ColorHCFR v2.0 Available... - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 985 Old 02-06-2008, 07:28 AM
Killerbeenl's Avatar
Originally Posted by laric View Post
Yes, the entry il labeled "Rec601 (NTSC)" we know it is a bit confusing, may be we should have labeled it "Rec601 (SD)"... or find a better name for the old EBU "Pal/Secam" one...
--Patrice
Patrice,
I will use the REC601 from now on,thanks
greetzzz,
Danny
Sometimes you are 1 click away from pulling your hair out and bang your head against the wall
Killerbeenl is offline
post #182 of 985 Old 02-06-2008, 08:14 AM
Brian Hampton's Avatar
Quoted: 584 Post(s)
Liked: 312
I just used the latest HFCR with the 709 disc also available from this forum to run through a calibration of my pj. It looks great and maybe I'll try again soon to make it even better (the calibration file doesn't look to be perfect but I made a few passes and it's not too bad.)
This was lots of fun and the pj looks great. Thanks Again.
-Brian
Brian Hampton is offline
post #183 of 985 Old 02-06-2008, 08:17 AM - Thread Starter
laric's Avatar
That is the end goal, glad you enjoy the experience... and results !
(And tool )
--Patrice
French speaking home theater HCFR Forum
laric is offline
post #184 of 985 Old 02-06-2008, 01:43 PM
Losha's Avatar
would it be possible to support irradiance and reflective measurement with the eye-one pro ? (i have an oem-version, so no imatch for me.. would be nice to measure other stuff too, e.g. in free measure)
It's a guy thing. We don't read. We do. We ask questions later. quote by Curt
Losha is offline
post #185 of 985 Old 02-07-2008, 02:50 AM
blutarsky's Avatar
Is there a DVD with 709 patterns usabel with plasma (small windows) somewehere? I have a PS3 and at the moment there's no Blu Ray disc patterns available...
blutarsky is offline
post #186 of 985 Old 02-07-2008, 02:54 AM - Thread Starter
laric's Avatar
There is, try this one : http://www.avsforum.com/avs-vb/showthread.php?t=948496
--Patrice
laric is offline
post #187 of 985 Old 02-07-2008, 06:32 AM
blutarsky's Avatar
Well, I'd change that reference label in the next release to "REC 601 NTSC\\PAL" or "REC 601" or "REC 601 SD DVD".... btw, what chances we have to have the opportunity to access the ISF CCC interface
Or maybe the royalties are too high to keep HCFR freeware?
post #188 of 985 Old 02-08-2008, 02:34 AM
blutarsky's Avatar
Guys,
some questions:
1) in the guide "pour nuls" it is showed the sensor attached to a plasma screen with some adhesive tape. How do you calibrate offsets keepeing the sensor attached to the screen? Some plasma screens, although turned off still emit some light...I'm asking because I'm not attaching the Eyone Display 2 sensor, just because every 10 minutes I want to recalibrate offsets (putting the sensor in a black plastic bag, with lights turned off, at night) and having the sensor attached with adhesive tape would uncomfortable....
2) I didn't understand how to run the ANSI contrast measurements: my sensor is attached in such a proper position for color/IRE window measurements, that when in the ANSI "chess table" windows, it as on the border of two squares one white one black.... what am I supposed to do?
post #189 of 985 Old 02-08-2008, 03:38 AM
richlo's Avatar
Originally Posted by blutarsky View Post
Guys,
some questions:
The Eyeone display2 does not need adhesive tape, it has smallsuction cups on it, and if you want to recalibrate it, just remove and put on planar surface and your good to go.
Rich L
Go Chicago Bears
richlo is offline
post #190 of 985 Old 02-08-2008, 04:10 AM
blutarsky's Avatar
Rich,
in the guide they've tapered the sensor also to avoid ambient light interefering with measurements (I think )
post #191 of 985 Old 02-08-2008, 05:47 AM
jvincent's Avatar
I wouldn't worry too much about the ANSI measurement. It's just a number and doesn't help with picture quality anyway.
jvincent is offline
post #192 of 985 Old 02-08-2008, 05:52 AM
blutarsky's Avatar
Noting can keep my mind away from thinking that, we, experimenting-users we will be constrained in the flaky-calibration domain, due to limited sensor accuracy.
Switching to a professional tool, means money.
At this point, we could be thinking, how much our sensor is keeping us away from a very good calibration.....
BUT.... ther is a "but"!
If someone had some seriuos equipment and made some tests and discovered that tipically some cheap sensors could benefit from compensated values, we could bring our tests, a step beyond.
So the qeustion is, if did anyone tested Eyeone Display LT/2 with some extremely costly equipment, to check accuracy?
If so, are those compensation values well known?
Can our best friend HCFR take thos compensations?
post #193 of 985 Old 02-08-2008, 05:58 AM
jvincent's Avatar
TomHuffman did this in his meter shootout. He compared the i1Pro to the D2 and Spyder.
http://www.avsforum.com/avs-vb/showthread.php?t=958099
jvincent is offline
post #194 of 985 Old 02-08-2008, 06:00 AM
blutarsky's Avatar
What about those 20k sensors..... did anyone compare?
