternative link still works.
JVC DLA-RS4910
HCFR Bug List
post #4460 of 4464 Old 03-27-2017, 02:09 PM
Liked: 0
Thanks for the heads up. I missed that alternate link the first handful of times around. What a noob.
post #4461 of 4464 Old 03-28-2017, 06:17 AM
MaaZeus's Avatar
Quoted: 46 Post(s)
Liked: 43
Actually, if standards are followed 235 IS the end. Its called Reference White for a reason, it should be the peak white your TV is capable of making. The TV range is basically the same as PC Levels, just with less steps, but that reduction of steps from black to white does give room for the so called BTB and WTW content which PC Levels cannot have. (PC Level is already maxing out the 8-bit colors). But those BTB and WTW signals are techincally "out of specs". That does not mean some movies do not have them but they are very much a minority. To see WTW you have to reduce the contrast slider on your TV, which also means that you are severely reducing the contrast ratio of the TV for most real life content just to give your TV some room for the few movies with little "out of spec" details that really should not even be there and sometimes are nothing but artifacts.
I'm sure some will disagree with this but this is how I see it. I do know that professional video monitors are calibrated to preserve WTW but why they are calibrated so, I do not know. (I think it is because they do want to see possible overshoot artifacts so they can clean them out) Spears And Munsil website say that if you want to clip WTW content or preserve them, both are correct ways to go and its up to you what you value the most. If you like to see what little WTW content is there or left behind, go ahead and keep the WTW visible, but if you want to have the most contrasty image for the actual content within the 16-235 range, clip them out.
MaaZeus is online now
post #4462 of 4464 Old 03-28-2017, 06:51 AM
Bloodwound's Avatar
Quoted: 95 Post(s)
Above 235 is not really going to matter, and 240 should satisfy those with a high degree of OCD. And yet we still aim for 250+.. for no frigging reason.
You can turn up the contrast lever as long the whites don't turn pinkish or other weird things, and let it clip between 235-240 (but also check the individual colors and that you still have a linear dynamic range) You don't *have* to do it, but being aware of the possibility can come in handy on some occasions.
MaaZeus likes this.
Bloodwound is online now
post #4463 of 4464 Old 03-28-2017, 07:32 AM
MaaZeus's Avatar
Quoted: 46 Post(s)
Liked: 43
Yeah, making 240 your new reference white is way more sensible than aiming up to 255. You do get some subtle WTW content in if there is some in the movie, but do not butcher your TV's contrast ratio so badly for the others.
post #4464 of 4464 Unread Today, 08:55 AM
aasoror's Avatar
Quoted: 28 Post(s)
Liked: 33
FYI, dropbox link to the pattern manual is broken.
TIA
aasoror is online now
Reply Display Calibration
Lcd Hdtv , Led Hdtv , lg bp530
