AVS HD 709 - Blu-ray & MP4 Calibration - Page 73 - AVS Forum
post #2161 of 4003 Old 07-31-2010, 01:37 PM
mike81's Avatar
I have a Sony KD-46S504 1080p LCD and a Sony BDP-S560 Player. The player is set to output 1080p and is connected via HDMI. The TV is set on full pixel so it displays the image in it's native resolution. All the enhancements are turned off.
I'm using the patched version of the disc. When looking at the pattern labeled Small 1080p Crosshatch it does not appear to be displaying correctly. It appears something like the attached image. I just did this quickly in Windows Paint. The white horizontal lines are 2 pixels wide and appear to be grayish. The vertical lines are 1 pixel wide like they are supposed to be. There are 2 white dots in the center of the squares. Each is 1 pixel and stacked one on top of the other.
The same type of thing happens with every pattern that is similar to this. Every time there are supposed to be horizontal white lines made of a certain number of pixels, it is not correct. One pattern is supposed to show alternating black & white horizontal lines. Each line is supposed to be 3 pixels wide. However the first line is made of 2 rows white pixels & then 1 row grayish. The next line is 2 black rows and 1 grayish. It then repeats.
Another pattern is supposed to be a checkerboard pattern. 1 white pixel and then 1 black, etc. However, the whole screen has a grayish color. I'm getting right up on the screen and as far as I can tell, there are no alternating black and white pixels.
Now, both the LCD panel and video processor have been replaced, so why do the patterns not display correctly? Any help at all would be appreciated.
mike81 is offline
post #2162 of 4003 Old 08-01-2010, 12:51 AM
Bluematches's Avatar
Hi,
I would like to calibrate my TV (Panasonic 50G20) through its USB input. Where can I get the 100% window patterns (primary, secondary colours and greyscale by step of 10%) in jpeg format (1920x1080)?
Cheers
Bluematches is offline
post #2163 of 4003 Old 08-01-2010, 02:28 PM - Thread Starter
alluringreality's Avatar
Quoted: 12 Post(s)
Liked: 34
There have not been any relevant issues reported regarding the Patched disc, but you might want to try the AVCHD and see if it performs the same. The AVCHD video may look the same, but I'm just suggesting to try the AVCHD to rule out any cause related to the disc with that player.
Assuming the AVCHD performs the same, the next item would be some sort of scaling. I'd probably guess at any scaling being from the TV, but I suppose it could be from the player. Personally my Sony can't display one of the patterns correctly with how it deals with video. Having access to multiple displays, like at a store, would be the easiest way to look at how different TVs can display the same signal differently.
alluringreality is online now
post #2164 of 4003 Old 08-01-2010, 02:38 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 34
Much of the video is created from images. The project is on another computer, but I think .png is used. Generally I'm scratching my head trying to come up with a situation where it would be beneficial to calibrate a TV to images (corresponding with video levels) from a USB input.
post #2165 of 4003 Old 08-01-2010, 02:59 PM
In fact, I use the USB input to watch avi files (720p) and I assume that if I calibrate the USB input, it would also be useful for TV programs. Calibrating the input through a dvd/BR player, seems not that close because of the player settings.
Png files are fine. I would convert them in jpeg or gif files. Would it be possible to get them? It would be very much appreciated
post #2166 of 4003 Old 08-01-2010, 05:58 PM
bodosom's Avatar
You need to be sure that still images (gif, jpg, png etc.) are processed in the same color space as video (avi, mpg, mov etc.). Since non-video sources are expected to be full range (e.g. output from digital cameras) they are typically displayed in the so-called IT color space which is incorrect for video (which nominally displayed in the so-called CE color space).
IT: full 8-bit RGB 0-255
CE: limited to 220 levels RGB 16-235.
bodosom is offline
post #2167 of 4003 Old 08-01-2010, 09:36 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 34
Have you tried the MP4 files with the USB? On some skimming it appears that AVI is a container and not standardized to one single video format, so assuming the display correctly matches levels between different video formats then MP4 would be as good as any if the TV will play it. Of course the ideal would be AVI with the same video format as what you'll be watching, but transcoding and verifying video levels can be somewhat involved.
post #2168 of 4003 Old 08-01-2010, 10:27 PM
Edo Glvez's Avatar
The MP4s work great for me, even if I get the *unsupported audio codec* thing, I asume it's because there is no audio stream in the container.
