ColorHCFR v2.0 Available... - Page 10 - AVS Forum | Home Theater Discussions And Reviews
Old 02-23-2008, 04:11 AM
timmorris's Avatar
Gary has posted several times in this thread about lack of Spyder accuracy. I've got some evidence that proves that unless you get a good one you might as well use it as a paperwieght. I calibrated a plasma with a Spyder and then some weeks later bought an Eye-One Pro. The Spyder results looked good on the face of it but when I measured the same display with the Eye One dE maxed out at 13 due to 10% measurement errors in two of the filters. Just to make sure I re-measured on the same day with the same ambient light (within 30 minutes). The results are attached.
The D2 is calibrated ex-factory so If you are going to bother going through the process then spend the extra.
Tim
Spyder vs Eye One.pdf 200.2822265625k . file
timmorris is offline
Old 02-23-2008, 04:29 AM
Ki_
Ki_'s Avatar
Originally Posted by Killerbeenl View Post
Hello,
I have a feature request:
I have connected my laptop with a s-videocable and to my CRT directview tv and used the buildin patterns.
This was the first time because a prefer to use my DVD-player but a must say its
works like a charm.
There is one problem and that is the fullscreen patterns,i used the 10% windows from
the HCFR dvd because that's a better choice for crt televisions.
So my question is can u make 10% or 25 % windows for the automeasure of greyscale/primaries etc.
thanks,
Danny
Hi
You can select the pattern size in the measure/generator/configure/display menu.
(it doesn't work for the test patterns but only for measurement patterns)
Ki_ is offline
Old 02-23-2008, 01:12 PM
Killerbeenl's Avatar
Originally Posted by Ki_ View Post
Hi
owh... how dumb of me thanks for the quick reply
greetz,
Danny
Sometimes you are 1 click away from pulling your hair out and bang your head against the wall
Killerbeenl is offline
Old 02-23-2008, 01:33 PM
Tim
Hi Tim,
Did you measure with or without the filtre/baflle on the spyder and crt or lcd mode in HCFR ?
And was that the spyder2 hardware or the older spyder?
Greetz,
Danny
Old 02-23-2008, 02:58 PM
kjgarrison's Avatar
Originally Posted by kjgarrison View Post
IF we have results to post and get input on, where should these be posted? Should the old thread using the previous version be used?
I actually posted here, and did get some feedback, but I think I shouldn't have posted actual calibration graphs here. Sorry about that.
bump
Where to post graphs and discuss things?
kjgarrison is offline
Old 02-24-2008, 09:56 AM
jvincent's Avatar
bump
In the following thread.
http://www.avsforum.com/avs-vb/showthread.php?t=786966
jvincent is offline
Old 02-24-2008, 01:23 PM
kjgarrison's Avatar
tyvm
Old 02-26-2008, 01:09 AM
aoshiken's Avatar
Hi,
2.0.1 seems to crash with a .chc file, please, take a look to this post:
http://www.avsforum.com/avs-vb/showt...8#post13223358
I don't know if it was related to the program or to a bad generated zip file, anyway, I supposed you want to know.
Updated: The program crashes when double-clicking on the chc file but doesn't if you start the program and then choose File->Open.
Cheers.
aoshiken is offline
Old 02-26-2008, 03:18 AM
Tux
Tux's Avatar
Doesn't crash here. Double clicked on the FinalCal.chc file. All OK.
Tux is offline
Old 02-26-2008, 09:41 AM
rmongiovi's Avatar
Quoted: 27 Post(s)
When I first installed 2.0, I could double click on a certain .chc and it would open fine. If I then closed HCFR and double clicked on the file again, it would tell me the file could not be found. Double clicking another .chc file would work fine, and using the "open" dialog box in HCFR would work fine. But only the first double click on this one .chc file would work.... It would take a reboot to be able to double click that one file again.
Then that just stopped happening. I just chalked it up to the wonders of Windows....
Roy
rmongiovi is offline
Old 02-26-2008, 02:43 PM - Thread Starter
laric's Avatar
Hi,
No problem at all here also... FinalCal.chc works fine in any case, this either on XP or Vista Premium (SP1).
Btw, nothing similar was reported so far...
--Patrice
French speaking home theater HCFR Forum
laric is offline
Old 02-26-2008, 06:37 PM
kjgarrison's Avatar
Is this intentional or is this a bug?
Cyan consistently shows up at or near the target postion on the "ideal or target" CIE chart between blue and green. The other secondary colors plot out on the lines appropriately, but not cyan.
Old 02-26-2008, 10:25 PM
Renovator's Avatar
I've attempted to wrangle the original French manual into English.
Unfortunately, I don't speak French, and only recently started worrying with display calibration.
To that end, it's a work in progress. I tried to keep the tone and humor of the original authors, but slipped to local vernacular as the process went on.
I'm happy to host it on my server, I just ask that the links go to the download page rather than hot linking the file(s).
Two Office versions are available. One .docx for 2007 and a .doc for earlier flavors.
NiceFiles
(Any corrections can be mailed to me and the file(s) will be updated.)
Renovator is offline
Old 02-27-2008, 06:11 AM
timmorris's Avatar
Hi Tim,
Greetz,
Danny
I measured in Calman V3 using plasma mode for both meters and with the filter in place for the Spyder 2. I'm not the only person to have noticed this. As the spyder isn't calibrated and uses filters which are by their nature variable there's no way that everyone can be accurate. Even the D2 which is calibrated ex factory is susceptible to drifting over time due to humidity.
Tim
Old 02-27-2008, 09:01 AM
Tim
As far as i know you should take the baflle/filter off when measure CRT or plasma so maybe that's the reason.
I know that the spyder is not accurate but its just the numbers that are off
but the result is not that bad and much better than DVE and AVIA .
