Saturation in RGB? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-19-2008, 08:40 PM - Thread Starter
alluringreality's Avatar
Quoted: 57 Post(s)
Liked: 65
HCFR has a "saturation scale" measurement. For video levels of 16 to 235, how would you calculate 25%, 50%, and 75% saturation in RGB? Would the following be correct for a 100% luminance red?
0% sat - 235, 235, 235
25% sat - 235, 180, 180
50% sat - 235, 126, 126
75% sat - 235, 71, 71
100% sat - 235, 16, 16
If the above is correct, would the following be correct?
50% saturation, 75% luminance red - 180, 98, 98
Generally I'm not sure the "view images" option in HCFR is working correctly. 0% saturation is showing red, green, and blue all equal like a 50% gray, but 100% saturation is showing 255, 0, 0 for 100% red saturation even though I have 16-235 set.
alluringreality is offline
post #2 of 6 Old 01-31-2008, 04:56 AM
Georges G's Avatar
Hello
No, this is not correct. In 0-255 mode, the 0% sat is not (255,255,255). The 0% sat for a color is the gray level which have exactly the same global luminance than corresponding 100% saturated color. For red, the series is the following:
0% sat - 126,126,126
25% sat - 171,111,111
50% sat - 204,92,92
75% sat - 231,67,67
100% sat - 255,0,0
The gray level changes for each color. The darkest is blue, whose 0% sat level is 84,84,84 and the lightest is yellow, with 244,244,244.
In 16-235 mode, the right values should be the following, for red:
0% sat - 125,125,125
25% sat - 163,111,111
50% sat - 191,95,95
75% sat - 214,73,73
100% sat - 235,16,16
Unfortunately, there is a bug in V2.0, the 16-235 flag is not taken into account for saturations. I'm working on it, it will be fixed in next version (coming very soon).
Yes, in this particular case, it is true, you found a real bug. Thank you for your help !
Georges
Georges G is offline
post #3 of 6 Old 01-31-2008, 08:08 AM
hwjohn's Avatar
Georges
Georges,
So, the problem with our original calculations was that we were allowing luminance as well as saturation to fluctuate?
In other words, we must hold luminance constant while we vary the saturation, correct?
AVS HD 709 - Free calibration disks
The 2007 Patriots: 18 -1
Tom who?
"...the small of napalm in the evening breeze, as I crouch behind a shopping cart in the parking lot..." - The Mall Ninja
hwjohn is offline
post #4 of 6 Old 01-31-2008, 08:44 AM - Thread Starter
Quoted: 57 Post(s)
Liked: 65
I suppose holding luminance for each of 0%, 25%, 50%, 75% would make sense, but I thought 100% red luminance was 0.213 for 709. I don't get where the gray comes from because that seems close to 0.5 as far as I can tell.
post #5 of 6 Old 01-31-2008, 10:01 AM
Georges G's Avatar
Yes, it looks strange, but it isn't. If you look at real measures, primary colors and gray scale, you will find blue Y near 30% gray Y, red Y around 50% gray Y, and green Y around 80% gray Y. And if you sum those three Y values, you obtain 100% white Y value (a little less if you sum the three gray levels). But if you add 30%+50%+80%, you do not have 100%, you have 160 ! What's wrong ? In reality, it's simple. Between those two scales, percent levels and Y levels, you have a gamma factor. This factor in 0.45 in a sense, 1/0.45 in the other (the famous 2.22 gamma).
Red is 0.213, and 0.213 ^ 0.45 = 0.499, ie 50%. This is it
In the other sense: 30% ^ 2.22 + 50% ^ 2.22 + 80% ^ 2.22 is near 100% (90% more exactly: this is it too ).
Clearly, Y value for Red is 0.213 * YWhite. To obtain white, you send a RGB value (255,255,255). To obtain a gray whose Y measured value will be 0.213 * YWhite, the RGB triplet has three identical values which are 255 * ( 0.213 ^0.45 ), ie (127,127,127) in Rec709 (in Rec601 it is very little different). Pure red is of course (255,0,0), and measured Y value for both colors must be the same (not absolutely perfectly, because we do not have decimals in RGB triplets...). For intermediate saturations, well, it's some little maths
I hope it will make it clear now
Georges
post #6 of 6 Old 01-31-2008, 10:28 AM
hwjohn's Avatar
Georges
Excellent, makes sense now. Thanks Georges!
Tom who?
hwjohn is offline
Reply Display Calibration