And do you know if HCFR can take those compensation values in account?
post #195 of 985 Old 02-08-2008, 06:07 AM
jvincent's Avatar
I don't think anyone did that comparison but don't forget you very quickly get to a point of diminishing returns.
As a hobbyist, if your measurements are within the range of human perception then it's probably not worth spending much more money.
jvincent is offline
post #196 of 985 Old 02-08-2008, 06:10 AM
blutarsky's Avatar
I didn't want to spend more, only thought if those shifts from reality could be taken in account from HCFR.
post #197 of 985 Old 02-08-2008, 06:14 AM
jvincent's Avatar
You can adjust meter offsets in HCFR, but every probe is different. So you would need to have the reference probe to create the offsets.
jvincent is offline
post #198 of 985 Old 02-08-2008, 07:06 AM
dooshorama's Avatar
question:
i've noticed with the eye-one sensor, during free metering, when transitioning from high contrast (say 80%) to low (say 20%), there is a long pause. the sensor seems to freeze. even when i click on "stop", the sensor does not respond. the work around is to switch to a high contrast image and (sensor responds immediately), stop measuring, switch to low contrast, and restart metering - then the sensor responds without delay.
is this due to the sensor or the software?
dooshorama is offline
post #199 of 985 Old 02-08-2008, 07:32 AM
blutarsky's Avatar
You mean, for example, that every Eyeone Displa LT is different?
post #200 of 985 Old 02-08-2008, 08:18 AM
jimwhite's Avatar
yes
Jim White
St. Petersburg, FL
jimwhite is offline
post #201 of 985 Old 02-08-2008, 08:23 AM
blutarsky's Avatar
Wow! How do you know what your probe is reading an\\or if it is wrong?!?!?
post #202 of 985 Old 02-08-2008, 08:36 AM - Thread Starter
laric's Avatar
They are different to a certain extend...
BTW, all are... You just have to know the tolerances, and may be not look for an ultimate .5 dE with such probes.
--Patrice
laric is offline
post #203 of 985 Old 02-08-2008, 09:22 AM
jvincent's Avatar
Assuming it is not broken, it should read within it's tolerances, which are well below the human level of perception.
And following up, what you get with the $20K probes is tighter tolerances and things like the ability to calibrate to NIST verifiable references.
jvincent is offline
post #204 of 985 Old 02-08-2008, 04:45 PM
audioholicJeffL's Avatar
Hey guys, I got an issue. version 2 keeps crashing. I have tried both vista and XP and it has the same issue on both. When I click on the grey scale measure I get the hour glass and the program stops responding. I am using the DTP-94 and using a macbook with VMware. Both vista and XP worked perfect before. I have also tried uninstalling and reinstalling and recopying over the DLL file for the probe and it still hangs up when I try to measure grey scale. Any ideas?
audioholicJeffL is offline
post #205 of 985 Old 02-08-2008, 05:06 PM
alluringreality's Avatar
Quoted: 57 Post(s)
Liked: 65
Originally Posted by audioholicJeffL View Post
macbook with VMware
If you have one of the Intel ones, can't you dual boot?
alluringreality is offline
post #206 of 985 Old 02-08-2008, 05:39 PM
dooshorama's Avatar
the individual meter offsets leaves room for someone with a more expensive "reference" probe to create HCFR offset files at a cost. meters would need to be sent back and forth. it's a business idea for a trustworthy individual with some free time.
post #207 of 985 Old 02-08-2008, 06:33 PM
Yes I can if I want to set it up that way. Really shouldn't have to it worked flawless with the other version. The program has no way of knowing it is running in VM ware. It is still windows running native.
post #208 of 985 Old 02-08-2008, 08:22 PM
stash64's Avatar
Quoted: 282 Post(s)
Liked: 100
I need a helpful little nudge. I thought I was ready to run through my first calibration using HCFR and my i1 Display LT, but I don't see any measurement tool for contrast in the HCFR menu. Do I use the "Measure Gray Scale" tool along with a 100% gray pattern ? And if so, what reading am I looking for ?
Tom Huffman's guide suggests measuring light output in "fL", and that light output in "fL" can be calculated as: 100%Y x .29. I have a rear projection set, so I want to set contrast at a level that produces 35 fL. However, I don't understand what units of measure correspond to "100%Y".
Lastly, I don't see a black level measurement tool either. Is black level to be set just by eye, not using the colormeter ?
Sean
stash64 is offline
post #209 of 985 Old 02-08-2008, 08:35 PM
richlo's Avatar
Sean
Just bring up 100% stimulus (the last white in a greyscale measurement), then increase contrast until you get about 120Y, this should equate to 35ftl..just remember any greyscale adjust will change this..so you might have to go back and forth to get close to that..
Rich L
Go Chicago Bears
richlo is offline
post #210 of 985 Old 02-09-2008, 02:27 PM
stash64's Avatar
Quoted: 282 Post(s)
Liked: 100
Originally Posted by richlo View Post
Sean
Thank You !!! That was where I was stuck. I did not think you could actually have a "Y" value over 100. I'm going to take a shot at calbrating with HCFR and the AVS HD patterns tonight. Fingers crossed.
How about black level ? Is this done without the colormeter ? I don't see a problem with running black level by eye only since it is the easiest setting to judge by eye.
Sean
stash64 is offline
Reply Display Calibration