Calibrating the screen for TV channels will be pretty much impossible tho, best you will be able to do is wait until late night for a pattern, and there is no guarantee that those settings will be the right ones for other stations.
Edo Glvez is offline
post #2169 of 4003 Old 08-02-2010, 06:07 AM
I converted the mp4 into avi and I will try if it works. Thanks
post #2170 of 4003 Old 08-02-2010, 11:46 AM
Bobster231's Avatar
Hey guys, just bought a Samsung UC40C5000 LED television, I cannot however get the contrast (white bars) pattern to work. No matter what I do raising the contrast or lowering it the bars are always there and not dissapearing. Its almost as if its working as a backlight. Very weird. However I got the brightness pattern to work perfectly. I have all extra enhanced features turned off. Any ideas? I really want to set my contrast!
Thanks guys.
Bobster231 is offline
post #2171 of 4003 Old 08-02-2010, 12:57 PM
sotti's Avatar
Quoted: 21 Post(s)
Liked: 167
Thanks guys.
It's quite possible that your set will never clip below 100%.
You may want to pull up one of the patterns that ramps all the way to 254 and see if the ramp discolors at all. typically one channel will start clipping before the others. For instances if red clips first (typical), the upper end will get a little blue, turning the lower pink looking. Back the the contrast down till the whole ramp has a consistent tone.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is online now
post #2172 of 4003 Old 08-03-2010, 09:54 AM
Sujay's Avatar
AVS HD was recommended on HDNation's calibration episode: http://revision3.com/hdnation/hdcalibration
Sujay is offline
post #2173 of 4003 Old 08-03-2010, 12:49 PM
chrismas's Avatar
So I have TotalMedia Theatre 3 and I'm curious how you play it off of the hdd.
chrismas is offline
post #2174 of 4003 Old 08-03-2010, 01:06 PM
chrismas's Avatar
Nevermind I figured it out lol
chrismas is offline
post #2175 of 4003 Old 08-03-2010, 01:19 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 34
This is how my TV performs by default. Not allowing the bright grayscale to clip may make sense. It's possible that by not allowing the grayscale to clip the manufacturer could have tried to avoid some issues, like items mentioned in http://www.avsforum.com/avs-vb/showt...9#post18771039 The issues from the link are easier to look at by taking measurements, but there are some sections in Misc Patterns as mentioned in http://www.avsforum.com/avs-vb/showt...4#post18770474 for further looks at high contrast settings. Anyway the way my TV works is that by not really allowing the high grayscale to clip then the display avoids most issues up to white (235) at even the highest contrast settings, so the further checks from Misc Patterns don't show much of anything when using even the maximum contrast. Honestly if I decide to revise the disc again I may primarily suggest to consider setting contrast no higher than where most all the bars remain flashing, which is the recommendation from the DVE Blu-ray.
post #2176 of 4003 Old 08-03-2010, 06:52 PM
Edo Glvez's Avatar
Sweet! Grats!
post #2177 of 4003 Old 08-04-2010, 12:18 PM
Odonata_00's Avatar
Both the AVCHD file and the PATCHED file work on the LG BD550.
Odonata_00 is offline
post #2178 of 4003 Old 08-05-2010, 07:09 PM
omiez's Avatar
Hello
Is there a way to calibrate connecting an external Hard Disk to my TV, a Samsung LN40C530 to calibrate ?
At the moment i don´t have Blueray Player.
omiez is offline
post #2179 of 4003 Old 08-06-2010, 06:31 AM
Edo Glvez's Avatar
Originally Posted by omiez View Post
Hello
Tried a USB stick and the MP4 files?
post #2180 of 4003 Old 08-06-2010, 12:12 PM
omiez's Avatar
Going to try after work,i let you know. Thank You
omiez is offline
post #2181 of 4003 Old 08-06-2010, 10:55 PM
skatingrocker17's Avatar
Just watched that episode tonight. I didn't even know this existed. Anyway I had my plasma almost perfect before and fine tuned it with this but what exactly am I looking for in the interlaced part? I think I'm just looking for how the TV deinterlaces the 1080i source.
EDIT: Also, using PATCHED the PS3 had no problems displaying pop-up menus.
skatingrocker17 is offline
post #2182 of 4003 Old 08-10-2010, 09:57 AM
SemperFiavs's Avatar
Is there a way to adjust color/tint without using a blue filter? My Panasonic
S2 doesn't have a blue mode and I don't have blue filter glasses.