Old 02-27-2008, 09:30 AM
angryht's Avatar
I like the title: Calibration for Zeros.......priceless. Please accept a thank you from a fellow zero.
-Greg
angryht is offline
Old 02-27-2008, 10:57 AM
legierk's Avatar
Quoted: 13 Post(s)
NiceFiles
On a whim, I thought, maybe someone has translated the instructions for HCFR by now.....wow, too cool....thanks!
legierk is offline
Old 02-27-2008, 10:18 PM
timmorris's Avatar
With Calman and Spyder TV the baffle should be ON for measuring CRT and plasma. I have no idea why it should be off for HCFR. Most people have at least a few thousand dollars invested so I can't see why they want to save $50 on a meter (or $200 on software that has help which holds your hand through the whole process, but that is just a personal thing). A dE of 13 is not just measurable but easily perceptible when you have seen the correct greyscale. I have confirmed the Eye One Pro measuremnts with a professional calibrator's Eye One Pro, and his measurements mirrored mine exactly.
Given this information that has been posted on AVSforums several times I can't see why anyone is still buying a Spyder.
Tim
Old 02-28-2008, 02:41 AM
blutarsky's Avatar
Ouch!!! Can you confirm?
I own a Display LT sensor and I've been reading it shouldn't be on when using plasmas!!!
What changes when mounted or unmounted?
blutarsky is offline
Old 02-28-2008, 04:21 AM
timmorris's Avatar
A Display LT sensor is a completely different thing, I don't know how HCFR addresses the D2 as it doesn't specifically have a plasma mode.
All I KNOW is that with both the Calman software and the Spyder TV software you are told to fit the filter when using the S2 meter. The S2 meter is not calibrated so unless you are very lucky the results are likely to be inaccurate.
Tim
Old 02-28-2008, 04:39 AM
richlo's Avatar
it happens..not abnormal to see this..what are you using to measure the gamut
Rich L
Go Chicago Bears
richlo is offline
Old 02-28-2008, 10:41 AM
mech's Avatar
I recently upgraded to Vista on my laptop. When using the old 1.22f version of HCFR I had no issues whatsoever. Now I've finally gotten around to upgrading to the newer version and it refuses to find my i1. I have tried both versions of eyeone.dll but neither works. When I uninstall and go back to the previous version of HCFR (1.22f) it works fine. I've uninstalled, reinstalled, cleaned the registry, shuffled files... is there something I'm missing?
Any advice?
mech
mech is offline
Old 02-28-2008, 07:38 PM
kjgarrison's Avatar
If you mean what probe. DTR-94
Duh. DTP-94
Old 02-28-2008, 08:44 PM
richlo's Avatar
where is your file
Rich L
Go Chicago Bears
richlo is offline
Old 02-29-2008, 11:25 AM
kjgarrison's Avatar
where is your file
internet probs with uploads
supposed to be fixed
kjg 2 27 DALLIGHT.zip 2.8662109375k . file
Old 02-29-2008, 03:33 PM
Tim
With the spydertv software and measuring a CRT TV it ask me to REMOVE the baflle before measuring black and white and for colours it says to put the baflle ON?
This is with the newest version SpyderTV software.
greetz
Old 03-04-2008, 09:45 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
I have a question that maybe someone could answer for me. When I'm doing my calibration is there a place where you can enter your target x,y,Y values so you can get a dE for each measurement when you are trying to dial things in. When trying to get white point squared away it's easy to just watch color temp, but when trying to nail down primaries/secondaires a dE value would go along way (with the x,y,Y that's already there).
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
Old 03-04-2008, 02:19 PM
HiHoStevo's Avatar
Originally Posted by laric View Post
That is all explained in "ColorHCFR for dummies" (not yet available in English)...
But yes it should be made more obvious for beginners...
As for 75%, I thought it was allready possible, just can't figure if it really was or only in my mind !
--Patrice
Any idea when the English version might be available for the really dumb..........??
Also will this software work with the Progressive Labs CA-6X sensor?
There are just two theories for successfully quarreling with a woman -- neither one works!
The Barn - Use Password = AVSForum
HiHoStevo is offline
Old 03-04-2008, 07:51 PM
kjgarrison's Avatar
Heres a more than decent translation IMO. Just a few posts back up the page.
http://www.avsforum.com/avs-vb/showt...5#post13237045
Old 03-05-2008, 06:26 PM
turbe's Avatar
Liked: 95
Here is my Calibration (and Control) tool that ColorHCFR users may be interested in:
Since I have received several PM's regarding Calibration Automation with applications like ColorHCFR, the ControlCAL API Plugin is still in development and is not currently available to other Developers. Please don't send PM's requesting release dates and when and if other applications will support ControlCAL's API. Feel free to post in ControlCAL's Forum thread.
ControlCAL v1.4 RC1 is Now Available!
Download Link is available at http://www.ControlCAL.com
I'll be posting more information soon concerning the options available when creating and editing ControlCAL Display Profiles....
v1.4 RC1 - 03/05/2008
+NEW ControlCAL Display Profile File Format (.cdp extension).
+Create/Edit/View/Save ControlCAL Display Profiles Option.
+Load Display Profiles created by others.
+You can now toggle between ASCII and HEX Input Modes in the ControlCAL Terminal Window (Advance Mode).
+Internal Serial Command Format Support for many Manufacturers including BenQ, Epson, JVC, Panasonic, Pioneer, Mitsubishi, Sony (including Sony Checksum), Sharp and more....
+Internal Support for Mitsubishi HC Series Projectors - Profile can be used as a starting point for Creating a Profile for your Display.
+Many Internal Code Changes...
+More info Coming Soon......
*v1.4 RC1 is a Time Limited Version and will expire on May 31, 2008.
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
