Xbox 360 - Can You Rip CD's to it? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 03-14-2008, 11:40 AM - Thread Starter
Fit2Run's Avatar
I have xbox 360 and I am hooking it to my home theater shortly. I want to be able to rip all my cd's to it.
#1 can xbox 360 do that?
#2 how long per cd to rip?
#3 will it show the song, album cover etc on the screen (50")
#4 how much will it hold (assuming I have nothing else on it)
#5 Does 360 make sense for this application.
Otherwise I may by the escient vision se-80
Fit2Run is offline
post #2 of 14 Old 03-14-2008, 11:46 AM
reaper's Avatar
1 Yes, you can rip CDs to it.
2 Been a while since I did it but it seemed comparable to PC times... 3-5 mins maybe?
3 Not sure about the album art but I think not.
4 The drive for a standard 360 is 20GB. You might consider an elite with a 120GB drive
5 Not really. The best way to do it would be to rip them to your Windows PC or Mac and then stream them to your 360 via ethernet. You definitely get album art then... well you do if you do a media center PC and connect it to the 360.
reaper is offline
post #3 of 14 Old 03-14-2008, 11:49 AM
alucard_x's Avatar
Quoted: 25 Post(s)
Liked: 25
using this method you can't play the music while playing games or as a custom soundtrack.
the best way is to just hook up a usb harddrive or ipod and play the music that way, you can get to it right under chat and im settings while in any game by hitting the xbox button.
alucard_x is offline
post #4 of 14 Old 03-14-2008, 11:51 AM
logicalnoise's Avatar
nope I stream from my PC while playing Puzzle Quest all the time(the soundtrack gets repetitive).
logicalnoise is offline
post #5 of 14 Old 03-14-2008, 12:03 PM
reaper's Avatar
Agreed. You can indeed stream music from a PC both through media center and through the guide button which works in-game.
reaper is offline
post #6 of 14 Old 03-14-2008, 12:03 PM
jasonstiller's Avatar
What you lose by streaming is the custom playlist feature so youll have to either listen to the songs in whatever order the xbox has them in or pause the game everytime you want to skip a song your not in the mood for. The best way is to rip your favorites to the 360 HD and make a some sweet playlists base on the action content of the game
jasonstiller is offline
post #7 of 14 Old 03-14-2008, 12:04 PM
Sunkist's Avatar
So have I, I was streaming the spice girls while playing Halo3 split screen just to piss of my friends. Works way better than putting all of your music on the HD.
Sunkist is online now
post #8 of 14 Old 03-14-2008, 12:05 PM
hotdogwater2's Avatar
I do it all the time with no problems -- go try it
XBL Gamertag: The Abuser
hotdogwater2 is offline
post #9 of 14 Old 03-14-2008, 12:09 PM
reaper's Avatar
Also not true. I believe you can simply create a playlist on the PC and you can play that if you want to. It will synch to your playlist and play only those songs.
reaper is offline
post #10 of 14 Old 03-14-2008, 12:12 PM - Thread Starter
Fit2Run's Avatar
I dont have any songs on my PC. They are all on CD's. Now do I rip my cd's onto my computer and then through the network play them on xbox? Eventually I can add songs using Itunes.
Fit2Run is offline
post #11 of 14 Old 03-14-2008, 12:27 PM
fjtorres's Avatar
Correct.
The 360 native media player knows playlists and will load them correctly.
You just need to create them on the PC and be very careful about the path names. It even recognizes autoplaylists (recentlt added, most played, etc) on my Gigabeat.
The trade off between the native media player and the MCE client is album art via MCE vs visualizations via native dashboard player.
And, of course, you are limited to 100 songs inside games.
They've covered most of the bases, although it would be nice if they updated the player to allow local album art as "visualization" option...
fjtorres is offline
post #12 of 14 Old 03-14-2008, 12:32 PM
fjtorres's Avatar
Yes, you can do that. There's about 5 or 6 ways to do it. Easiest is via WMP or Zune software.
You can also burn a data CD or DVD and play the ripped music off that.
Or you could copy ripped music to an external USB-connected HDD.
BTW, if you haven't started ripping and you have the space, consider ripping each CD twice: one at whatever data rate and format you prefer for portable use and a second time in either WMA lossless (preferred) or high bit-rate WMV VBR (say, 320KBPS). Low-bit-rate files really show their limits when played through a good sound system...
fjtorres is offline
post #13 of 14 Old 03-14-2008, 12:43 PM
Savageone79's Avatar
also if anyone doesn't know already you don't have to pause your game to skip a song in a playlist you can just use the skip forward button on the xbox remote and it will skip the song without interupting your gameplay.
Savageone79 is offline
post #14 of 14 Old 03-14-2008, 12:51 PM
reaper's Avatar
FYI: Beware of iTunes content. If it contains DRM, it will not play on the 360.
reaper is offline
Reply Xbox Area