SemperFiavs is offline
post #2183 of 4003 Old 08-10-2010, 11:14 AM
m. zillch's Avatar
Quoted: 125 Post(s)
Liked: 142
^Sorry, but no.
You can buy some on line at various places such as this:
http://www.costore.com/thx/producten...=87&pid=930793
In A/V reproduction accuracy, there is no concept of "accounting for taste". We don't "pick" the level of bass any more than we get to pick the ending of a play. High fidelity is an unbiased, neutral, exact copy (or "reproduction") of the original source's tonal balance, timing, dynamics, etc..
m. zillch is online now
post #2184 of 4003 Old 08-10-2010, 04:28 PM
markabuckley's Avatar
I'm just trying this set of test patterns (great by the way)
question on my PF11UK Panasonic though - I'm running XBMC on my HTPC - Nvidia drivers set to "full range RGB" - and "RGB" output
yet at my normal viewing (which I thought was ok) I could not see any of the black bars flashing in the brightness test
if I ramp up brightness to be really excessive 19 upwards become visible
seems to be the output from my Nvidia card itself - at +7 brightness I could still only see 19 - and 18 needed even more (this is on my TV) - and at +7 you could start to see "noise" in the black background across the whole screen
bumped the Nvidia brightness setting to 58 instead of 50 (in Nvidia drivers) and suddenly at +7 brightness on TV I could see down to 10 or 11 in the test - so the output from my Vidieo card must have been odd levels wise and TV was working too hard to correct
markabuckley is offline
post #2185 of 4003 Old 08-10-2010, 04:33 PM
aaargh - I just tried same with Contrast in Nvidia settings - as I couldn't get to see anything about 232 or so even with contrast way down on the TV - bumped the Contrast back up to normal levels - then adjusted the Nvidia driver Contrast setting - not much - only from 50 (normal) to 45 - and instantly I could see all the way up to 243 !
frustrated as I've been watching from my HTPC with severely clipped blacks and whites because of these settings in the driver itself
btw my TV was ISF calibrated by previous owner, and I had only ever adjusted contrast/brightness to my taste - but now I've adjusted these driver settings - the PQ looks so much better
I've only had my HTPC like this for a year ! lol
post #2186 of 4003 Old 08-10-2010, 11:16 PM
SharksFan1's Avatar
I am trying to calibrate my LG 42LB5DF. I am using my PS3 and the AVS HD 709 AVCHD on a DVD+R I burned. I'm using the Overscan video (the last one on the basic settings) and can not get my TV to show the full picture, with no overscan. I tried adjusting the "Aspect Ration" but none of the options give me the full picture. I have a little more than 2.5" overscan, so maybe 3" then. I have looked at the setting on my PS3 and can't find any way to fix it there.
Does any know how I can fix this?
SharksFan1 is offline
post #2187 of 4003 Old 08-11-2010, 11:07 AM
d3193's Avatar
I can't believe I have only just discovered this on AVS.
Thank you. Thank you.
Thank you for sharing this calibration disc with us.
Thank you for your generosity and hard work.
d3193 is offline
post #2188 of 4003 Old 08-11-2010, 01:08 PM
JimLely's Avatar
Hi All,
Hope this question hasn't been answered before: I just got my first LCD TV yesterday (other TV is a DLP rear projection). How do I calibrate (with your superb disk) the backlight?
Jim
JimLely is offline
post #2189 of 4003 Old 08-12-2010, 06:22 AM
louerhardt's Avatar
Here is a helpful pattern generator to output from a PC. And ...completely FREE!!
http://spectracal.com/download_HTPC.html
Lou Erhardt, ISF-C
SpectraCal, LLC
louerhardt is offline
post #2190 of 4003 Old 08-12-2010, 06:31 AM
One-Man Content Creator
wmcclain's Avatar
Quoted: 328 Post(s)
Liked: 337
Originally Posted by JimLely View Post
Hi All,
Jim
Have a look at the backlight threads in the Calibration forum: http://www.avsforum.com/avs-vb/searc...rchid=15743043.
The usual advice is to set the backlight as low as is pleasing to you (LCD black levels are better at lower levels) and begin your calibration of the other display settings from there.
-Bill
wmcclain is online now
Reply Display Calibration
Lcd Hdtv , Led Hdtv , lg bp530
Gear in this thread - bp530 by PriceGrabber.com
